A full-on Sport BEM – Including regenerative braking from a college student
Discussion in 'Street and Performance Bikes' started by xcel, Sep 13, 2009.
    [​IMG] The Li-Ion pack appears a little sparse to achieve stated specs but it works and looks great!
    [fflash=left]http://www.youtube.com/v/os9Vna0XH4s&hl=en&fs=1[/fflash]Wayne Gerdes - CleanMPG - Sept. 13, 2009
    Ninja Ion - BEM-60 (Battery Electric Motorcycle)
    Meet Tom Miceli and his super hot BEM Sport bike called Ion.
    Miceli’s $12,000 Ion consists of a ‘96 Kawasaki ZX6 Ninja chassis, a LiPO pack using two dozen 40 Ah cels in a series/parallel arrangement w/ a 72 V output and a total cap of approximately 3 kWh. The bikes AC motor is a 6.75-inch unit with 95 lb-ft. of peak torque. The latest iteration is “supposedly” capable of more than 70 mph with an AER of 60 miles.
    To save on accessory loads, the Ion includes a custom LED headlight, taillight and turn signals drawing less than 12 W in total!
    The fly in the ointment? 3 kWh with a DoD of maybe 80% MAX yields 2.4 kWh. 2400 Wh/60 miles = 40 Wh/mile. That seems a bit low for a bike with rider weighing in around 550 pounds and the aerodynamics of a brick while riding in an upright position? Then again, with a very efficient transverter and controller, the bike and rider weight about 1/6 that of a Prius (typically rated at around 250 Wh/mile when under electric propulsion), 40 Wh/mile may be possible?
    Miclei’s next upgrade will include larger 60Ah batteries and a custom-made, two-speed transmission :D
    With a bike like this on his first time out, we can expect to hear much more about Tom in the future and I for one am looking forward to that next project whatever it is ;)
    For more details on Tom’s creation, check out the Wired Article entitled A DIY Electric Motorcycle Kawasaki Should Build
    Building the Ion
    A high quality hand built fairing fabrication but notice the GUI screen (not fired up) in the later stages of the vid? I wonder what Tom has displayed :)
    [flash]http://www.youtube.com/v/RUfYkvSPldI&hl=en&fs=1[/flash]
  2. antrey
    antrey Well-Known Member
    This is a gorgeous conversion! Aesthetically it is much more ambitious than mine will be. I'm documenting my conversion of a 1986 Honda VF500 on blogger: http://voltagefueled.blogspot.com
    I will be using a less powerful motor (as expected from a hypermiler ;)) and a longer range capable lithium iron phosphate pack. Solar photovoltaic panels will help add a bit of range but it will take me a while to integrate the PV panels since solar charging solutions for lithium packs are currently limited.
