Hi Vooch: ___55 highway is a bit optimistic on the 08 EPA but lower 50’s may be within reach. See the following for more details … 2007 LA Auto Show Wrap-up ___Good Luck ___Wayne
the 103kw TDI gets 5.9l/100k vs. 8.3l/100k for the 2.0T FSI in Germany that suggests only a 20-25% boost in gas milage for the TDI vs. VW's current offering. i reckon that's about 40 HWY - how do they get to 'mid 50's' ?
Hi Vooch: ___The next gen 2.0L TDI slated for the US is the exact engine that will power the new VW TDI’s overseas plus the new NOx/PM emissions tech. That is the only difference between the 2.0 we will see here and the one they will see in Europe. ___As to how they are going to get there, have you read the Honda Civic 2.2L iCDTi review? The 2.2L iCDTi is 2 generations ahead of the old 1.9L TDI’s the US is familiar with and the upcoming VW 2.0L TDI is another generation ahead of the iCDTi in that review! By all appearances, ramping up injector pressures with multiple injections via Piezo electric action, adding an intake swirl/constrictor for low, mid and high speed operation and the new VVT tech is increasing the efficiency of these monsters in lockstep. The neat thing is they (Audi/VW, BMW, Ford/Peugeot, GM/Opel, Honda and MB) are achieving even higher performance, lower emissions before the after treatment and another step change increase in FE all the while running even lower compression ratios reducing NVH. **** near magic and after you drive one of these modern miracles, you will wonder why it took so long to get these excellent engines into the US! ___Good Luck ___Wayne
Wayne, you're making me drool again. It still burns me up that we can't get that car you reviewed over here... What incredible potential! I'm really excited to see what we get with the new Jettas but I'm still having trouble getting past my concern about their electrical issues of the past? I don't think I'd have any concerns with a Honda...
Wayne - are you suggesting that the new 2.0TDI will have approx. a 4 l/100km rating (euro method) ? That would truely be amazing ! A 103 inch wheelbase car (Jetta) w/ some 240 ft lbs. of torque getting such awesome MPG
A 4l / 100km rating is very good, probably out of reach for a 2.0 TDI Jetta. I would guess the new TDI will be similar to the current 2.0 TDI and 2.2 i-CTDi: Low 7's (l/100km) in the city and mid 5's on the highway, which would be around 33/44 miles per US gallon. Somebody from VW originally said 40/60 but I think that's optimistic unless they have some major magic going on somewhere. A good hypermiler should be able to extract much more than that though. The engine probably has close to the same potential for high mpg as the i-CTDi that Wayne tested, likely a little lower because of tighter emissions requirements. Sean, the Mk 5's (current Jetta/Rabbit) are supposedly better than the Mk 4's (previous Jetta/Golf) but there is clearly still room for improvement. Hopefully the Mk 6's will be another step in the right direction. Many of the common issues on the Mk 4's seem to be caused by over-enthusiastic cost cutting. Poor solder is sometimes a culprit, window regulators using plastic clips instead of metal led to the commonly mentioned power window problems, and I think the popular 1.8T / VR6 coil pack problems started to come up when VW decided to go with a new supplier. I know much less about the Mk5's because I don't own one, but from what I've read, there seems to be much less of the penny pinching problems. Germans do, however, often like to make things more complicated than they need to be, which probably leads to some problems. Even in my car, I see many sensors, switches, and assemblies that seem to be oddly placed or not even present on American or Asian cars. My biggest hesitation with the new TDI and emissions systems would be clueless dealers. I have confidence that my dealer will get on top of things very quickly once they see how things work, but there are way too many dealers who still don't know how to work on the 1.9 TDI, which has been around in various forms for around 10 years. I really think VW of America should be trying to figure out how to fix their service departments. If VW's service departments were on par with Toyota's, I believe VW's reliability ratings would go from near the bottom to about average. I'm getting too excited here. I need a break.
Thanks for the info, Mike. I know a fair bit about VW's early history (I'm a Beetle nut ), and they had fantastic service early on. They knew it was supremely important for survival in a new market. In fact, it was their policy to have enough parts on hand to construct two complete VW Beetles from scratch. Coupled with solid engineering (and OVERengineering) they had a winning combination that proved to be the foundation of a hugely successful company. I really wish they would return to those early values. Regardless, I'm still excited to see how well this new Jetta is constructed and what reliability is like.
Hi Mike: ___The VW reps in LA said to expect high 40's to mid 50's on the 08 EPA. ___Good Luck ___Wayne
High 40's to mid 50's would be amazing if they can get it. That is a big improvement over their current engines.
I have the current Jetta (06 5 speed wife's car) and 50 MPG is very achievable on the highway. If the new Jetta is rated anywhere near 50, then 55-60 MPG is probobly attainable on the highway.
The current Jetta TDI is only rated at 37 on the highway from the EPA. It is very easy to beat the EPA with TDI's, though. Getting over 50 mpg on the highway with the upcoming engine should not be a problem, but seeing an EPA rating that high would really impress me.
Wayne - mid 50's HWY MPG on the '08 EPA cycle means over 60 for us still used to the old EPA numbers. Imagine, a large car ( 103 inch wheelbase ) with the ability to cruise autobahn speeds scoring those kind of numbers. What will the Detroit lobbyists do about that ?
Tonight at the Audi/VW dinner Wayne and I had a chance to talk to a VW manager and he informed us that mid 40's is optimistic for an '08 EPA rating.
He said that combined will be lower than mid 40's. While he couldn't give a direct answer as the testing has not be completed yet on the '08 EPA cycle, I got the idea that he was expecting a combined in the high 30's.
Combined in the high 30's using '08 EPA - that works out to say 45 combined old EPA.................that is about 70% better than the gas model. Could I extrapolate and figure that my combined MPG will be 56 (33 * 1.7) once they put the same engine in a Passat Wagon ?
Hi Vooch: ___The upper-level manager did not really hint at anything in the 30’s but simply stated mid 40’s to low 50’s would be optimistic. It will do 65 + for most here as it is more fuel efficient then the 1.9’s while being far more powerful and cleaner as well. ___Good Luck ___Wayne
Hi Koreberg: ___I asked about both the Rabbit and the Golf using the 2.0L TDI. He looked back at me and smiled ___Good Luck ___Wayne
