Go Back   CleanMPG Forums » Information » Fuel
Fuel Gasoline, Diesel, and Renewable fuel(s)
Does premium fuel = better MPG?
Tags: , ,
Old 04-10-2008, 10:19 AM
99BlueBlazer 99BlueBlazer is offline
Vehicles: 1999 Chevy Blazer 4x4
Does premium fuel (which obviously cost more) have any mileage savings compaired to regular unleaded? Other than the "octane" ratings I dont really know what is different between the quality levels of gasoline.
Old 04-10-2008, 10:24 AM
toastblows toastblows is offline
Vehicles: 03 VW Jetta TDI, 05 Honda Civic Ex, 07 Honda Ruckus
Re: Does premium fuel = better MPG?
no, use what owners manual says to use
Old 04-10-2008, 11:10 AM
Right Lane Cruiser's Avatar
Penguin of Notagascar
Higher octane just has more additives to prevent pre-detonation (aka "pinging"). Because of that it actually has a lower energy density than regular gas (which doesn't have as many additives). For a car rated for regular gas, premium fuel will get you worse mileage (by a little). For a vehicle rated for premium fuel, most will "detune" a bit to accommodate lower octane fuel without "pinging." That can often have a FE hit associated with it.
In short, if you car does not call for premium fuel, don't use it. You'd just waste your money.
- Sean
New? Start here!
Old 04-10-2008, 01:53 PM
warthog1984 warthog1984 is offline
Quick answer-
Fuel grades that have different octane ratings are totally different beasts in how they ignite and expand in the engine. The best mileage will be using the fuel YOUR engine is tuned for. Otherwise your just wasting gas.
Old 04-10-2008, 01:57 PM
BailOut's Avatar
BailOut BailOut is offline
My favorite holiday is Earth Day!
Vehicles: 2007 Toyota Yaris Liftback
I did my own experiment of 3 tanks each of 89 and 93 octane (my engine is rated for 87). I lost 4% of my MPG on 89 and 9% on 93.
- Brian
My commute
Share the Road
Old 04-10-2008, 02:01 PM
High compression ratios need higher octane to boost performance. Most cars are 86 octane min, and most min gas stations are 87. 87 will do you just fine. Even 85.5 they make in montana will work, has a nice ping to it
Old 04-10-2008, 02:10 PM
PaleMelanesian's Avatar
Beat the System
At higher elevation, you can get away with lower octane without knocking. That's why places like Montana and from personal experience, Flagstaff can get away with selling it.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 04-10-2008, 02:42 PM
Shrek's Avatar
Shrek Shrek is offline
Kaizen Driver
Vehicles: 2002 Toyota Corolla Verso 1.6 VVT-i Manual
Try to figure out what your engines compression ratio is. My toyota engine has 10.5:1, and would require high octane if it was not for advanced engine technology.
So it will run OK on regular, but with high-octane I have a huge boost on below 2000 rpm torque which help me a lot to get high mileage with manual gearbox.
Low octane fuel burn faster, but that really is only a problem with high-rpm situations. For a hypermiler it is very beneficial to trot along at 1500 rpm and high gear-high load without the engine whasting 50% of the energy because of anti-knock safety kicking in.
If I fill low-octane fuel I can feel an annoying dip in the moment curve at around 2700 rpm.
Old 04-10-2008, 02:48 PM
diamondlarry's Avatar
Super MPG Man/god :D
I just wanted to add my $.02 worth to everyone else comments and say that premium will only give better FE in an engine that is tuned for it. You will get the best FE with the octane the car was designed for. In older vehicles, the lowest octane you can find that won't cause pinging will get the best FE. I would be curious to see what would happen if I could put 85 octane or less in my Prius.
Old 04-10-2008, 03:09 PM
xcel's Avatar
xcel xcel is offline
___Let me add to Larry’s post. The MDX spec’s “Premium Recommended” and unless you are laying into it for the IGN to back off due to the KS, Premium is an absolute waste as regular unleaded will allow her 30 + on the highway at most any time of the year. My experience with regular unleaded in the MDX anyway?
Fuel Economy: Then and Now. xcel In the News 13 03-31-2007 09:47 AM
DCX Chairman Dieter Zetsche Urges Americans to Rethink Diesel. xcel In the News 0 01-23-2007 06:03 PM
Fed, State, and Corporate hybrid purchase incentives. Yesterday, today, and tomorrow. xcel Articles 2 12-04-2006 10:17 AM
Trucks hurt fuel economy. xcel In the News 1 11-14-2006 10:37 AM
