Hi All: I just purchased and had installed a new set of the P195/65R15 Dunlop Enasave AS' on the 2021 Toyota Prius Prime for $403.82 ((4) tires @ $322.83 incl. tax + $80.99 install and disposal). On the rack receiving its new Enasave's earlier this morning. The new tires were manufactured/created during the 33rd week of 2022, same as those I ran out to 120k miles. The original OEM P195/65R15 91S' with the Uniform Tire Quality Grade (UTQG) of 340AB lasted 95k miles from initial purchase through two replacements at 95k and 190k miles. For the last set, I purchased the P195/65R15 89S' with a (UTQG) of 540AB and they made it all the way out to 120k miles before needing replacement. The former 91S' were the OEMs and are lighter at 16 lbs. vs 18 lbs. for the 89S'. They also have a 9/32 tread depth when new vs the 89S' at 8/32. The latter really does last longer and while the OEM Load index of 91 appears to be higher than the 89 rating of the replacements, that number is generated at max sidewall. The 91S' have a 51psi max sidewall vs the 89S' 44 psi max sidewall. If I were to have purchased these from Discount Tire this go around, I would have had to purchase the 91S' as they do not carry the 89S'. And the price would have been $638.09. Another comparison, if you happen to own a Tesla Model 3/Y with the OEM P255/45 R19 Continental ProContact RX' for example, to replace those at a Discount Tire would cost you $1,325.90 with most owners replacing them between 5 and 40k miles. So yes, this is a pretty hot deal. Wayne
Hi All: The P195/65 R15 Dunlop Enasave's are still available on Walmart.com and TireRack has a closeout for just $68.53 a piece incl free shipping! That means just $274.12 for the tires and $80.99 install coming to a grand total of $355.11 + Tax!!! I looked up some 15" Bridgestone Ecopia's and Discount Tire now wants $170 each plus install, certificates if selected, and tax. I am guessing tariffs have killed the price but that is a guess on my part. Moving on, I was at a Discount Tire the other day and saw a pair of Michelin Energy Saver A/S' in one of the garage bays. I thought these were gone for good and while they have no sizes that fit the 4th or 5th gen Prius, to was good to see them when I thought they were gone for good. Michelin Energy Saver A/S Look closely at the sound coating within the inside of the tire. They decided against gluing in the foam ring that is causing problems for other tire brands. Michelin's ultimate fuel-efficient passenger car tire suited for drivers looking to maximize fuel economy without compromising long tread life and all-season safety. Ultimate Fuel Efficiency All-Season Safety Long Tread Life Standard Limited Warranty: 6 years Supported by the Michelin Promise Plan of a 60-day satisfaction guarantee, roadside assistance, and a mileage warranty up to 65,000 miles. Wayne
