Go Back   CleanMPG Forums » Conventional Automobile Owners Community » Honda
Honda The Power of Dreams - Discussion about Honda and Honda automobiles.
more DWL vs CC...
Tags:
Old 05-12-2006, 07:15 AM
gonavy gonavy is offline
Vehicles: 05 Accord hybrid...waiting for the Fusion
more DWL vs CC...
...at least as pertains to the HAH:
Many of you are familiar with my commute- 33 miles, all highway except for the 1st and last 2 miles. I drive off-peak, so congestion is virtually never an issue in any lane. There are several rolling hills of 50-100ft, usually 1/4 mile slopes, and then the usual over/underpass hills every few miles. Net altitude gain is +100ft for the AM drive.
All last sumemr as I was learning to drive efficiently I used DWL and neutral coasting on downhills, with a target speed of 60mph, minimum 53-55, max 65. I finally 'got it' around late July, also around when the car passed 5k miles, all broken in, and 1st oil change. My normal AM commute FE was 39-41, creeping up in the fall to 40-42.
During the winter I shifted away from DWL and began to use CC exclusively for the 29 highway miles, set at 60. Now that temps are ~same as they were last fall, an apples comparison shows me at 40-42. Actually, its more often between 41-43 the last month, with a few 44.0s as I hit my parking space. This is with CC.
The last few days I decided to try DWL for old times' sake. Yesterday: 42.0. Today: 41.5 (wet roads from overnight rain).
Moral of the story: in the HAH, CC is ~as effective as DWL for FE for those with consistent, relatively flat drives that don't require speed changes. The computers' fuel and cylinder management is at least as good as my foot's, and even better when you consider its holding speed on the uphills, yet still matching or beating my DWL results. Of course, I could be screwing up with my foot, too.
Old 05-12-2006, 09:23 AM
tbaleno tbaleno is offline
Re: more DWL vs CC...
That means you need to improve your DWL skills to match what the car is doing on the down hills. I recomend trying to press the gas just enought to kill regen on the downhils and staying in gear.
Try that out and let me know if it works for you.
Old 05-12-2006, 10:15 AM
Yes, I do need to work DWL skills.
I normally neutral coast on the downhills if I am DWL.
I'll try staying in gear to kill regen and see what happens. Not sure it works as well in the HAH- I should hook up the scangage again to see load and fuel usage/openloop/closeloop status if I am just touching the gas.
Old 05-12-2006, 11:00 AM
brick's Avatar
brick brick is offline
Retrograde Orbiter
Vehicles: 2009 Volvo V70
In theory it should work well. If you are running on six cylinders at idle but closing three and killing fuel injection while you hold the knife edge between regen and power, in theory you should see reduced losses as you descend at the same rate.
Tim
Old 05-12-2006, 07:12 PM
agreed.
I'm debating between trying that or simply driving at 55 instead of 60 now. I only change 1 variable at a time (I suck at solving multivariable differential equations).
I've sort of built up some intertia (complacency?) with me FE. Wayne would shoot me on sight! But watching his exploits the past days has re-motivated me to push the envelopes again- even in places I pushed earlier.
Adapting Basic Hypermiling Techniques to the HCH-II tarabell Articles 90 11-19-2010 09:29 PM
New personal best (short segment) brick The Daily Grind 18 06-19-2006 06:19 AM
