More on The All-new, 5th Gen 2023 Toyota Prius Prime
Discussion in 'In the News' started by xcel, Nov 17, 2022.
  1. BillLin
    I glanced at the new reply summaries and read that as "real party in black." That works for me, too! :) The first two cars I ever purchased were black.
  2. EdwinTheMagnificent
    Like Wayne , I wouldn't want to own a black car. Or white.
    But it sure is pretty.
    xcel and BillLin like this.
  3. RedylC94
    The best for hiding at night, and also for maximizing demand on the air conditioner on sunny days.
    And a few highlights mentioned or not in the Std. 2023 Prius Preview and Review, how about the power Liftgate on the XSE Premium?
    The tray underneath the rear cargo floor with the Fix-A-Flat and 120V Charging Cord.
    And look at this. That is the smallest 12V I have ever seen in an automobile! It was moved to the rear from the front like the 2017 - 2022s.
    The following comes from the 2017 - 2022 4th gen Toyota Prius Prime. I never understood why the 4th Gen Prime comes with a jack when it is equipped with fix-a-flat and compressor, but I have used it on my now sold 2020. The 2023 Does not include it or the compartment underneath and to the side of the driver’s side rear seat.
  5. xcel
    And some more hero shots of the all-new Prime I snapped this morning... Which do you like best?
  6. Trollbait
    Trollbait Well-Known Member
    The phrasing of the 2023 Prius manual made it sound as if the jack was optional for it.
  7. litesong
    litesong litesong
    It must be called the “stop&go&stop” test.
  8. litesong
    litesong litesong
    Black ain’t even a color!
  9. RedylC94
    To better represent real-world driving, the test should consist of repeats of uphill&downhill&stop&uphill&downhill&stop&uphill&downhill&stop ... ---all while maintaining a specified average speed.
  10. litesong
    litesong litesong
    Ah….you must be German. They love to squish their words & make new long words. AND I see you like my &’s.
  11. RedylC94
    I was just imitating your format.
    The serious point was that standard tests don't account for the way real-world secondary roads so often have stop signs or stop lights at the bottom of hills, which wastes a lot of energy.
  12. litesong
    litesong litesong
    But when auto manufacturers say they have 2.5 ton gas hogs that gets 42MPG, don’t ya wanna BUY THE BEHEMOTH?
    Ya ken’t be against motherhood, apple pie, lying in advertising & the american way.
  13. xcel
    A lot of questions about cargo volume so let us consider the 2023 5th Gen Prius Prime cargo dimensions with seats up and seats down vs the 2022 4th Gen Prius Prime.
    [​IMG][​IMG]
    Seats Up
    36.5" Depth
    36.5" Width
    22" Center Height
    21" Edge Height
    Seats Down
    62" Depth
    2017 - 2022 Toyota Prius Prime
    Seats Up
    34" Depth
    37" Width
    20.5" Center Height
    19.5" Edge Height
    Seats Down
    64" Depth
    So side by side, the 2023 Toyota Prius Prime improves the real world cargo carrying ability with a larger opening and deeper with the rear seats up but slightly less width and less depth with the rear seats down.
    2023 Prius Prime vs 2022 Prius Prime
    Seats Up
    Depth - 36.5"/34"
    Width - 36.5"/37"
    Height (center) - 22"/20.5"
    Height (edges) - 21"/19.5"
    Seats Down
    Depth - 62"/64"
  14. xcel
    2023 Prius Prime Trim Pricing (MSRP) vs 2017 - 2022 Prius Prime
    SE - $32,350, up $2,585 from the 22 LEs $29,765
    XSE - $35,600, up $4,055 from the 22 XLEs $31,545
    XSE Premium - $39,170, up $3,625 from the 22 Limited's $35,545
    D&H: $1,095, up $100 over the 22's $995 D&H fee
    The loss of the $4,502 Fed tax credit <-- Toyota’s Fed tax credit sunset began in Sept. of last year anyway, some states removing the PHEV rebates, dealers not providing any discounts, and the rather steep bump in the retail price is going to be a tough sell for some going forward. Remember the new 2021 Prius Prime purchase for $15,700 + TTL and Reg? Yeah, that is long gone. :(
    2023 Toyota Prius Prime vs 2017 - 2022 Prius Prime
    Engine and Drivetrain
    • 2.0L I4 vs 1.8L I4
    • 220 net hp vs 121 net hp
    • 0 to 60 mph - 6.6 sec vs 10.2 sec
    • Compression Ratio is 14:1 vs 13:1
    • 150 hp @ 6,000 rpm and 139 lb.-ft. torque vs 95 hp @ 5,200 rpm and 105 lb-ft of torque
    • 53/51/52 (SE) and 50/47/48 (XSE, XSE Premium) vs 55/53/54 (mpgUS city/highway/combined)
    • Driving Range (Gas/EV combined) - 600 miles (SE)/550 miles (XSE, XSE Premium) vs 640 miles
    • EV Driving Range - 44-miles (SE)/39-miles (XSE & XSE Premium) vs 25-miles
    • Onboard Charger - 3.5 kW vs 3.3 KW
    • Charging Time - 4 hrs. (240V)/11 hrs. (120V) vs 2.2 hrs. (240V)/5.5 hours (120V)
    • Max Voltage - DC650V vs DC600V
    • MG2 Output - 161 HP vs 71 HP
    • Li-Ion pack weight and capacity - 284 lbs and 13.6 kWh (11.5 kWh useable) vs 265 lbs and 8.8 kWh (6 kWh useable)
    Where did all of that power increase come from? Like the 23 Prius, the Prius Prime's MGs include redesigned magnets, and the pole numbers were increased by 2. The stator windings were moved much closer to the rotor reducing magnetic field flux "leakage" and tighter wound windings reduced resistance losses. The MGs, inverter/transverter, and eCVT have been shrunk in size reducing both total mass and electrical losses across the system. With the larger capacity and more powerful Li-Ion pack, voltage was increased by 50V through the transverter to 650V. The more powerful Li-Ion and MG1 allowed Toyota to remove the 2017 – 2022 Prius Primes one way clutch that separated the Engine from MG1 at higher speeds.
    On the mechanical side, along with adding a dual port fuel and direct injection system like the D4-S system used on all of Toyota’s 2.5L Hybrid drivetrains, the compression ratio was bumped up by 1 from 13 to 14:1. I am only touching the surface as there is a lot more detail missing here.
    And a few on-the-road activities while at the 23 Prius Prime Short Lead.
    The 2023 Prius Prime provides much more regen than the 2017 - 2022's. Not anywhere near one pedal driving but much closer to that then not. I was unable to adjust this higher level of regen out from the Mode Settings screens I was looking through. I am not a fan, but it appears the general public wants more and Toyota provided it.
    I was unable to get an answer with regards to the Japan Spec “MySpace” solution where HVAC can be used indefinitely when plugged in. We will have to wait on this as well.
    2023 Toyota Prius Prime First Drive Results
    On gasoline hybrid engine: 60-mph NB and SB highway aFCDs – 56 mpg
    City Drive Loop – 82.7 mpg
    On EV drivetrain only: 20-mile city drive loop aFCD – 6.4 miles/kWh
    20-mile, 60-mph highway drive loop aFCD – 4.6 miles/kWh​
    All of the above are non-calibrated aFCD results. I was able to calibrate the Prime XSE's speedometer to actual. Dead on at 60 mph. 60 mph indicated is 60 mph from several GPS programs I use.
    All in, that new and more powerful 2.0L and redesigned electronics from the larger and more powerful pack, more powerful MGs, and more compact but higher handling busses, provides the much higher performance with very little struggle like the 4th Gen Prius and Prius Prime. But just like the 23 Prius, those 19’s on the SE and SE Premium really took the efficiency to the woodshed. The first drive results are off by 10 to 20% from my own 2021 Prius Prime. I cannot wait to try out the SE's 17s for a more even comparison to my own.
    On a similar note, the only place to pick up the P195/60R17 tires (SE) and P195/50R19 tires (XSE, XSE Premium) is your local Toyota dealership and they cost $242 and $246 respectively. The 15" P195/65R15 Dunlop Enasave 01 A/S' on the 2017 - 2022 Prius and Prius Prime are just $120 a piece by comparison. US Toyota dealerships are offering Buy 3, get the 4th for a $1 if you mount and balance your tires at their stores so that will help lower the total cost to replace by $240 +.
  15. xcel
    A Toyota produced 2023 Toyota Prius Prime specs and walkaround vid.
  16. xcel
    The 2023 Toyota Prius Prime overview.
  17. xcel
    And finally, a few of my paraphrased notes from comments made by the Toyota PR, Comms, and Engineering teams at the 2023 Toyota Prius Prime short lead.
    In terms of battery raw materials, Toyota can build 90 HEVs vs 7 PHEVs and just 1 BEV from the same materials. That statement was eye opening as it points to Toyota's direction despite which way the wind blows on any given day.
    SE/XSE and XSE Premium - 44/39-miles EV and 52/48 mpg combined.
    Gen 4 to Gen 5 - 600 to 650V with 150 HP I4 ICE, 161 HP motors, and 220 HP combined.
    You will see this advert soon enough and it is pretty darn cool. Here are the tag lines to it.
    Toyota expects to sell 10k Prius Primes in 2023 - starting in May, and 15k units in 2024.
    2023 Toyota Prius Prime LED Headlamp detail
    2023 Toyota Prius Prime Q&A
    • Why just a 3.5 KW onboard charger? Excuses.
    • Solar Panel power? 185 W - could add upwards of 775 miles/year or ~ 2-miles per day.
    • When will the Prime be available? May of this year.
    • Is there a 1-pedal driving mode? Not entirely.
    • % of Prius sales that may be Prime? 30%.
    • Days to emissions crossover between Prius and Prius Prime with std. national grid and miles driven per year? Unknown.
    • Why no AWD with Prius Prime? Larger battery packaging.
    • Why was DI and MPFI incorporated? Power.
    2023 Toyota Prius Prime First Drive personal impressions and additional Q&A...
    • The driver display sightline over the wheel sucks
    • Less body roll but the 23 still provides a comfortable ride
    • More reverb buffeting with front drivers and rear quarter panel dropped a small amount
    • 23 Prime is as quiet as the 4th gen. 23 Prius is noisier than the 4th gen Prius
    • Regen is definitely stronger. It is similar to One-pedal but will not slow all the way to a stop. I cannot find a way to adjust it. And I want a lot less!
    • EV and HEV stats. The new XSE with 19s is not as efficient as my LE w/ 15's by 10 to 20% - Posted in this thread previously
    • Started first all-EV drive at 0.6 miles and 92% SOC. Completed first drive with both city and highway results after 52 miles at 0% SOC
    • Charging Cable locks to the car while charging. Unlock car to release. Posted previously
    • Cargo Volume measurements and comparison to 2022. Posted previously
    • 13.4 kWh total, 11.5 kWh useable
    • 650V from 600V in the 2017 - 2022
    • No ICE to MG1 clutch in the 2023. The higher power output Li-Ion and MG1 takes care of the problem
  18. xcel
    From the 23 Toyota Prius Prime presentation deck.
    This
    leads to this:
  19. xcel
    Another possible reason along with the larger wheel openings, higher ground clearance, and not-straight sculpted sides from the plan view, for the higher Cd is the underbody. There is a lot of open area under there but I suspect the rear underbody panels were pulled for this Media shot.
    2023 Toyota Prius Prime underbody
  20. xcel
    What the SE trims 17" alloys and wheel covers look like up close. They are more gray than black like the Prius LE.
    2023 Toyota Prius Prime 17" alloy and wheel cover
    2023 Toyota Prius 17" alloy and wheel cover
