Re: MySQL error when I try to add a vehicle
I was finally able to add it, but only by creating a vehicle of the default vehicle type (an Acura, I think) and then editing it after the fact.
I should also point out that when the MySQL error occurs, it shows the error in Opera and then immediately takes me back to the garage page, but without my new vehicle listed. In IE6, it doesn't even show the error at all.
Also, if I keep the "Transmision" field blank, when I go to edit it again, it will put "Auto(L5)" back into that field. My electric vehicle doesn't have a transmission.
Also, "Transmision" is misspelled.
Also, I had to manually calculate my energy usage in gasoline-equivalent gallons because otherwise the MPG would show up as "0". For the calculation, I used 1 gallon of gasoline equals 121 MJ or 33.6 kWh of energy.
