Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
2014 Chevrolet Cruze Diesel… The Numbers Are In
Old 02-06-2013, 11:39 PM
xcel's Avatar
xcel xcel is online now
42 mpgUS with the 6-speed AT.
http://www.cleanmpg.com/photos/data/501/2014_Chevrolet_Cruze_TD_emblem.jpg
Wayne Gerdes - CleanMPG - Feb. 6, 2013
2014 Chevrolet Cruze Turbo Diesel (TD) - $25,695 USD including destination, handling, and two-year maintenance plan.
Just hours before the official opening of the 2013 Chicago Auto Show Press Days, GM released the final specs on its much anticipated 2.0L turbo diesel equipped Cruze. This summer the Cruze will host the cleanest turbo diesel passenger car engine General Motors has ever produced.
Built at the same in Lordstown, Ohio manufacturing facility as the current Cruze, the 2014 Cruze Turbo Diesel delivers a combination of segment-leading features and that ever present 46 mpgUS highway rating with an automatic.
The Cruze compact sedan’s new 2.0L turbo-diesel is based on proven architecture already used in European models, where approximately 40 percent of all Cruze models sold feature a diesel engine. The 2.0L turbo-diesel engine produces an estimated 148 hp and whopping 258 lb-ft of torque providing a 0-60 time of just of 8.6 seconds. Peak torque is achieved at 2,000 rpm while the engine has an overboost feature capable of increasing torque to an estimated 280 lb-ft for approximately 10 seconds.
The Chevrolet Cruze TD arrives with a six-speed automatic transmission, four-wheel ABS disc brakes, 3.20 final drive ratio, 140-amp alternator, 800 cold-cranking amps battery, 17-in alloys, ultra-low-rolling resistance all-season tires, rear spoiler, Aero Performance Package and leather-appointed seating.
Other standard features include Chevrolet’s infotainment system MyLink, a two-year maintenance plan, and a five-year 100,000 mile powertrain warranty.
A lightweight aluminum cylinder head and aluminum intake manifold contribute to the engine’s comparatively low weight of 408 pounds.
Additional highlights include:
  • Dual overhead camshafts with four valves per cylinder and maintenance-free hydraulic lifters with low-friction roller-finger followers
  • Quiet belt-driven cams/valvetrain with high-strength belt material and tensioner rated for 100,000 miles
  • High-strength aluminum pistons with reinforced top ring and integral combustion bowl design
  • Central direct injection, with the injector positioned in the middle of the cylinder, with the bowl in the piston serving as the combustion chamber. This enables a high 16.5:1 compression ratio that enhances power and combustion efficiency
  • Variable-swirl intake manifold design, which optimizes air charge mixture motion in the cylinders for a more-efficient combustion that enhances performance and reduces emissions
  • Common-rail fuel system with Piezo fuel injectors that create multiple injections per combustion for greater performance, combustion efficiency and quietness
  • Variable-nozzle turbocharger that broadens the engine’s torque curve, particularly at low rpm, and supports greater high-rpm horsepower. It is mounted close to the exhaust outlet of the engine for quicker “spool up” of the turbine and faster “light off” of the exhaust catalyst
  • Intercooling system produces a cooler, denser air charge for greater power
  • Piston oil jets that help reduce friction and optimize piston temperature for greater performance and efficiency
  • Turbocharger bearings are oil-lubricated and cooled via an oil cooler
  • Variable-displacement oil pump helps save fuel by optimizing the oil pressure, which reduces friction
  • Vacuum pump designed for lower engine friction
  • Ceramic glow plugs, which provide greater cold-start performance over conventional metal glow plugs (an engine oil heater is offered for cold climates)
  • B20 bio-diesel compatibility
Quiet performance is enabled by a number of features on and around the engine. There are also sound-absorbing features added to the Cruze diesel itself including a unique dash mat, hood blanket and more.
An exhaust gas recirculation (EGR) control system features a high-capacity cooler and bypass feature that enable the engine to meet US and Canada’s tough diesel emissions regulations. There is also a Selective Catalyst Reduction (SCR) that includes a diesel particulate filter (DPF) and urea (Diesel Exhaust Fluid or DEF) injection that helps make the 2.0L the cleanest diesel passenger car engine ever provided from GM.
An approximately 4.5-gallon DEF tank in the Cruze TD holds enough fluid to provide at least 10,000 miles of driving between refills. The system is also designed for servicing to coincide with oil changes, for greater convenience.
Now let’s compare the Chevrolet Cruze turbo diesel against its only competitor, the Volkswagen Jetta TDI.
2014 Chevrolet Cruze 2.0L TD Specifications
Attribute2014 Cruze TD with the 6-speed AT2013 Jetta TDI with the 6-speed DSG AT
Price ($USD)$25,695$24,885
Displacement (L)2.0L2.0L
Power (hp)148140
Torque (lb-ft)258 with peak of 280236
mpgUS highwayest. 4242
Turning circle (ft)35.736.4
Acceleration performance: 0 – 60 mph (sec)8.69.1
Wheelbase (in)105.7104.4
Overall length (in)181182.2
Overall width (in)70.770.0
Overall height (in)58.157.2
Leg room front/rear (in)42.3/35.441.2/38.1
Curb weight (lb)34753,162
Passenger volume (cu ft) 94.692.4
Cargo volume (cu ft)13.315.5
Fuel capacity (gal)15.614.5
Old 02-07-2013, 12:23 AM
seftonm's Avatar
seftonm seftonm is offline
Vehicles: 2010 VW Golf TDI
Re: 2014 Chevrolet Cruze Diesel… The Numbers Are In
Based on the Euro numbers I was actually expecting this to come in with lower mpg than the Jetta. SCR may be what saved them. Tough sell against the Cruze Eco though.
Regards,
Mike S.
Old 02-07-2013, 04:01 AM
herm herm is offline
I think a Volt is a better deal
Old 02-07-2013, 04:44 AM
thunderstruck's Avatar
thunderstruck thunderstruck is offline
Moderator
Vehicles: 2015 GTI SE 6 Manual
Diesels usually far exceed the EPA ratings though. The car being allowed to use B20 is a hell of an advantage over VW, who threaten to void your warranty for anything over B5.
Old 02-07-2013, 05:53 AM
Bigspender007 Bigspender007 is offline
Vehicles: 2011 Honda Civic DX-G
I'm happy to see an american auto maker step into the diesel passenger car realm. Cost of ownership of the VW kills that option quickly, my parents VW TDI drained them at every service and insurance rates are significantly higher than a Chevy. Chevy seems to be backing this up with some good standard options to temp you to consider it and I'm considering it. I will wait to see Canadian pricing and fuel ratings.
Old 02-07-2013, 06:03 AM
Moderator
Vehicles: 2010 Toyota Prius II, 2013 Chevrolet Volt
B20 bio-diesel compatibility?!!??
Is that right? Not just the standard B2? B20 capability in a modern diesel is actually pretty unusual.
Old 02-07-2013, 08:17 AM
bullwinkle428 bullwinkle428 is offline
Vehicles: 2013 Honda Civic EX (5-speed auto), 2002 Honda Accord EX Sedan (5-speed manual)
The lack of a manual transmission, a long memory regarding GM's history with diesel engines, and the 75-80 cent premium for diesel fuel vs. gasoline are big enough negatives to prevent me from seriously considering this choice. Still think the gas-engine Eco is a better deal in the long run, even considering the POTENTIAL durability of the diesel engine.
Old 02-07-2013, 08:40 AM
PaleMelanesian's Avatar
Beat the System
Nice, but it's missing two key ingredients. Stick shift and hatchback / wagon.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 02-07-2013, 08:44 AM
ALS's Avatar
ALS ALS is offline
Moderator
Playing with the numbers the standard Cruze is a much better deal fuel mileage wise over the Diesel version. I ran some numbers using average Pa. fuel costs for 87 and diesel with a 1170 mile highway tri, where you would save a whole $12 with the diesel version. For a seven thousand dollar premium in price it isn't worth the difference for the diesel version.
I like the specs but to the average buyer that additional premium for the diesel option isn't going to make economic sense here in the states. In the EU where diesel sells at or less than gasoline it is something I would take a serious look at.
Old 02-07-2013, 09:34 AM
Did you compare it to a stripper with the 1.8L?
Diesel Chevrolet Cruze confirmed for U.S. msantos In the News 18 07-13-2011 02:02 PM
2013 Chevrolet Cruze To Offer 2.0-Liter Clean-Diesel Option FSUspectra In the News 25 03-13-2011 07:35 AM
Official Cruze Eco Numbers - 28/42 MPG Nevyn The Daily Grind 5 12-03-2010 12:47 PM
2011 Chevrolet Cruze - America’s Most Fuel Efficient non-hybrid/non-diesel Compact xcel In the News 17 06-02-2010 11:23 PM
Chevrolet Tahoe and GMC Yukon 2-Mode Hybrid FE numbers released. xcel In the News 5 09-28-2007 04:18 PM
