Okay. first, ignore the raise line. That was just debuging text I forgot to take out. Second I think I'm on to what the problem is. give me a day or so (probably a few hours) and I'll see if I can't fix it.
You should be able to delete your cars now. Let me know if more issues pop up. I still have to work on the name getting reset when you change the car type using drop downs, but its on the list.
Hi Tom: ___You are becoming a hot coder real quick, did you know that? It wasn’t 5 weeks ago and you had never coded at all IIRC! Hot **** ___Good Luck ___Wayne
Tom - that change is good - I have now deleted the extraneous cars. One thing you'll need to clean that up further - when you flag the car for 'delete', and then click the 'send' (submit) button, the following page loads: http://www.cleanmpg.com/garage/garage_insert.php However, since we're not 'inserting', but deleting, there's no record to post, so the page comes up blank. The more 'elegant' way would be to repost the main db page form, showing the owner's car at the top, with the break and the other people's cars - in other words, this page: http://www.cleanmpg.com/index.php?page=garage So this is your first try at this, eh ? Pretty good...pretty good. Debugging can get frustrating at times - but if you take the approach that it's like solving a puzzle - it can feel especially rewarding when you finally figure out a difficult problem Thanks for getting to this so quickly... Mark
The reason it goes to a blank page is because the blank page is actualy a script. It's just that the script doesn't display anything. I guess I could put up something saying that your car was modified or something. Doesn't it automaticaly dump you to the main page after a second or two? It is supposed to do that.
I dont see an image when I look at my vehicle record. Just a red X. I figured out that my car is #57 so I copied your link, changed from 59 to 57 and changed the brackets. Still I get the red x. The first sig you see is my fake sig. Underneath is supposed to be the real sig but just the red x for now. I think it is a conspiracy. First, the dropdown list only goes to 1998. Now this. Are you guys trying to tell me something?
I'm in the same boat. On the other hand, I did manage to wrap tags around my red box to make it link to my gaslog :)
Here's the code if anybody wants an easy cut&paste. Just replace my car number 56 with your own in both places and remove the two spaces in [/IMG ] and [/URL ] that I placed there to break it for viewing.
hmm. sumptin' ain't right with the figgerin' to get your data into a image in the first place. dunno- I'm a hardware guy for a reason.
Wohoo! Tbaleno, did you do it or did I do it? I just made a small change to my database and it worked. I went into my gaslog and started looking for things that might confuse it. I found that in only one tank I used an entry of "10" for average trip length. I reset that value to the default, saved, and my mileage signature magically popped up!
I did "stuff". You were such an old user some of the stuff that is automaticaly set up for new users wasn't set up for you. I had to add that to your profile.
I added my Silk Shorts and that one works. My guess is that if you can't pick your car via the pull down menus, the sig won't work.
Might have another one for you, Tom. Started adding tanks tonight, and noticed that I can't add more than 5 tanks under a 'non-default' profile (strategy). Looked at the others with multiple tanks entered and saw they had just used the 'default' - I don't know if that has something to do with it ?
Well, I think I found another database "easter egg" for you. I entered a tank this evening and it showed up just fine. I then went to edit it to add a note, at which point I saved it. But now the tank doesn't show up in the database for some reason. I know that it's in there somewhere because the improvement in my LMPG is reflected in the calculation for my sig. Kinda strange. I guess I shouldn't complain because it wasn't that great of a tank, anyway
I have no doubt you'll squash it. If it makes you feel any better I know how aggravating it is to debug software. I've spent many an hour doing the same thing at the office. Your dedication is tremendously appreciated! Let me know if there's anything I can do to help.
I just realized a couple of my tanks also disappeared, probably when I edited them a few days ago. I added them back in, but my signature still doesn't seem to appear in the tank.
I think I squished the bug. I'll look at your signature issue tarabell. It seems to exist now. Maybe it fixed itself or something. just put this in your signature (img)http://www.cleanmpg.com/garage/images/55.png(/img) replace () with []
