Found an HX for the mechanically inclined
Discussion in 'For-Sale/Wanted' started by jcp123, Jan 13, 2012.
  1. jcp123
    jcp123 Caliente!
  2. 08EscapeHybrid
    08EscapeHybrid Moderator
    $1,200 for a car that doesn't even run?
  3. jcp123
    jcp123 Caliente!
    Head gasket is about a 6 hour job, max, if you have all the tools and parts ready. If the battery isn't sulfated, then a slow charge is in order and makes it not such a bad price. I agree it's not worth it though if you're taking it to a shop. Hence why I say it's best for the mechanically inclined :)
  4. 08EscapeHybrid
    Unless I'm purchasing an antique/classic vehicle, I think about $500 is my limit for vehicles that don't run.
  5. msirach
    I believe this is in Andrew's back yard. He needs this one.
  6. PaleMelanesian
    :p That is in my backyard. It's almost tempting, just for the transmission. It's certainly less work than that Insight that popped up last week in Dallas.
    However, my '96 is 2 years older and has 13,000 more miles on it, but is in better shape.
  7. diamondlarry
    Doooo iiiiiiit! You know you wanna!:D Seriously though, with the taller gearing I'd bet your numbers would reach higher into the stratosphere than they already are.
  8. Right Lane Cruiser
    Two things about that:
    First, the higher gearing will really only help on the highway. Lower gear P&G wins over higher gear steady state at lower speeds.
    Second, lean burn makes tracking mileage difficult at best unless you have a built in gauge -- the ScanGauge is worthless for measuring fuel usage with variable A/F ratio. He'd have to wire in an MPGuino to get accurate info.
    But hey, I don't doubt Andrew could do incredible things with an HX. ;)
  9. PaleMelanesian
    Both true. With the speeds on my routes, I'm often using 4th gear instead of 5th. It would help on the highway, but my car is almost entirely a commuter. My car ain't broke (well, mostly not ;)), so I don't need to fix it.
  10. msirach
    Offer $600 and put it in your backyard.:rolleyes:
  11. PaleMelanesian
    Also, I wonder if it's really an HX. The only clue we might have from these pictures is the wheels, and they're wrong. It should have the ultra-lightweight alloys (like below), but instead it has steel and hubcaps.
