Month of December 2020 (Nat’l Avg $2.140)
Discussion in 'The Daily Grind' started by Gord, Dec 1, 2020.
  1. Gord
    Welcome back to the grind :D
    The national average gas price is up just under a penny (+0.9¢ / +0.4%) since last month at $2.140 - this time last year it was a fair bit higher at $2.591
    so it's still 45.1¢ (-17.4%) cheaper.
    Diesel is up a chunkier 6.1¢ (+2.6%) on the month to $2.426. However, it's 58.5¢ (-19.4%) cheaper than this time last year's giddy heights of $3.011.
    Diesel premium is +13.4% over Regular.
    E85 is up 1.6¢ (+0.8%) to $1.933 - a year ago it was $2.320 so 16.7% cheaper.
    _____________________
    Last night, motorway route - not a lot of traffic, 48°F, tail/crosswind NW9:
    48.3 / 21.4
    This morning, motorway route, cooler 37°F, headwind NW7:
    49.2 / 21.5
    Tank down 0.4 at 48.7 (FCD 51.4) / 91.4 / Range 625 . Guess gauge F««««|««««E . UG down 0.4 at 52.3 / DTE 615
  2. EdwinTheMagnificent
    Thanks for starting our thread, Gord.
    Today I'm in the Honda. 25 deg F in Naperville and Elk Grove.
    35.1 miles , fcd = 45.5 MPG. Not so bad.
    Fcd read about 42 when I got on the highway and about 44 when I got off.
    Gord and BillLin like this.
  3. BillLin
    Thanks for getting December rolling, Gord. I'm fortunate to wake to temperatures in the 50s deg F before things return to more typical December first temps here in New England. My winter tires are on the Crosstrek but I'm leaving the new all seasons on the Prius for the time being. I've plugged a nail puncture on one new Prius tire already.
    Gord and EdwinTheMagnificent like this.
  4. EdwinTheMagnificent
    I still have my all-season tires on both cars. The Prius' Hankooks have 36K , so they
    are good still. Note to self : adjust pressure DOWN before first real snow , which
    might be later today. The Honda tires ? They "looked" okay when I bought the car,
    but Discount Tire said they should be replaced soon. That was in June 2020.
    I'm a fan of winter tires , and have bought them in the past , but never for one of my
    own cars. The Honda would really benefit from them.
    BillLin and Gord like this.
  5. litesong
    litesong litesong
    Glad to hear your Hankooks are still good to go. With winter coming, I assume your tread is still pretty deep. My two sets of cheaper OE Hankook 426’s weren’t good to go at 33,000 & 36,000 miles, showing accelerated wear after 20,000 miles.
    As for winter tires, I got two free used 195x75x14 inch studded Cooper Weather Master ST2 tires for the Hyundai Accent. Just put them on for their second winter for me. Depending how many miles I run them this winter, I think they should give a third winter season. So far the studded tires are only objectionably noisy in the 45 to 50mph range. At 55 to 65 MPH speeds they are louder than normal tires, but don’t irritate. The snows are fairly smooth, too. Yesterday, I went for a 150 mile drive & the snow tires were acceptable. If I had been in the 45 to 50MPG range for hours, I wouldn’t have liked that. Normally I almost always save the Accent for backroad driving below 45MPG. The snows are very good at those speeds. The snows are extending the life of my Accent Cooper MasterCraft All-Season tires. Yeah, I got away with free snow tires like a bandit.
    Gord, EdwinTheMagnificent and BillLin like this.
  6. BillLin
    I rarely have to adjust down. I was surprised to find the winter tires had dropped almost 10 PSI since I bought them late August. I cheaped out and didn't have the official TPMS installed. I picked up an aftermarket valve-cap type TPMS system a year or so ago and it works very well. The individual tire pressure and temperature display sits on the dash and is solar recharged. Email me if anyone's interested in more details.
    What sold me on the winter tires was that the tire compound remains more compliant as the temperatures fall, so even without snow, dry and wet pavement traction is improved over all-season tires.
  7. litesong
    litesong litesong
    Two to three years ago, I went through 3 fairly quick nail & screw punctures. Pretty sure it had something to do with the 2 new major house building projects directly connected to our 25 year old housing development.
  8. EdwinTheMagnificent
    Today in the Prius. 20 deg F in Naperville , 25 in Elk Grove.
    35.1 miles , fcd = 59.1 x .943 = 55.7 MPG. Could be worse.
    I could be driving that fuel-sucking Civic. :)
  9. EdwinTheMagnificent
    Today in the Honda. a little wind from the southwest
    helped. 35.1 miles , 46.4 MPG. Used heat on the highway.
    It was 27 deg F in Naperville and 28 in Elk Grove when I got to work
    a few minutes ago.
  10. BillLin
    Good job, Edwin. I once got a battery operated heated seat back and lower pad. It only used about 1 Amp at 12 Volts. Didn't need cabin heat as much. I need to look at grille blocks again...
  11. EdwinTheMagnificent
    Grille blocks for me too. I need to buy more pipe insulation.
    What I had last winter wasn't really enough AND I have no clue
    where it is.
    Gord, BillLin and RedylC94 like this.
  12. BillLin
    I like the pipe insulation approach as well. I'm thinking of seeing if coroplast can help. I have a bunch of old real estate signs made from that stuff.
  13. EdwinTheMagnificent
    coroplast : the ecomodder's friend
  14. RedylC94
    Very easy to place in lower grill of my 2011 Prius, and to adjust. A little more awkward in the tapered slots on top.
    EdwinTheMagnificent, Gord and BillLin like this.
  15. Gord
    I used to use pipe insulation to great effect in the diesel Honda FR-V as it took a bit of warming up below 45F but the gas Audi doesn’t seem to be as affected by the cold. We don’t get as cold as some of you guys though!!
    Tuesday night, bit quieter, 41°F, tail/crosswind NW4:
    50.6 / 21.5 - pretty good for a homeward bound trip
    Wednesday morning, non-motorway route as it looked busy, 45°F, head/crosswind SW6:
    50.5 / 19.6
    Wednesday night, motorway, 41°F, partial tailwind WSW6:
    48.0 / 21.4
    Thursday morning, motorway, damp, 37°F, crosswind S7:
    51.1 / 21.5 - another great run
    Thursday night, motorway, 38°F, crosswind N4:
    45.8 / 21.5 - stupid drivers braking when there was no need and a lot more traffic hampered my efforts!
    This morning, 36°F, cross/headwind NW7, snow/sleet forecast but it was just wet!:
    47.5 / 21.5
    Tank down 0.2 at 48.5 (FCD 51.1) / 218.4 / Range 485 . Guess gauge F__««|««««E . UG down 0.6 at 51.7 / DTE 481
    I've adjusted Ultragauge calibration a touch from 0.730 to 0.740 - might need more, I'll see how it goes!
    Lost pip 1 (of 8) @ 161 miles
  16. EdwinTheMagnificent
    Today in the Prius. 33 deg F in Naperville , some tailwind (SW).
    35.1 miles , fcd = 61.1 x .943 = 57.6 MPG.
    Distance remaining = 124 miles. Enough to get home today ,
    then to work and back Monday.
  17. EdwinTheMagnificent
    Today in the Prius. 33 deg F in Naperville.
    35.1 miles , fcd = 60.2 x .943 = 56.8 MPG.
    I will fill up tonight at the same place where I
    am picking up my amazon order , Amoco in Naperville.
    By writing that down , I won't forget to go inside and
    get my package from the amazon locker.
  18. EdwinTheMagnificent
    Today , still in the Prius( I didn't go home yesterday ).
    33 deg F in Naperville and Elk Grove.
    16.3 miles , fcd = 65.4 x .943 = 61.7 MPG.
    I will drive the Civic Wednesday and Thursday to balance out
    the miles. I hate to insure two cars , but I like keeping the miles
    down on each odometer.
  19. Gord
    Going home Friday lunchtime, motorway route, cold 35°F:
    43.7 / 21.2
    Friday afternoon to holiday home 2UP, 46°F:
    48.0 / 106.7
    Going home Sunday afternoon, came back slightly shorter route to avoid some road repairing, 42°F:
    46.8 / 101.1
    Monday morning, motorway route, freezing to start, 30 rising to 37°F at work, crosswind N3:
    49.6 / 21.5
    Monday night, motorway route, 37°F, partial tailwind WSW7:
    44.6 / 21.5
    This morning, motorway route, frosty 35°F, head/crosswind SW6:
    49.8 / 21.6
    Tank down 0.8 at 47.7 (FCD 50.3) / 512.0 / Range 125 . Guess gauge F____|_«««E . UG down 2.8 at 48.9 / DTE 148
    Lost pip 2 (of 8) @ 232 miles
    Lost pip 3 @ 292 miles
    Half tank at 352 miles
    Lost pip 5 @ 438 miles
  20. BillLin
    Wow! Fantastic!
    Gord likes this.
