| General General HW modding questions and answer discussions here. |
Solar hood?
04-10-2008, 08:33 PM
Vehicles: 2008 Toyota Prius
Solar hood?
Perhaps a totally nutty idea, but I thought I would mention it... Part of my job is new ideas and once in a while I hit on something that works out. Just have to keep trying. I am told Ted Turner has a 90% failure rate....
I recently saw a story on solar cookers on the TV and was wondering if something like that could be adapted to keep the engine warm.
The premise is to take a hood, cut openings into it, inset clear plastic into the cutouts, then color the top of the insulator black (or replace it?) to see if it would keep the engine compartment warmer than say a painted black hood. The hood on a Prius appears to have an air space of about 1.5 inches or so.
If it would work, all sorts of interesting custom designs could be used.
If anyone thinks it is feasible, let me know I can can work on a prototype. We have a fiberglass division in our company and they have built carbon fiber hoods before. I do a fair amount of designing for laser burnounts and I could come up with something for a metal version.
04-10-2008, 09:11 PM
Vehicles: 07 yaris, 93 Camaro
Re: Solar hood?
I don't follow your description of the hood, but by all means, if you have the resources and idea why not try it?
However, with a solar cooker the sun's rays are reflected from many angles to one common point to heat the food. This would prove to be very difficult if you were trying to heat an engine I would imagine, not to mention you would have to park with the hood facing the sun for it to work.
PS, I'm sure that the people that are trying to keep their engines warm for MPG purposes wouldn't mind that their hood was lighter (CF or glass) as opposed to metal
-Aaron
 <---Daily driver
 <---Off to new home
 <---Driveway decoration
04-11-2008, 01:16 AM
Re: Solar hood?
I'm not too sure what the point of this is, just to minimize warmup time? I guess this sounds kinda like that solar heater thing I built over the winter, but inside an engine bay instead.
Anyways seems like you might have issues with the clear plastic getting too hot while the car's running.
-Justin
04-11-2008, 08:56 AM
Beat The System
Re: Solar hood?
What about a black hood, with copper pipe running back and forth, also painted black (maybe on the underside?). Feed the loop of piping through the cooling system. It'll preheat the coolant.
Andrew
04-11-2008, 09:52 AM
Re: Solar hood?
Sounds like an idea that could work Andrew...
Problem is, shiny parts reflect sunlight. You'd have to go like dull flat black for maximum effect.
Don't think that would be a popular look.
It seems like on sunny days it's hot under the hood even when the engine hasn't been running!
Ben
04-11-2008, 09:58 AM
Beat The System
Re: Solar hood?
Not a popular look? It's just like all the ricers do with their "carbon fiber" hoods - except not so shiny.
What about just making the underside of the hood shiny, to keep the heat in better?
Andrew
04-11-2008, 12:40 PM
Vehicles: HyHi 2007 2WD
Re: Solar hood?
Don't forget...that extra weight will hurt economy. The easiest thing would be just to keep your hood in the sun and have it painted a dark color. A step up would be to add insulation around the sides of the engine compartment to keep that heat in.
Jonathan
 Eagles may fly, but weasels don't get sucked into jet engines (with 1 known exception)
04-11-2008, 01:32 PM
Celtic MPG Warrior
Vehicles: 2004 Toyota Yaris 1.4D4D, 2008 Kia Cee'd sw 1.6crdi
Re: Solar hood?
Apart from the extra weight, i love this idea! To advance this idea, what do you think about this: Remove the radiator and re-plumb the coolant pipes to the new under/in-bonnet solar collector and it becomes a super aerodynamic radiator!
Then you can grill block to your hearts content, ie: block completely, go as aero as possible.
With good design, the heat loss through the bonnet panel would be enough to stabilise engine temps and would heat the engine a little when parked in the sun. I've thought of this before but it seemed a little odd so i said nothing.
ollie
04-11-2008, 01:35 PM
"How's your mileage?"
Vehicles: 2002 CR-V, 1953 chevrolet 150
Re: Solar hood?
Definitely wouldn't want to be looking out over score of tiny discoball mirrors on your hood while trying to drive. The flat black idea is good though. This time of year I deliberately park so the hood is in the sun, and it sits like that all day. I don't know if it makes any difference or not but the afternoon warmup hit is minimal compared to the morning.
-Tom
Since the SGII:
04-11-2008, 01:49 PM
Beat The System
Re: Solar hood?
I'm talking about foil or discoball mirrors on the underside of a black hood. The heat gets in, but then it can't get back out.
Andrew
