tbaleno, your sig....
Discussion in 'Off-Topic' started by brick, Apr 5, 2006.
  1. brick
    brick Answers to "that guy."
    Mine still appears to be screwed up for some reason. When I add up all of the miles and gallons that I can see in my tank log I get 12125.9mi, 394.222gal, which is what it was before I added my last tank. But the total mileage calculation is using the correct data, which is 12619.4mi and 407.611gal. So the data exists somewhere in the database but isn't being displayed in the tank log.
  2. tbaleno
    tbaleno Well-Known Member
    try adding a tank with 0 miles and 0 gallons. Then deleting it and see if the signature updates properly
  3. brick
    I added a tank with 0 miles and 0 gallons and the sig stayed the same, and the missing tank didn't show up. Just for kicks I went back and edited that test tank to add a note and it went though just fine.
  4. tbaleno
    Okay, When I get home, I'm going to adjust your car so the miles in the logs match the car. It looks like you will be missing one tank so you will have to re-add it. Apparantly a tank got deleted but the totals for the car were not updated to reflect this.
  5. brick
    Sounds good to me. Appreciate it!
  6. philmcneal
    is this suppose to happen?
  7. tbaleno
    I wonder if this database will ever be free from bugs ;) It should be fixed now I think.
  8. tarabell
    tarabell Well-Known Member
    wowsers, signature works!
  9. krousdb
    krousdb Defiant NX-74205
    Um, sorry to break you streak of 12 hours of bug free signatures, but mine just broke again. Last night when I added my last tank, the signature updated to 55 and change. Today it is back to 54 and change, although the mileage log shows the correct 55+ number.
    Looks like another bug to squish!
  10. tbaleno
    Shows 55 here.
  11. krousdb
    Huh? Where. When I look at my posts, all the sigs are at 54. Maybe I have a bad cookie?
    EDIT: The sig should 55.341 MPG. The sig just below this line shows 54.63 MPG. Correct?
    EDIT Again: Now it shows correctly.
  12. tbaleno
    Did you do anything or did it just start showing correctly?
  13. krousdb
    After the last post it was wrong. After the first edit it it started working.
