ScanGaugeII Calibration Worksheet
Tags: ,
Old 06-21-2008, 05:40 PM
BrianWillan BrianWillan is offline
Vehicles: 1997 Saturn SL1
Re: ScanGaugeII Calibration Worksheet
Originally Posted by n3rdyguy View Post
Hi
Is it possible to make a version for us that uses litres/100km?
Just convert your liters/100km to km/liter and then use the spreadsheet as is. The spreadsheet is essentially unit independent. Meaning that it wouldn't really know the difference if you entered a km for miles or liters for gallons, as long as the units are consistent.
Cheers
Brian Willan
Oshawa, Ontario
Canada
Old 11-01-2008, 05:48 PM
jdhog's Avatar
jdhog jdhog is offline
Hyper Smiler
Vehicles: 09 Matrix, 91 Civic DX
This looks like useful info. I'm coming up to my first fill while having a SG so I'll be needing to read this again soon to help me calibrate it. Thanks!
'If you can meet with Triumph and Disaster and treat those two impostors just the same' Kipling
Old 11-30-2008, 06:34 PM
morfes morfes is offline
I have a question about how am I use this utility.
I go to the gas station and I fill up
I write down to a paper the data we need to fill the spreadsheet.
Then I need to go at my home to fill it so I should do some km. At the gas station I reset the data as you suggest at the spreadsheet without adjust anything.
I go home and the spreadsheet calculate for example that I need to adjust the fuel at the sg 4%.When should I adjust it? Because this moment the sg has already done some distance from the gas station to my home....
Old 11-30-2008, 10:33 PM
Dan's Avatar
Dan Dan is offline
KiloTanked in post 153451
Well I was carrying it on my cell phone so that solved your immediate problem.
Plus the spreadsheet will simply zero in on a calibration setting over multiple tanks. You can just follow one tank behind the spreadsheet if you like. Won't effect the math since I factor out whatever calibration you have set.
So plug in TankA get CalibA. When you fill TankB, set you calibration to CalibA, then go home and fill in your tank to get CalibB. When you fill TankC, set your calibration to CalibB.... One tank behind.
11011011
Dan <11011011>
Old 12-01-2008, 03:28 AM
11011011
Thank you very much for your answer , but I have a question more. Every time I fill up , I will use a new tank at the step 2? I mean tha I don't erase the previous data and should I write the new one so the spreadsheet calculate all of the fill ups?
Old 12-01-2008, 10:30 AM
Dan's Avatar
Dan Dan is offline
Yes, the top bold line of step 2 is the accumulated total. Add each tank into a blank row in step 2. This will sum all the tanks together to help get a very accurate picture of the required calibrations.
11011011
Dan <11011011>
Old 12-01-2008, 10:56 AM
11011011
Thank you again! I test it and I will post the results!
Old 12-01-2008, 12:29 PM
Showbizk's Avatar
Showbizk Showbizk is offline
Vehicles: 04 WRX Sport Wagon; 08 Hyundai Veracruz
The only problem I've had with this is by the time I get home after filling and make the spreadsheet entries to calibrate, I lose about 4 miles of data on the tank, since changing the calibration zeroes out other entries...
"It's crackers to slip a rozzer the dropsy in snide!"
...Bob
  #19   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 12-01-2008, 12:34 PM
PaleMelanesian's Avatar
Beat The System
Any time within the first gallon, you can change the offsets on the fly. Just go to fillup and adjust it, but don't hit save. Sure, the first 4 miles might be off by 1%, but that's not much.
Andrew
  #20   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 12-04-2008, 06:48 AM
But If I do that and not hit save , it doesn't save the offset...
Scangauge Tips and Tricks Dan ScanGauge 45 01-08-2009 09:47 PM
Scangauge Calibration krousdb ScanGauge 9 06-17-2007 07:04 AM
Scanguage calibration Dan Toyota 4 05-25-2007 02:32 PM
ScanGaugeII Mount frank@mgtmotorsports.com ScanGauge 2 03-10-2007 11:29 PM
Using the ScanGauge to assess pump calibration brick ScanGauge 2 09-07-2006 05:42 PM
