YAW Stability Control-'08 FEH
Discussion in 'Ford Hybrids' started by GaryG, Sep 30, 2006.
  1. GaryG
    GaryG Well-Known Member
    Hi All
    Looks like Ford has came up with a way to incorpoate yaw stability control to work with regen. Hope the system is at least standard equipment on the '08 FEH and MMH's.
    The present invention is a method and system to control regenerative braking during the operation of a yaw stability control system. The method and system use feedback control algorithms to monitor and dynamically modify regenerative and non-regenerative braking. The controller can use a simple proportional-integral-derivative feedback controller. A vehicle yaw stability control system can determine if a vehicle is experiencing an oversteer or understeer condition. The controller compares actual brake balance to a desired brake balance. The controller determines if the front axle wheels are overbraked relative to the rear axle wheels or if the rear axle wheels are overbraked relative to the front axle wheels as compared to the desired brake balance. The controller can adjust regenerative braking and non-regenerative braking levels according to the determinations.
    For those who are interested, here is the patent:
    http://www.freepatentsonline.com/7093912.html
    GaryG
