lowering a/c dial saves gas?
Old 08-24-2007, 08:31 AM
jkandell jkandell is offline
Does lowering the dial on the a/c (so more warm air gets mixed in) raise mpg?
Old 08-24-2007, 08:38 AM
johnf514's Avatar
johnf514 johnf514 is offline
Zoom? Try Glide!
Vehicles: Rally White 2007 Mazda3i Touring 5-speed
Re: lowering a/c dial saves gas?
Absolutely - the compressor runs less, therefore robbing less engine power and fuel.
Old 08-24-2007, 08:40 AM
psyshack's Avatar
psyshack psyshack is offline
Vehicles: Mazda, Honda, Ford
Nope,,, all your doing is mixing in warm air from the heater core. Slowing down the fan doesn't help either. Now if you have auto climate control. You might beable to set a temp and have the compressor kick off once temp is met. It all depends on how the system is built.
laurieaw's Avatar
laurieaw laurieaw is offline
Sorceress of the North
Vehicles: 2005 honda civic hybrid 5MT
definitely! on my HCH the dial reads in degrees, 62, 72, 82. when i put it just before the heat comes on, it does a fine job of cooling and taking humidity out of the car. setting it to 72 gives me frostbite, which i can get in the winter for free
laurie
best segment, 102.5MPG
Old 08-24-2007, 08:52 AM
johnf514's Avatar
Zoom? Try Glide!
You sure about that, psyshack? In every car I've owned, I can feel the AC compressor staying off for longer periods of time when the temperature gauge is on a warmer setting.
2007 Mz3
1999 Taurus
1999 Camaro
1989 Voyager
Old 08-24-2007, 08:55 AM
brick's Avatar
brick brick is offline
Retrograde Orbiter
Vehicles: 2009 Volvo V70
Psyshack hit it square-on: it depends on how the system is built. In order to see any benefits with the Accord (not automatic climate control) I had to manually turn off the A/C compressor. The knob was just an air mix that changed temperature at the vent. The Prius, on the other hand, uses an automatic system with a variable-speed compressor that only sucks enough power to meet demand. Increasing the temperature setting reduces the influx of heat to the cabin by virtue of a lower temp gradient which, in turn, makes it easier on the climate control system.
If you have automatic climate control you should be in good shape.
Tim
Old 08-24-2007, 08:59 AM
johnf514's Avatar
Zoom? Try Glide!
I must be off my mark then - none of my vehicles had climate control.
Consider my posts null and void.
Old 08-24-2007, 09:57 AM
laurieaw's Avatar
sorry, i guess i should have added mine does have an automatic setting, which i haven't really used much since i don't put the a/c on very often. that said, i did see a difference in how it ran based on the temp setting.
laurie
Old 08-24-2007, 10:27 AM
Dan's Avatar
Dan Dan is offline
KiloTanked in post 153451
Originally Posted by brick View Post
...The Prius, on the other hand, uses an automatic system with a variable-speed compressor that only sucks enough power to meet demand. Increasing the temperature setting reduces the influx of heat to the cabin by virtue of a lower temp gradient which, in turn, makes it easier on the climate control system.
Sweet, thanks for the insight.
11011011
Dan <11011011>
brucepick's Avatar
brucepick brucepick is offline
Vehicles: 1997 HONDA CIVIC HX Manual (M5), ScanGauge
My view on it is that you should feel or hear the compressor starting and stopping (unless it's a variable-speed compressor as above). In the a/c cars we've had in the past, we also could feel the difference in vent air temperature right after it started or stopped. You can use these observations to detect how your system is programmed.
I would think that the various makers, and various generations of systems over time, will have different names and setups. But if you can hear or feel it cycling on and off more or less often, that would tell you what's going on.
Quite likely many service techs will not know the answer to the question as their job is to fix it when it's broke, usually a matter of sealing leaks and adding refrigerant.
1997 HONDA CIVIC HX Manual (M5) ScanGauge, MPGuino, running 54 psi. Currently ~ 47 mpg avg (summer).
What America really thinks about high gas prices. xcel In the News 12 06-13-2008 08:24 AM
Teens Offer Tips for Saving Gas tarabell In the News 13 04-29-2008 03:27 PM
Texas natural gas field vital to U.S. supply. xcel In the News 3 08-31-2007 07:39 PM
Letting up on the gas. xcel In the News 5 04-02-2007 05:12 PM
Driving on gas - but not gasoline. xcel In the News 0 02-01-2007 12:28 PM
