Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
Scangauge II fuel cut off seems to work very well
Tags: , , ,
  #51   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-28-2008, 04:58 PM
2way 2way is offline
Electromagnetic Wave [:-h
Vehicles: 2002 Toyota Celica GT-S/6 1996 Toyota Avalon XLS
Re: Scangauge II fuel cut off seems to work very well
The cutoff is to indicate to the ScanGauge that you are in DFCO and the injectors are shut off. When this happens and cutoff is set correctly, the ScanGauge will read 9999 on the iFCD and GPH goes to 0.
  #52   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-29-2008, 09:22 AM
racefan racefan is offline
I have a 2004 Nissan Frontier and I know from the service manual that it states there is a fuel cutoff on decelleration. That said the TPS is 0 at idle. What happens if I simply de-activate the Fuel Cut-off feature? I do not want inaccurate readings. Any suggestions with regards to my truck? BTW it's an auto. Thanks in advance.
  #53   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-29-2008, 01:57 PM
Set the cutoff to 1. I'm not sure on what it does for accuracy.... but, it helps if you want to take advantage of DFCO.
  #54   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-29-2008, 02:09 PM
CarlD CarlD is offline
Vehicles: 2005 Ford Escape Hybrid
Idle TPS reading shouldn't be a problem since it will be closed loop except when initially warming up. Look at TPS and LP when coasting down in gear to get an idea of what value to choose. A setting of 1 will almost certainly never invoke fuel cut.
  #55   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-29-2008, 04:59 PM
Chris D.'s Avatar
Chris D. Chris D. is offline
I'll check the GPH to see what it sais when downshifting.. never thought of that DUH!
forgive me, I'm 1/2 n00bish on my fathers side
I'm using this one because I already know how to use it
  #56   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-29-2008, 08:12 PM
R E P U B L I C R E P U B L I C is offline
Vehicles: VW TDI Jetta 2006 NO BATTERIES NEEDED
A BIG Thank you to Wyane .. I got my scan gauge 2 about an hour & a half a go........
I am like a little kid at Christmas!~!!!!!!!1
Next time Wyane I'll pay the extra to go NON-usps!!!!!
Got it !!!!!Wyane & am real happy!!!!!!! 18th to the 29th.... maybe the
scan gauge had to go tru customs comeing into New Mexico (grin)
Thanks AGAIN
  #57   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 04-30-2008, 09:57 AM
Yes & no. If TPS is 0 at idle and indicates closed throttle, a setting of 1 should work just fine. As you say, the idea is that you want to know throttle closed & Open Loop. When set to 1, if you go below, it indicates a closed throttle (TPS=0). In one of my cases, idle TPS is 10 and my cutoff=11.
Beating the EPA - The Why’s and How to Hypermile xcel Articles 134 08-15-2012 08:57 PM
CleanMPG Reviews the ScanGauge II xcel Reviews 20 04-07-2010 12:16 AM
The Truth About Fuel Economy Ratings. xcel In the News 3 03-10-2006 03:44 PM
