Hi Brandon:
___Hey, I was over at AcuraMDX.org for almost a year before we brought our MDX home
The 01/02 MDX tranny’s were the problem children from all my reads. The 03 - 04 7th gen Accord V6’s had tranny problems and the 2nd gear jet kit was their supposed fix? About all I can say is that with close to 50K miles of HS FAS’ing with the K24’s Auto, the 05 is holding up extremely well. I am extremely gentle with her though … There are quite a few items Honda cheapened up on the Accord’s over the previous 2 gen’s. Not just the std. front disc brakes on all Accord’s but also the Parking brake as well!
___As for the CVT based HCH’s, I found that Hybrid Testing article intriguing to say the least. Here is a repeat of my own questions/concerns/conclusions but it appears that the CVT based HCH was abused by the same driver? Look at the exact miles and location of the HCH-I w/ the wrecked CVT.
HCH pdf #1: 2003 HCH w/ CVT - cost $25,834. Driven by Electric Transportation Application employee. 27,887 @ 36.26 mpg.
HCH pdf #2: 2003 HCH w/ CVT - cost $23,235. Driven by Electric Transportation Application employee. 24,451 miles @ 43.17 mpg.
HCH pdf #3: 2003 HCH w/ CVT - cost $23,174. Driven by Bank One’s courier pool. CVT and CAT failed at the 96 and 97K mark respectively. 104,593 miles @ 37.99 mpg.
HCH pdf #4: 2003 HCH w/ CVT - cost $23,174. Driven by Bank One’s courier pool. CVT and CAT failed at the 99 and 100K mark respectively. 104,381 miles @ 37.6 mpg.
Insight pdf #1: 2001 Insight 5-speed - cost $22,387. Driven by Technology Development Fleet of APS. Battery Pack and Controller failed - Replaced under warranty. 68,287 miles @ 47.10 mpg.
Insight pdf #2: 2001 Insight CVT - cost $22,387. Driven by Bank One’s courier pool. 104,920 miles @ 44.38 mpg.
Insight pdf #3: 2001 Insight CVT - cost $21,170. Driven by Bank One’s courier pool. CVT failed at 89K. 110,175 miles @ 46.23 mpg.
Insight pdf #4: 2001 Insight CVT - cost $22,387. Driven by Grand Canyon Red Cross courier pool. 18,612 miles @ 49.36 mpg.
Insight pdf #5: 2001 Insight CVT – cost $22,887. Driven by Grand Canyon Red Cross courier pool. 15,746 miles @ 44.38 mpg.
Insight pdf #6: 2001 Insight CVT - cost $22,887. Driven by Grand Canyon Red Cross courier pool. 8,962 miles @ 46.38 mpg.
Prius I pdf #1: 2002 Prius I - Cost $22,580. Driven by Technology Development Fleet of APS. 69,938 miles @ 39.71 mpg.
Prius I pdf #2: 2002 Prius I - Cost $21,655. Driven by Bank One’s courier pool. Rear hub and bearing failed at 40K. 106,995 miles @ 40.36 mpg.
Prius I pdf #3: 2002 Prius I - Cost $21,655. Driven by Bank One’s courier pool. Overheated and Rack and Pinion failed at 87K and 106K respectively. 105,795 miles @ 41.08 mpg.
Prius I pdf #4: 2002 Prius I - Cost $23,884. Driven by Bank One’s courier pool. 27,513 miles @ 43.68 mpg.
Prius I pdf #5: 2002 Prius I - Cost $23,064. Driven by Electric Transportation Application employee. 15,773 miles @ 45.21 mpg.
Prius I pdf #6: 2002 Prius I - Cost $23,255. Driven by Electric Transportation Application employee. Rack and Pinion failed at 25K and again @ 32K miles - Replaced under warranty. 17,490 miles @ 41.81mpg.
Prius II’s 16,000 each with an accumulative mpg of 44.6 mpg.
___I did notice a few outliers?
1. How did the HCH’s and Insight’s cost far more then MSRP?
2. Why did the 1 medium mileage Insight’s pack and controller fail?
3. Why did the 2 high mileage HCH CVT’s and CAT’s fail within just a few miles of one another? Someone from Bank One was probably neutral or brake dropping them by the sounds of it?
4. Why did the 1 high mileage Insight CVT fail?
5. How did the rack and pinions of the 2 Prius’ fail and the one with 2 failures at the 25K and 32 K mark only had 17,490 miles on it?
___Although these automobiles were more then likely abused similar to a rental car by those that drove them, the CVT and CAT failures sound very expensive for the HCH’s in particular.
