Go Back   CleanMPG Forums » Conventional Automobile Owners Community » Honda
Honda The Power of Dreams - Discussion about Honda and Honda automobiles.
Gear ratios - 2007 Fit vs 1996 Civic
Old 03-24-2008, 01:25 PM
PaleMelanesian's Avatar
Beat The System
The Fit has been widely criticized as being geared too low. The result being it runs at high rpm at highway speed. Sometimes called a "buzz-bomb".
2007 Honda Fit
5th gear - 0.757
Final drive - 4.294
Then I looked up my 1996 Civic.
5th gear - 0.700
Final drive - 4.25
So this means I'm driving a buzz-bomb as well! The Fit's 1.5 engine has almost identical output to my 1.6 non-vtec, both in peak numbers / rpm and when comparing the dyno charts. They're also rated for the same mileage: 33 / 38.
It's not usually an issue for my normal driving - my routes are 55mph max. But on the interstate, where 70mph = 3200 rpm, HS-P&G becomes the only option for good mileage.
Andrew
Old 03-24-2008, 01:36 PM
shifty35's Avatar
shifty35 shifty35 is offline
Re: Gear ratios - 2007 Fit vs 1996 Civic
3k RPM is the Civic's favorite rpm for steady state FE.
The Fit has a shorter 5th gear and a shorter final makes the overall shorter than yours.
Fit: 55 mph = 2784 RPM, 70 mph = 3408 RPM
Civic DX: 55 mph = 2578 RPM, 70 mph = 3243 RPM
You're going roughly 5 mph faster at the same RPM.
I wouldn't call the DX transmission a buzz bomb at all. Try the CX/VX transmission, which is roughly the same as the Insight's...
Granted, I tossed the DX trans in my old Civic for an EX one... now *that* is a buzz bomb.
Don't even get me started on the DOHC B16 / 99-00 Civic SI 5th and final! Something like 4.5-4.7k rpm at 60 mph...
Ben
Old 03-24-2008, 01:41 PM
Beat The System
Ha! You're right. For the 96-00 series, I've probably got one of the best transmissions.
But why do they do this? If you want to run 4.5k rpm on the highway, you can always use 4th gear, right?!!!
Andrew
Old 03-24-2008, 01:42 PM
xcel's Avatar
xcel xcel is offline
Hi Andrew:
___Your DX might even be worse The calc’s to find RPM at 60 include the diameter of the tires. The Fit w/ a stick uses 175/65/R15’s with a diameter of 23.0” (Circumference of 6.0214 ft.) and an RPM at 60 mph of 2,850
___The formula for R’s at a given mph as follows: [(mph) * (fifth gear ratio) * (final drive ratio) * (88)]/(tire circumference)
___Others of note …
07 Corolla w/ a stick: 2,305
07 Yaris w/ a stick: 2,660
08 Smart ForTwo: 2,857
Old 03-24-2008, 01:46 PM
Beat The System
Oooooh! Didn't think of that. I have 175/70/13's.
That 3200 at 70 is my observed actual rpm. Calc'd by your formula is 3093. About the difference I've observed between speedo / odo and reality.
Andrew
Old 03-24-2008, 01:56 PM
xcel's Avatar
Hi Andrew:
___You drive less of a buzz bomb than the current generation Fit …
My spread sheet pulled a 2,654 RPM at 60 mph for your DX w/ a stick:
Tire diameter of 22.6” (circumference of 5.91’) - 60 mph - fifth gear ratio of .700 - final drive of 4.25 yields 2,654 RPM.
Old 03-24-2008, 02:01 PM
Beat The System
That sounds about right. The point here is that Honda's ridiculous gear ratios is not a new problem.
It's not a terrible problem for me, given that I don't drive that fast. It also means that if I was to acquire a Fit, it would work for me in a similar way to what my civic does.
Andrew
Old 03-24-2008, 05:44 PM
-mr. bill -mr. bill is offline
Vehicles: 2006 Honda Civic Si
The point is "Honda's ridiculous gear ratios" has nothing to do with 0-60 times or quarter miles. Unless somebody thinks that a 1996 Civic DX was "tuned" by HoA for street racing.
-mr. bill
Old 03-24-2008, 06:05 PM
xcel's Avatar
Hi Mr. Bill:
___I sure wish I knew what it had to do with? Pulling a 1,000 # trailer at 60 mph possibly? Honda’s choice to run their smallest cars with relatively higher powered engines did not make any sense 3 years ago and it most certainly doesn’t make any sense today?
Old 03-24-2008, 06:29 PM
ksstathead's Avatar
Just bought a 2008 Honda Fit with the 5AT for my wife. First trip out, 2 hours at 70mph cruise control was 35.2 mpg (new EPA 27/33). Return trip no cruise control with 9 mph head wind was 35.5 mpg (speed high 60's average with a little DWL). I was fairly pleased with that. Edit: 452 ft elevation change, downhill with cruise, uphill on return trip.
But the 5AT's RPM at 70 mph ran 2585 to 2615 almost all the time, and quiet as a mouse. This is substantially lower RPM than my Tacoma or CRV, I think.
So, is the MT geared lower than the AT?
I like the 5 speed auto. It can be flat towed and it goes into fuel cut on most every decel in gear. Has paddle shifters which I hope can help reduce RPM in town by bumping up early. Also, I can induce fuel cut and save brake wear by decel with the tranny when I cannot coast or am coming in hot to a stop.
Congratulations CleanMPG Hypermilers! xcel Fuel Economy 116 02-18-2012 09:01 PM
CleanMPG Reviews the 2007 Honda Civic 2.2L iCDTi Turbo Diesel xcel Reviews 31 07-21-2011 12:57 PM
2007 Honda Fit Long-Term Update No.5/ With-Pics: tigerhonaker Honda 23 10-05-2008 04:34 PM
Honda Fit is small yet practical tigerhonaker Honda 0 08-11-2006 06:01 PM
Honda FIT and Ready To Go -*** VIDEO ENHANCED STORY ***Great Article tigerhonaker Honda 1 04-04-2006 03:29 AM
