Scangauge on FFH - Can't read SOC?
Discussion in 'Ford Hybrids' started by turbotaguy, May 22, 2011.
  1. HybridHT
    HybridHT Member
    Thank You Carl D ...!!!!! :)
    They all work on my 2011 Lincoln MKZ Hbrid...
    I am so happy , because these codes are so hard to get...
    If you have more let us know.
    I will be glad to check them on my MKZh, which is the same as the Fusion.
    Thanks Again...!!!! :flag:
  2. CarlD
    CarlD Well-Known Member
    Here is an xgauge that can be checked to see if the FEH is in a battery re-balance state if odd behavior is noticed:
    TXD: 07E4224818
    RXF: 046215480618
    RXD: 3008
    MTH: 000100010000
    NAM: BAL
    This table shows what the display means for this xgauge:
    01 Rebalance in progress
    02 Rebalance completed successfully
    03 Rebalance aborted - battery fault
    04 Rebalance initializing
    05 Rebalance aborted by vehicle
    06 Rebalance aborted upon request
    07 Rebalance aborted due to battery temp out of range
    08 Rebalance can't be started due to battery fault
    09 Rebalance can't be started - vehicle did not allow
    0A Rebalance can't be started due to battery temp out of range
    0B Rebalance suspended
    0C Rebalance can't be started - maintenance mode in progress
    0D Rebalance can't be started - too many attempts
    0E Rebalance aborted - tester no longer present
  3. CarlD
    Adding to the list...these probably will work for the C-Max hybrid also
    HV Battery State-of-Charge: units %
    TXD:07E4224801
    RXF: 046245480601
    RXD: 3010
    MTH: 000100050000
    NAM: SoC
    HV Battery Voltage: units Volts
    TXD: 07E422480D
    RXF: 04624548060D
    RXD: 3010
    MTH: 000100010000
    NAM: HVB
    HV Battery Temp: units degrees F
    TXD: 07E4224800
    RXF: 046285480600
    RXD:3008
    MTH: 00120001FDBC
    NAM: BaT
    Maximum Discharge Power Limit: units kW
    TXD: 07E4224815
    RXF: 046245480615
    RXD: 3008
    MTH: 001900010000
    NAM: MxD
    Maximum Charge Power Limit: units kW
    TXD: 07E4224816
    RXF: 046245480616
    RXD: 3008
    MTH: 001900010000
    NAM: MxC
    Average Battery Module Voltage: units Volts
    TXD: 07E4224841
    RXF: 046245480641
    RXD:3010
    MTH: 0001000A0000
    NAM: AvM
    Inside Car Temp: units degrees F
    TXD: 07E422DD04
    RXF: 046285DD0604
    RXD: 3008
    MTH: 00120001FE70
    NAM: InT
    Battery Age: units months
    TXD: 07E4224810
    RXF: 046285480610
    RXD: 3010
    MTH: 000100140000
    NAM: age
    Interested to see how battery age compares with the actual age of the vehicle......
    Transmission Temp: units degrees F
    TXD: 07E1221E1C
    RXF: 0462851E061C
    RXD: 3010
    MTH: 000900080140
    NAM: TFT
    HV Current: units amps
    TXD: 07E122480B
    RXF: 04628548060B
    RXD: 3010
    MTH: 000100050000
    NAM: AMP
    Motor Electronics Coolant Temp: units degrees F
    TXD: 07E1224832
    RXF: 046285480632
    RXD: 3008
    MTH: 001200010140
    NAM: MeT
    Engine run time: units minutes
    TXD: 07E122F41F
    RXF: 046245F4061F
    RXD: 3010
    MTH: 001900100000
    NAM: TmE
    Generator Inverter Temp: units degrees F
    TXD: 07E122481E
    RXF: 04628548061E
    RXD: 3010
    MTH: 00120001140
    NAM: GnT
    Motor Inverter Temp: units degrees F
    TXD: 07E1224824
    RXF: 046285480624
    RXD: 3010
    MTH: 001200010140
    NAM: MoT
  4. SD3_Driver
    SD3_Driver Well-Known Member
    Nice, will give a shot to run time and trans temp.....:):)
