Blocking radiator - Help?
Old 09-17-2007, 08:52 AM
Dogarm's Avatar
Dogarm Dogarm is offline
Penmanship Champion
Vehicles: 2006 Civic Hybrid
Dear all,
Lacking the ability to use a block heater due to living in a condo, I am looking for the poor-man's method to keep the car a bit warmer in the winter. Others have mentioned blocking the front grill intake with cardboard. My question is, can someone please give me a bit of a walkthrough, as I don't want to mess the process up?
Any feedback would be appreciated, and pictures would be even better.
Cheers!
Dogarm '06 HCH II w/ Nav (& extra loyalty)
Old 09-17-2007, 10:49 AM
msantos's Avatar
msantos msantos is offline
Eco Accelerometrist
Re: Blocking radiator - Help?
How about this:
This is my wife's car... and mine is setup pretty much in the same way. Using foam pipe insulators (bought at Home depot for roughly 1 buck each) works very well and does not seem to change the overall look of the vehicle that much.
I used this approach in prior winters with good results.
Cheers;
MSantos
Old 09-17-2007, 10:54 AM
Bucko Bucko is offline
Vehicles: 2001 Chevy Prizm Manual 5 speed
That's a nice, simple and long lasting way to do it. Cardboard tends to turn into mush eventually.
PB Tank 702miles 11.03gal 63.6MPG
Old 09-17-2007, 10:57 AM
Dogarm's Avatar
Penmanship Champion
OK, I will find som of those insulator tubes. It looks like there is no need to even go under the hood for this mod - am I right? ANd then you just cut the ties in the spring and store the tubes until next fall! Thanks, msantos!
Old 09-17-2007, 11:41 AM
msantos's Avatar
Eco Accelerometrist
Yep. No need to go under the hood.
Once you cut and notch the tubes to fit they'll just go on easily, and you'll keep them for many years. I like this solution a lot since I can take out a tube or two to gradually match the actual temps... and like Bucko said, car washing in the winter is trouble free.
MSantos
Old 09-17-2007, 05:26 PM
Harold Harold is offline
Vehicles: HCH 2 / MX 5 Miata /06 Prius.
It apears that the lower grill is not completely blocked. Are you leaving about 20% open? H
Old 11-16-2008, 01:22 PM
Mendel Leisk's Avatar
Harold, the grill appearance is deceptive. The openings appear to go full width, but a closer look with pitlamp or flashlight shows a fair amount of the "openings" is actually blocked. It would be interesting to compare against a regular Civic: maybe they are blocked the same, or less?
Yesterday I tried a "West Coast" version of MSanto's suggestion. I put a single full length (maybe 4'?) of 3/4" dia foam pipe insulation, centered, in on our lowest grill section, with a zip tie at each end.
It's actually covering some of the pre-blocked grill, but the stuff is really cheap, I didn't want to bother cutting it shorter, it looked more symmetrical, is likely a bit more aerodynamic, etc., etc.
I don't have a ScanGuage, but a few days previous I made a point of monitoring coolant temp via Honda's display, noting where the bars peaked. It's fairly crude display, but I determined the bars consistantly peaked at the left edge of the "wave" icon on the display. I would think the coolant thermostat is responsible keeping this temp so constant, once the engine is warmed.
I put the single row grill block in last thing Friday night. My wife is the primary weekday driver, and I didn't want to do something iffy when she's using the car, potentially leaving her with a problem. Anyway, Saturday am with the grill block installed we had a protracted drive over to North Van, on freeway and local streets. I saw no change in the peak temps. And when getting to our destination. I made a point of letting the car idle in park for a bit, with all the ventilation and radio off. The cooling fan did not cycle, so I think we're good.
This is likely as much as I'll block, for now, considering our coastal climate, my lack of ScanGuage, etc. I think the car is a bit more comfy, the interior warming up a bit faster, and I believe this will help with the mileage, particularly short trip, around town. I'll post any further observations and/or revisions to amount blocked.
Old 11-16-2008, 01:46 PM
laurieaw's Avatar
laurieaw laurieaw is offline
Sorceress of the North
Vehicles: 2005 honda civic hybrid 5MT
good timing, i am about to go out and do mine today. i may just beat the snow.
laurie
best segment, 102.5MPG
Old 11-16-2008, 02:54 PM
groar's Avatar
groar groar is offline
X-Frenchy: very
Vehicles: Renault Mιgane 1.9dT 1997 (sold), Toyota Prius 2006
My car is light grey so using white coroplast and transparent tape is OK for me.
I blocked everything (lower and upper) except the 6th toward the turbo (my cars are turbo diesel) and the place under the hood. I constated :
  • the same temperature when the engine is hot.
  • the engine is hot quicker, but the temperature begins to increase a bit latter, may be because there is less air moving under the hood.
  • after a couple of hours engine off, it is hot only after a few kilometers when I restart it
Denis.
priceless:Earth,health,kilotank&AT-PZEV
1094.0mi@69.59(84.1/79.5/79.5/82.4)cur.goal=77.847mpgUS
1268.9mi@77.847
53mnth sav:
  • 5.7tonCO2
  • 42.17%=2446.25€=3357.26$
Old 12-03-2008, 10:29 PM
bdog bdog is offline
I've blocked mine using foam tubes and it seems to help, although the coldest we've got so far is about -5C. When it hits -20C I suspect it will help out quite a bit.
Getting the block heater put in tomorrow.. hopefully the dealer won`t gripe about the rad blocking
B
Grill blocking Dan Toyota 11 09-01-2007 09:31 PM
