No plug. It is a gas car. The energy to accelerate comes from gasoline, and the energy stored in the battery comes from gasoline, minus conversion losses.
U would think they could put in a simple trickle charger for not too much money! My battery is nearly full after running around the block a few times forcing motor only. I want to get a trip soon with no regen/full battery. That is when my insight really gets into its stride.
Ok question: does this like the insight store life time mpgs somewhere? I've been scrolling thru the menus and have not seen it
My current plan for lifetime mpg is as someone else posted... I'm leaving the "B" tripmeter untouched, allowing accumulated mileage and MPG to be seen.
I used the trip B trick for a while, until some other driver reset it. Too difficult to maintain for a year or two, let alone for the life of the car. Cheers, Bill
Anyone else have trouble with the Prius c sneaking back into ev mode when cruising on 25 and 30mph stretches after ur at speed? Every now and then I look down and I'm like damnit get out of ev!!! Would turning off Eco mode help?
Your gas pedal controls that. If it does not need ICE power, it will shut it down by design. You may want to glide, which means just enough gas pedal to remove regen braking. Then pulse back up with the ICE. Or, just let it do its thing and enjoy great mileage.
What ksstathead said... Given your car is going into EV because your current speed and motive requirements fall below the threshold of a running engine, you have the choice of speeding up or coasting. Assuming your surrounding traffic can allow the pulse and glide, I'm afraid that's the best you can do. The issue of how to stay out of EV mode is the million dollar question for most drivers of hybrid electric vehicles, and plug-ins too. Good luck! Bill
Thanks that helps, I'm not used to being on pure ev when cruising at 25-30. 2006 insight only used the electric motor to assist on start, and was easy to keep out of boost once past 20-25mph
How would u compare on clear roads the mpg from say 90F say 30F? In the insight u could see 10mpg differences. The insight really likes it hot! So how does the Prius C act?
The C is going to be better in the cold. The Toyota EGR system on the C was made to get up to temps faster and I only see 4-5 mpg drop in the cold over summer.
Haha! We can hit 40s here in the winter which is VERY cold for me. Here is a tech data improvements over the 3G Prius on cold start heating. Exhaust Heat Recirculation used to heat engine coolant 1) Newly designed heat exchanger a) More efficient fin-type heat exchanger b) Provides improved cold-weather performance 2) Reduces time for coolant to reach operating temperature a) Shortens time until gasoline engine can stop 3) Improves heater performance a) Reduces time to warm air by 1 minute
I have notice the C come up to temp generally within 3 blocks. Much faster than the Honda insight. So what is the best color for a Prius c? Hahaha this will be something that sparks debate
Three blocks !?! - Even in summer time in the morning (when it's relatively cool) my 2010 Fusion hybrid takes a couple miles of city driving (no HVAC use) to fully warm up
Maybe three blocks of full-throttle driving would bring it right up there , eh ? Mine takes about three miles.
