Toyota's Prius-I, reaching for the hypermiler in all of us
Old 06-21-2007, 11:46 AM
xcel's Avatar
xcel xcel is offline
This wolf in sheep’s clothing can show all of us a thing or two.
2001 - 2003 Toyota Prius-I - higher end FE techniques.
http://www.cleanmpg.com/photos/data/523/Prius-I_-_Drivers_Side_Rear_Profile.jpg
Wayne Gerdes - CleanMPG - June 21, 2007
In terms of the 2001 - 2003 Prius-I’s Fuel Economy, she has near the same capabilities as that of her younger sibling, the Prius-II. With a less powerful overall system and less precise energy consumption mimic and SoC level, you only have to be a bit more cautious is all?
A Prius-I is quite capable of pegging all 30 minutes of the 5-minute bar consumption screen mimic while actually covering a decent distance but not without a very careful application of the accelerator under a relatively specific set of rules and driving on an almost completely unmolested roadway in terms of traffic and or road conditions. Just one impediment to a glide or having to EV a small hill causing your SoC to fall from full to half puts her 100 mpg + capability at risk. Although the Prius-I does not have the overall power, fuel economy capability or the ability to transition into and out of a given mode as seamlessly as her younger sibling, the Prius-II, she does have a key for FAS’ing to improve warm-up FE and a relatively large shift handle so as to place her in a pure Glide in Neutral when conditions allow … With the 100 mpg capability available, let us see what you can do under a variety of conditions to help improve your Prius-I’s fuel economy.
Prius-I setup. As with any vehicle, higher tire pressure to reduce rolling resistance, higher quality and lighter weight synthetic oil to reduce ICE friction, a clean air filter to reduce pumping losses, a swap out of the transmission fluid to the Prius-II’s WS-ATF to reduce gear mesh losses and an EBH (Electric Block Heater) to help bring up coolant temp quickly so as to help improve upon the warm-up hit will all help improve upon her capabilities tremendously. I did not swap out the tranny fluid or install an EBH for the week and a half I had with her but everything else was good to go.
Prius-I’s warm-up fuel economy hit. From the time you turn the key and shift into Drive, the Prius’-I’s ICE is only spinning to warm-up the coolant and CAT and/or force charge the pack while under a low load acceleration from dead cold. Load as displayed by the ScanGauge-II was down in the high 20 to high 30% range while forced charging occurred and I do not believe this range to be an efficient one with the ICE spinning at 1,250 - 1,350 RPM going nowhere. When first driving her off normally for a commute or segment from dead cold, it was not uncommon to see that segments mpg down in the high 30’s/low 40’s after any 2-mile distance from an initial starting point. This kind of Fuel economy from a compact automobile during warm-up was unacceptable. What was found to work reasonably well during the warm-up phase was to propel her to a speed between 20 and 30 mph via the pack while the ICE is performing its pre-programmed warm-up routine and FAS which entailed a shift to N, key her off and back on again to reboot and achieve a powerless glide all the way down to 0 mph. You must have an absolutely un-impeded path in front and from behind in which to glide back down to 0 mph because there is no way for you to start her back up and continue driving until you have come to a complete stop, placed her in Park, shut down and rebooted. On the second or third pulse, the ICE would begin propelling the Prius-I like normal as well as force charging the pack during the acceleration which is exactly what was needed at that point in time. This warm-up technique yielded upwards of 80 mpg, a SoC recovering from an initial half to full over a 2 - 3 mile distance and a coolant temperature at a minimum of 155 degrees F. This is the minimum temperature found for the Prius-I’s hybrid functions to operate seamlessly. I did not find a better way other then to install an EBH (Engine Block Heater). Again, the caveats to this warm-up FAS method are extreme so use it only in a subdivision or parking lot where you can actually come to a complete stop at a stop sign or other traffic impediment right after bringing her up to speed from dead cold. If propulsion power was needed for any reason, you are dead in the water with no place to go but off the road to a complete stop.
http://www.cleanmpg.com/photos/data/504/Prius_I_MFD_880_miles_-_79_0_mpg_-_pegged_5-minute_bars.jpg
Pulse and Glide. There are a few rules that should be considered whenever and wherever possible. Once the Prius-I is completely warmed up with coolant temps above a minimum 155 degrees F, she can transition from a pulse to a glide and back again relatively easily. The issues I experienced are trying to hold a pure glide (no arrows) from a top speed to a lower speed target, entering into an ICE-Off Glide before reaching 35 mph, finding a relatively efficient pulse rate and finally the poor resolution of the SoC mimic not allowing you to know where the actual SoC may lye. Now would be a good time to review the P&G plus Warp Stealth in the Prius II for maximum FE article. The Prius-I can be manipulated into the exact same modes using similar techniques for excellent FE but not with quite the same ease or high end results.
Gliding. Because a Glide is the key to optimizing FE in all vehicles, it is very important that a successful no-arrow glide be initiated and held until the lower speed target is reached in the Prius-I. Holding a no-arrow glide is not quite as easy as can be achieved in the Prius-II but with a quick transition to a no arrow glide per the mimic and a shift of the gear lever from D to N once you have reached 31 mph and heading down from the higher speed target, she will drop into a powerless Glide efficiently and with ease.
ICE-Off glide. This was a bit more frustrating. With a SoC showing either full or half and coolant temps well into the 180’s, sometimes her ICE would simply not shut down when entering into a glide. You could achieve a no-arrow glide but the ICE would continue to idle away consuming precious fuel for some unknown reason? In order to guarantee an ICE-Off glide each and every time, a minimum of 35 mph from the previous pulse or steady state operation must be reached. Once 35 was breached, an ICE-Off Glide was never an issue.
Pulse rates (Accelerations). In the Prius-II, some use the ScanGauge II’s tach or load while others use the OEM iFCD to gauge a particular Pulse rate. In the Prius-I, her ICE is power constrained on the top end by MG2 assisting at lower RPM’s and higher loads. Whenever I saw or felt this action help accelerate the Prius-I, her iFCD would drop into the high teens from 20 - 30 mph. The following mimic shows a pulse rate I would not suggest using under any acceleration scenario other then an emergency whether that be to reach a steady state cruise or during a P&G scenario.
NOT Recommended - Sub 20 mpg Pulse w/ little additional acceleration: Power from ICE and MGSets to both the wheels and the pack.
By easing back on the accelerator pedal just a touch once MG2 began to assist per the mimic above, you should achieve near the same acceleration rate (seat of the pants measurement) but with a 20 + mpg result vs. Sub-20’s like above thus leading to the success I feel many Prius-I owners can achieve for themselves. The standard Pulse (ICE to the wheels and through MG1 to the Pack) as seen below appeared to yield the best results in my week and half behind the wheel?
Highly Recommended - 20 + mpg pulse w/ a Full SoC: Power from ICE to Wheels and ICE to MG1 to the pack.
Poor resolution of the Prius-I SoC. As depicted in the pics below, the Prius-I displays the SoC as either Full or Half. We know the pack has a SoC range of almost 40% but with the simplistic Full/Half mimic provided, you do not have any idea as to what the actual SoC is and thus had to use EV very conservatively.
SoC Full -------------- SoC Half
With the above, the following technique whenever a slower speed range P&G scenario can be achieved should be considered. Starting from a Full SoC, accelerate to 20 mph under EV and ignite the ICE with a quick jab and return of the accelerator pedal. Use the proper pulse energy mimic as shown above to achieve a higher speed target of at least 35 mph. Let off and once Regen is seen, place her gear selector into N as your speed drops to 31 mph or below as the ICE is already shut down. Arrow free Glide down to 15 mph. Place the gear selector back into D, EV back up to 20 mph, re-engage the ICE and again pulse back up to at least 35 mph. Repeat the sequence except only glide down to 20 mph and immediately accelerate back up to 35 mph plus with no use of EV. Continue to use the 20 - 35 mph or higher Pulse and Glide range without any EV on the bottom end as long as possible. If you see the SoC mimic drop to ½, you may need to run the next two pulses up to maybe 37 to 40 mph to bring the SoC back to full and allow a more efficient pulse range afterwards. With the SoC at half, MG1 is drawing hard off the ICE during a Pulse thus preventing a 20 + mpg acceleration rate. If you see the half SoC mimic appear, it is best to Pulse to higher speeds at an even lower pulse rate so as to allow more time for MG1 to fill the pack back up as soon as possible. If you have a downhill section, you can use Regen to help bring the SoC back to full. Either way, you should attempt to bring her SoC back to full within 2 P&G cycles or your maximum FE success rate has been diminished severely
Lower speed highway. There was an interesting phenomenon that appeared between 48 - 52 mph after a long stretch of P&G that had me somewhat confused. Even today I am not sure the solution is completely sound? While traveling at speeds between 47 and 52 mph, I would sometimes see long bouts of 52 - 54 mpg as if running in a forced charge mode. A minute or two later, I would see the iFCD running at 110 - 112 mpg and the Energy mimic was showing full Assist when none was called for. This cycle would continue for quite some time after reaching the Interstate. If I sped up, the issue went away and so did the great 48 - 52 mph, 75 mpg highway fuel economy I tried to DWL and drop load off almost completely during what appeared to be a force charge to no avail. Nothing I did with the accelerator pedal to counteract the Forced Charge/Full Assist effects seemed to stop this cycle other then speeding up and loading the ICE up a lot harder then what I deemed appropriate and sacrificing FE in the process. After 10 - 20 miles, this cycle would usually disappear but either way, while it was happening; it was tough to maintain 75 + mpg no matter her speed. During a night shift drive, I noticed this issue subsided soon after I turned on the headlights. Again, I do not have a reason as to the why this should happen but it was rearing up with little input on my part. On the second to last day heading into work, I was running into this low load highway speed cycle yet again and decided to try using CC (Cruise Control). CC has never worked for maximizing FE in any other automobile I have ever been behind the wheel of but this full assist to forced charge cycle stopped almost immediately afterwards? I was able to maintain the iFCD in the 75 mpg range on the flats as well as see a number of 5-minute bars at 75 + mpg without any effort other then holding a very slow and low load speed while RR under CC. Whenever I would run a hill, I would dis-engage CC and speed up a touch coming into the trough, DWL up, Warp stealth down and re-engage CC as soon as my previous speed target was reached. I do not know why it worked but it did and that is all I cared about I have no idea as to the inner workings of the SoC algorithm but CC at 48 mph settled the cycle down and yielded darn good FE while traversing the flatter sections. Saying the Prius-I exceeded my expectations would be an understatement.
Heavy stop and crawl highway traffic conditions. This is where P&G’ing and/or EV’ing while DWB comes to play. With every slow down to 0 mph, a little regen from some distance away would bring her speed down gently all the while increasing the SoC (the mimic was usually full given the higher speed highway run into the traffic jam). When stopped and movement begins, a gentle acceleration under EV until a either a gap appeared to open up for a 35 mph + Pulse with a Glide back down, slow speed EV to the top of the next hill/overpass, whatever and glide back down in N, or simply re-ignite the ICE, accelerate back up to whatever traffic would allow and hopefully glide back down ICE-Off even if 35 mph was not reached. Achieving ICE-Off was successful when pulsing up to < 35 mph maybe 75% of the time but when the ICE did not shut down, you paid dearly for the glide back down to 0 mph and waiting for the ICE to stop while parked with everybody else. Running her up to higher speeds as traffic allowed when it did open up allowed for a nice charge on the pack so as to cover overhead and allow a few blocks of EV which is exactly what makes the Prius-I so darn effective in this type of traffic scenario. In one 10 mile stop and crawl on Interstate I-294 just south of O’Hare airport in Chicago, I saw 4 of the 6, 5-minute bars pegged in fact. Fuel economy over any given period while stuck in a traffic jam allows her to achieve the mid 80’s to low 90’s without so much as a few accelerator pedal manipulations if you are willing to take her to those levels.
Higher speed highways. This is an area where all vehicles drop off quickly but the Prius-I appeared to drop off faster then just about anything I have driven other then an HCH-I or Insight dropping out of lean-burn as speed increased. For every mph above 50, I was losing ~ 1 - 1.5 mpg which appears harsh at first but even at 60, she would hold onto 60 mpg once setup. The good thing is whenever an opportunity presents itself to slow to a stop, to a lower speed or you have a long downhill ahead, warp stealth can and should be taken advantage of at every opportunity. By placing her into Warp stealth, you are minimizing energy conversion back to the pack under regen, you are in fuel cut for the time she is in this mode and you are not losing much in the way of speed depending on how steep the downhill section is. You are however dragging the packs SoC down some while MG1 draws current in order to spin the motor over. Because the energy mimic was so course, I did what I could to maintain the ICE spinning between 1,000 and 1,200 RPM via MG1 (somewhat speed dependant for some reason?) and attempt to hold a no arrow warp stealth. That last part takes a delicate pedal balance and as your SoC or speed droops, you will be making fine adjustments to the accelerator pedal so as to try and maintain this no-arrow warp-stealth condition at highway speeds. Without a Can-View or Graham scanner, I am not sure what the current magnitudes or directions were or even if this no-arrow mode even exits under the hood? Given the Energy mimic shows current flow back and forth between regen and standard warp stealth, I used this no-arrow warp-stealth mode as yet another fuel conserving technique and used it anytime I was slowing from 60 + down though 41 before entering into a pure Glide. I wish there was better news with regard to her higher speed highway fuel economy but given she was pushed for what she was worth (not for what she was not ), that leaves me flying a little blind on the top end.
I want to add that what many believe to be a very fuel efficient RPM range in the Prius II’s 1.5 (1,700 - 2,300 RPM) was not where I found the highest FE from in the Prius-I. With the energy mimic pointing to a 1250 - 1400 RPM range during the pulse so as to keep MG2 from assisting, I found a similar RPM range to work extremely well even at highways speeds. While climbing any lengthy steeper segment, I would run her up inside a 1,700 - 2,100 RPM range as that was sometimes needed but loafing along down the highway at the same 1,250 to 1,450 range appeared to maximize her somewhat steady state fuel economy tremendously. There was not much power available down that low but her FE figures told me this is where she wanted to be. I hope you find the same.
The results. All tanks below were consumed using an initial tank top off to final fill tank top off.
Short ScanGauge Calibration Tank
Temps from 63 - 76 degrees F and 20% rain. MFD = 78.6 with the std. setup but non calibrated SG-II = 73.5 after 191.0 miles.
I allowed my wife drive almost 20 miles and I drove the rest back to a local gas station for the short calibration tank. 234.0 miles on 3.306 gallons = 70.78 mpg. Calibration commute(s) yielded a + 1% speed/distance offset and a + 3.3% Gallons consumed offset over this short calibration tank.
Full Review Tank
Temps from 63 – 81 degrees F. MFD = 79.3 with the SG-II = 74.5 after 189.3 miles.
Temps from 64 – 84 degrees F. MFD = 78.7 with the SG-II = 74.0 after 381.2 miles.
Temps from 68 – 86 degrees F. MFD = 78.9 with the SG-II = 74.3 after 575.6 miles.
Temps from 72 – 84 degrees F. MFD = 78.8 with the SG-II = 74.1 after 769.6 miles.
Temps from 75 – 82 degrees F. MFD = 79.3 with the SG-II = 74.5 after 947.3 miles. 2.000 gallon fillup from gas can.
Temps from 81 – 82 degrees F. MFD = 79.3 with the SG-II = 74.5 after 963.8 miles.
Fuel Starve occurred at 947.3 miles out. Top off fill calibration dropped fuel consumption offset to + 2.3% with mph/distance at 0% offset. 963.8 miles on 12.821 gallons (10.821 gallons + 2.000 gallon from can) = 75.17 mpg.
Final Short Tank before she went back to her owner.
Temps from 72 – 83 degrees F. MFD = 82.3 mpg with the SG-II = 78.4 after 198.0 miles.
Temps from 75 – 88 degrees F. MFD = 83.4 mpg with the SG-II = 79.1 after 392.5 miles.
ScanGauge-II for final commute home and tank: 83.6 mpg and 79.1 mpg.
Top off to Top off for final fill Fuel Economy. 392.5 miles on 4.96 gallons = 79.13 mpg.
Top off to Top off from initial fill to final fill, observed Fuel Economy: 1590.3 miles on 21.087 gallons = 75.416 mpg.
Conclusions. With a little help from you, the Prius-I can reach an area few may have thought possible in the past. I would highly recommend that you place some of these techniques into practice at your earliest convenience but not without first practicing them on an empty and desolate country road so they become second nature and only under the safest conditions. The Energy and Consumption screens as well as a Scangauge can overwhelm you at first and it is best to train yourself gradually rather then “I can do all of this tomorrow” and getting someone injured as well as achieving somewhat poor results in the short term. Once you have the tools in your toolbox, it should not be out of your realm to achieve the mid 60’s to low 70’s while driving a lower speed highway commute, 70’s and 80’s over very short trips around town in the summer, and mid 80’s to mid-90’s when you can let it all go on the back desolate roads you may available to you. It was not uncommon to take her from dead cold in 70 degree temps to the low to mid 90’s within 15 miles of her starting point using every tool in the arsenal. Of course traffic and roadway conditions may dictate a far less fuel efficient segment but even so, use you head with the tools provided and she will reward you many times over.
If you have the type of commute allowing you to be untouched by other drivers in a lower speed suburban type environment, 1,000 miles to a tank would not be a problem. As speeds climb, that possibility diminishes quickly although excellent FE is still available with the right application of the proper tool at the appropriate time no matter when and where you drive.
I would like to thank both Wayne Mitchell and Doug Schaeffer for their technical expertise and especially Cheryl Appel of the Madison Hybrid Group for the use of her Prius-I for a week + so as to not only gain experience with this fine piece of automotive history but better yet, find out what it was capable of in the process.
Cheryl and her 2002 Prius-I.
Thank you Cheryl!
Good Luck
Last edited by xcel : 10-07-2007 at 10:15 PM. Reason: Added the Prius-I's tank FE sig and cleaned it up.
Old 06-21-2007, 12:01 PM
Re: Toyota Prius-I, reaching for the hypermiler in all of us.
There is only one Wayne! I have a mostly secondary highways 1400 mile round trip starting tomorrow, reduced payload by 250 lbs, and see if I can't get a few more mpg than the last road trip. Can't go as slow as one might like, because I gotta get there.
There seems to be no downside to cardboard in front of the radiator, until the rad fan spins at about 200 oF, or A/C is called for. I know, Wayne, you never use A/C
I have bequeathed my supply of rebuilt accel pedals to Bob Wilson. So somebody else is going to have see if lighter springs could not be fitted into them. Have long thought that would make the NHW11 dance easier.
Or perhaps this is just a bad carpenter blaming his tools?
DAS
Old 06-21-2007, 01:56 PM
philmcneal's Avatar
just wanted to add, when pulsing i find it was very easy to have the engine supplying power to the wheels and the electric motor without putting energy back into the pack. This was much easier to do on a prius I than a prius II having driven both cars for months.
when SOC is below half (55% and lower) the engine WILL WORK harder to recharge the battery (so 20 amps is lost when engine is spinning, so you will feel the acceleration difference) but once you reached 58% the engine will provide all the power to the wheels (most anyways) so the acceleration affect will be a bit faster (more motion less juice, less conversion losses) So be careful never to drain the battery to half SOC, your mileage will be affected by force charging the battery.
I pretty much can answer any prius question anyone throws at me with the minus of technical difficulties and maybe DIY items.
Old 06-21-2007, 08:01 PM
cuchulain cuchulain is offline
Vehicles: 1999 Prius NHW10
Great write up as ever, Wayne.
I am still digesting it, I was doing P/G under 35mph so I will follow your advice. As the NHW10 is similar to NHW11 it should be applicable.
Technically the SOC mimic is not full, I see it everyday coming down from 3300ft to 1000ft when I get full regen for over 10minutes. Try to get a pic for you.
Thanks again
Andrew
Old 05-25-2008, 07:22 PM
mclgolf mclgolf is offline
Vehicles: 2002 Toyota Prius
Re: Toyota's Prius-I, reaching for the hypermiler in all of us.
Wayne,
I am real new at this having only started driving my Prius l since November 07. I live in a rather cold climate in Northern Maine at the top of a hill that drains the MPG every time I head home. I don't gain it back on my early morning commute due to the engine needing to warm-up before functioning properly. Any suggestions for that opening 2 1/2 mile downhill drive on a cool Maine morning?
Old 05-25-2008, 08:35 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
If you don't already have one and engine block heater will work wonders.
- Sean
New? Start here!
Old 05-25-2008, 08:42 PM
bestmapman's Avatar
bestmapman bestmapman is offline
Vehicles: 2010 Toyota Prius, 2009 Kawasaki C-14
The Gen-I Prius would be a great car to buy now. It can be purchased significantly less then the Gen-III and is almost as good. As gas prices continue to rise, the Gen-I Prius should hold it's value well.
Drivin slow in the FAS lane.
Old 05-26-2008, 02:19 PM
xcel's Avatar
Hi Mclgolf:
___As Sean mentioned, an EBH would get you to S4 sooner and than you can take advantage of the downhill’s to make up for the climb coming home.
___Now let us talk about the 2.5 miles. Is that your entire commute or is it a hilly 2.5 miles we are talking about? A 2.5 mile climb would gain maybe 200 – 500’ and that would be quite a rise unfortunately. The Prius is great at handling its own SoC and FE but with some strategy thrown at it, close to doubling the EPA is not out of the question. When nearing the top of any significant decline, you could warp-neutral (ICE-Off) or regen under fuel cut for the distance coming down. I hope that helps but a few more details would be needed to really get a table top of your commute completed.
Old 05-26-2008, 07:24 PM
Wayne,
The 2.5 miles is either the end of my 15 mile commute (coming home uphill) or the begginning (going to work downhill). In your article you talked about three restarts to aid in the warming up fuel economy. I can start out for two tenths relatively flat and get my speed up to about 30 MPH and then shift to neutral for a long glide of about 2.3 miles to the first stop sign. If I use regen the drop is not quite long enough to sustain the complete glide but the car warms up. The FE is never above 60 mpg however and I get killed climbing my way back home. The rest of the commute is a little hilly but manageable. Thanks for your in depth article. I am truly impressed and perhaps once I understand the car better I can get myself up in the 60's or better. I am going to have a block heater installed soon!
Old 05-26-2008, 10:39 PM
philmcneal's Avatar
im beginning to wonder if that's the case of the prius II as well, since having all the power goes to the wheels (all arrows to the wheels; battery is grayed out) results in much lower rpms than what the engine efficencies are suggesting. But the FE indicated is much better overall, hm... although my impression was 1500 RPMS for flats and 1700 RPMS for hills driving with load...)
still can't coast as long as you Wayne, heh honestly 80 mpg would be a godsend but I just can't coast that long dammit!!!
Pulse and Glide plus Warp Stealth in the Prius II for maximum FE … xcel Articles 58 11-05-2011 08:28 PM
Chicago to NY in a Prius on one tank of fuel? xcel Articles 11 03-08-2011 10:35 AM
Behind Toyota's hybrid revolution - successful gamble with Prius. xcel In the News 2 06-20-2008 06:47 AM
Toyota Prius adds a sporty touring addition For 2007. xcel In the News 2 08-21-2006 09:10 PM
Test Drive: 2006 Toyota Prius tigerhonaker Toyota 6 07-16-2006 09:58 PM
