Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
VW October 2012 Sales up 22.4% + 2013 Jetta Hybrid Preview
Old 11-01-2012, 01:05 PM
xcel's Avatar
xcel xcel is offline
The Jetta lineup continues to power VW sales in the US.
http://www.cleanmpg.com/photos/data/501/Profile_News.jpg
Wayne Gerdes - CleanMPG - Nov. 1, 2012
2013 VW Jetta Hybrid - $24,995 to start and a 45 mpgUS combined estimate.
The SE ($26,990) though SEL Premium ($31,180) adds more comfort, luxury and convenience features.
The sixth-generation Jetta receives a new family member in the form of the Jetta the 2013 Jetta Hybrid.
Exterior
The familiar Jetta exterior has been tweaked to reduce its coefficient of aerodynamic drag to .28 from .30 with a slight lowering, a front air dam, more closed up grille, slightly extended side skirts and a trunk lid spoiler. While not exactly eye-catching, the upscale alloy wheels on all trims and laser body to roof seam welds add a touch of class over and above the base non-hybrid offerings.
Interior
Situated between the informative, but not ground-breaking, all-new Power Meter on the left and the speedometer on the right is a standard Multi-Function Instrument, which shows ambient temperature, gear selection, the trip computer, a second audio display, and driver settings. In the Jetta Hybrid, this screen also presents the car’s drive state and the “ePower meter,” which includes the level of battery charge and the available amount of electric driving (“E-Max”).
An Auto dual-zone climate that incorporates an electric-based A/C system for a cool interior climate even when the engine is shut down is standard.
A new soft plastic upper interior covering and cloth textured headliner and A-pillar adds to its upscale appearance.
All Hybrid models also include standard Bluetooth connectivity and a leather-wrapped multifunction steering wheel.
Comfort? Spending over 200 miles in the Jetta Hybrid split between the driver and passenger seat yesterday, the car was quiet enough to have a conversation with a passenger without raising your voice or straining to listen at speeds up to 75 mph. In addition, the large diameter cushioned soft leather wrapped wheel, ergo and seat comfort was excellent.
2013 VW Jetta Hybrid - The Driving Space
Drivetrain
The Jetta Hybrid combines a direct injected and turbocharged 170 HP and 184 lb-ft of torque 1.4L I4 gasoline engine with a 27 HP clutched electric motor mated to a very smooth 7-speed dry dual clutch automatic and a 1.1 kWh Li-Ion pack located under the rear trunk floor. The small electric motor acts as a starter to spin up the engine from 0 RPM, provides EV propulsion under light demand and regenerative braking whenever the brake is actually applied. Together, the drivetrain provides an eye opening and somewhat easy to achieve 45 mpg combined rating along with a 0 to 60 mph dash time of just 8.6 seconds.
The Jetta Hybrid can be accelerated gently to 37 mph, and 44 mph if using the “E-Mode” button although the topography driven on yesterday was too hilly to test these limits. I did see EV propulsion at 65 + mph on mountain downhill’s so it is torque demand based vs. a hard ceiling limit imposed via software.
The Jetta Hybrids killer app is its ability to glide at up to 84 mph. I did not test that top limit but at any speed just let off the gas, the engine is declutched from the transmission and shutdown evoking a glide without any work from the driver whatsoever. While there is a small amount of drivetrain drag, it is vastly reduced compared to Toyota’s HSD, Ford’s e-CVT and even Hyundai’s Bluedrive in D.
Placing power to the road, all versions (15, 16 and 17 in wheel equipped) of the 2013 VW Jetta Hybrid are shod with somewhat low rolling resistance Continental ContiPro Contacts.
2013 VW Jetta Hybrid EV Mode in action
Notice I am demanding power via the “ePower meter” (left gauge) with the engine shutdown (0 RPM per the ScanGuage) while traveling at far beyond its specified 37 mph EV
Mode top speed. Glide speeds may in fact be unlimited. This higher speed mountainous driving stint ended at 60.1 mpg with a net elevation decrease of approximately 300 ft.
When the Li-Ion pack is filled to capacity with a slight touch of the brake to evoke Regenerative braking during a lengthy descent, the engine does spin up with the injectors shut down to provide engine braking as expected.
Ride and Handling
Whooa is it good! The Jetta Hybrid features the Jetta GLI’s suspension components minus the stiffer springs. Why is it good? Great tuning up front and at the rear, a truly independent multi-link rear suspension. Again right out of the great handling Jetta GLI but with softer spring rates and probably less aggressive dampers providing a very comfortable ride.
Volkswagen’s latest electric power steering (EPS) system in the Jetta Hybrid provides an excellent balance of precise road feel without limiting driving comfort at speed. Maybe a touch under-boosted at parking lot speeds, at suburban and highway speeds it buries the entire compact class other than the Mazda3. And we are talking a fuel efficient hybrid, not a purpose built autocrosser.
All told, taking 35-mph-suggested, decreasing-radius mountain sweepers in 50 mph PSL zones at 60 + mph inspires confidence like nothing in the high fuel economy class.
Fuel Economy
The 2013 Jetta Hybrid is expected to be certified with a 45 mpgUS combined rating. This is of course an excellent rating and like all CleanMPG’ers, it is simply a number to achieve as a minimum with much more available in the real world. The following was a short US highway round trip drive in the chilly (39 – 43 degrees F) morning hours with the average Fuel Consumption Display (aFCD) reset and then recorded some 21.2 round trip miles later at the exact location that it was zeroed. Unfortunately the terrain in the Santa Fe area is extremely mountainous and there was an 800 ft. descent on the first leg heading out and the same 800 ft. climb coming back. The result as shown is not a calibrated result (odometer or fuel consumption) but given VW’s focus on accuracy, I suspect the 68.0 mpg result is extremely close to the actual result in subpar conditions and tough topography. In temperatures of 70 degrees, I would expect a 73.1 mpg result after temperature compensation on that same mountainous round trip route. In other words a world-record-breaking automobile and the only thing needed is to maintain speed between the limits and allow the Jetta Hybrids EV/Glide mechanisms to work as designed.
Safety
http://www.cleanmpg.com/photos/data/523/NHTSA_4-Star_News.jpg
The Jetta Hybrid arrives with front, side and side curtain airbags. On the active front, it incorporates Anti-lock Braking (ABS), Electronic Brake-Pressure Distribution (EBD), Electronic Stability Control (ESC), Hydraulic Brake Assist (HBA) and VWs exclusive Intelligent Crash Response System (ICRS), which unlocks the doors and turns on the hazard lights, as well as shutting down the fuel system in certain types of collision. On the tough NHTSA crash test regimen, the Jetta Hybrid scored 4 of 5-stars with the frontal crash test falling just short of the 5-star goal.
Preview Conclusions
While expensive (really $26,990 to start for the SE) and requiring premium fuel, the 2013 VW Jetta Hybrid provides excellent acceleration and absolutely the best handling within its competitive segment. I am speaking of the Prius, Honda Civic Hybrid and C-MAX by an instantly noticeable margin. It is also very quiet at both a stop and at speed. The transitions from Engine-Off in a glide, EV propulsion or regenerative braking to Engine-On and propelling the Jetta Hybrid are almost seamless. The driveline shift shock between gears is also one of the best in the business for a traditional automatic. Around town with the ICE-Off, I can only think of the current Fusion Hybrid being quieter.
The Jetta Hybrid, will go on sale later this month with specific details uploaded in the following: 2013 Volkswagen Jetta Hybrid Pricing, Options and Specifications
Ready to take you on a "Fun-to-drive" mountain road adventure.
VW October Sales
VW this morning reported 34,311 units sold in October, a 22.4 percent increase over October of 2011 sales results and the best monthly sales result since October 1972. CYTD, sales are up 35.6 percent.
As Volkswagen announced this month’s sales result, they also added they are donating $500,000 USD to the American Red Cross to help with relief efforts ongoing in the aftermath of Hurricane Sandy. Additionally, Volkswagen will provide matching funds to any employee donations made to the American Red Cross or the organization of their choosing.
The Jetta sedan continues to be the volume leader with sales totaling 11,253 while Jetta SportWagen totaled 2,223.
VWs continued sales success with its TDI models, the Jetta, Passat, Tiguan and Golf saw sales reach a combined 75,779 units, a healthy 29.9 percent increase calendar year-to-date.
VW Oct 2012 Highlights and Overall Sales
ModelOct-12Oct-11Oct-DSR % changeOct-12 YTDOct-11 YTDYTD-DSR % change
Jetta*13,47613,059+3.2%140,504150,047-6.7%
Passat8,3555,040+65.8%92,0179,933+822.8%
VW Totals34,31128,029+22.4%357,400263,488+35.1%
* Includes Jetta Sportwagen sales.
The daily selling rate (DSR) is calculated with 26 days for both Oct 2012 and Oct 2011. Year-to-date,
the DSR is calculated with 256 days for all of 2012 and 255 for all of 2011. All percentages reflect DSR.
Top 10 - Oct 2012 US Automobile Sales Leaders
Sales RankMakeModelOct-12Oct-11Oct-DSR % changeOct-12 YTDOct-11 YTDYTD-DSR % change
1FordF-Series56,49752,511+7.6%520,230468,899+10.5%
2ChevroletSilverado38,73936,656+5.7%336,939333,092+0.8%
3ToyotaCamry29,92622,043+35.8%344,714251,564+36.5%
4HondaAccord28,34922,589+25.5%276,196203,603+35.1%
5RamP/U25,22221,037+19.9%238,815199,010+19.5%
6NissanAltima24,62321,838+12.8%258,663222,392+15.9%
7ToyotaCorolla20,94916,244+29.0%243,652203,135+19.5%
8HondaCivic20,68716,173+27.9%254,716183,557+38.2%
9HondaCR-V20,20519,326+4.5%233,586180,361+29.0%
10FordEscape19,83219,046+4.1%219,907206,896+5.9%
Top 10 sales rank notes: No surprise that the top 5 remained the same as last month. Altima, Civic, CR-V and Escape pushed the Cruze out of the top 10. Civic rejoined the top 10 in October and wound up at #8 on the list. Civic and CR-V pushed the Escape back to #10. Corolla moved to #7 from the #9 spot last month.
B-Segment Sales Rank
http://www.cleanmpg.com/photos/data/2/Oct_2012_Market_Share.jpg
  1. Nissan Versa - 8,311
  2. Chevrolet Sonic - 5,495
  3. Ford Fiesta - 3,991
  4. Honda Fit - 3,773
  5. Fiat 500 - 3,720
  6. Hyundai Accent - 3,373
  7. Toyota Yaris - 2,579
  8. Kia Rio - 2,005
  9. Mazda2 - 1,124
C-Segment Sales Rank
  1. Toyota Corolla - 20,949
  2. Honda Civic - 20,687
  3. Chevrolet Cruze - 19,121
  4. Ford Focus - 18,320
  5. Hyundai Elantra - 14,512
  6. VW Jetta - 13,476
  7. Mazda3 - 9,518
  8. Kia Forte - 5,911
  9. Nissan Sentra - 5,624
  10. Dodge Dart - 5,455
D-Segment Sales Rank
  1. Toyota Camry - 29,926
  2. Honda Accord - 28,349
  3. Nissan Altima - 24,623
  4. Hyundai Sonata - 16,773
  5. Kia Optima - 12,948
  6. Ford Fusion - 12,690
  7. Chevrolet Malibu - 9,629
  8. Chrysler 200 - 8,758
  9. VW Passat - 8,355
Segment ranking items of note:
In the B-Segment, the Fiesta climbed from 6th to 3rd, Fit fell back a spot to 4th, Accent fell from 4th to 6th with the Yaris and Rio swapping positions near the bottom.
The C-Segment ranks saw the aging Corolla once again retake the sales lead while the Cruze fell to 3rd behind the Civic. The brand new Sentra fell one spot and from my understanding it was more of a supply issue with the new model. It is a better car than many above it.
The D-Segment ranks saw no changes from last month.
Automobile Manufacturer's US Sales Rank – Oct 2012 vs. Oct 2011 Comparison and Total Sales
  1. GM Oct Sales up 4.7% with 195,764 vehicles sold.
  2. Ford Oct Sales up 0.4% with 168,456 vehicles sold.
  3. Toyota Oct Sales up 15.8% with 155,242 vehicles sold.
  4. Chrysler Oct Sales up 10.2% with 126,185 vehicles sold.
  5. Honda Oct Sales up 8.8% with 106,973 vehicles sold.
  6. Nissan Oct Sales down 3.2% with 79,685 vehicles sold.
  7. Hyundai Oct Sales down 4.1% with 50,271 vehicles sold.
  8. Kia Oct Sales up 12.6% with 42,452 vehicles sold.
  9. VW Oct Sales up 22.4% with 34,311 vehicles sold.
  10. BMW Oct Sales up 18.5% with 32,339 vehicles sold.
  11. MB Oct Sales up 9.0% with 26,642 vehicles sold.
  12. Subaru Oct Sales up 30.1% with 26,119 vehicles sold.
  13. Mazda Oct Sales up 1.6% with 18,622 vehicles sold.
  14. Audi Oct Sales up 14.5% with 11,708 vehicles sold.
Manufacturer's US Sales Rank items of note: BMW and MB passed up Subaru in October otherwise the rankings remained steady.
Through the first nine months of 2012, the Seasonally Adjusted Annual Rate (SAAR) is running at approximately 14.7 million.
Old 11-01-2012, 04:40 PM
Paymaster Paymaster is offline
Vehicles: 2006 Civic Hybrid, 2013 Ford C_MAX
Re: VW October 2012 Sales Up 22.4% + 13 Jetta Hybrid Preview
Darn, just darn. Oh well. Maybe I can give my wife the C-MAX. I did read elsewhere that this requires premium fuel. If that is true at least I have that going for me.
Old 11-02-2012, 11:19 AM
Carcus Carcus is online now
Re: VW October 2012 Sales up 22.4% + 2013 Jetta Hybrid Preview
Glide.... hmmm?. Ok. Maybe VW's got something here.
Old 11-02-2012, 05:15 PM
RichXKU's Avatar
RichXKU RichXKU is offline
Mr. Forced Regen
Vehicles: '11 Honda CR-Z; '06 Toyota Tacoma I4 4x4 5MT
Needs Premium??
Old 11-02-2012, 05:51 PM
Moderator
Originally Posted by RichXKU View Post
Needs Premium??
Taking a leaf out of GM's book to boost the performance and mpg rating.
Plus, EPIC pricing FAIL.
Same pricing as the v and C Max but it's a sedan.
More expensive than the Camry Hybrid but it's a compact.
And it needs premium!
Not that much cheaper the current net pricing on the Volt and the Volt is, by all accounts, special to drive.
I cannot believe they couldn't bring it in cheaper than a $5.5k differential. Are they trying to make diesel look cheap?
Old 11-02-2012, 08:40 PM
all_about_the_glide all_about_the_glide is offline
Vehicles: 2007 Honda Civic Hybrid
Not perfect, but makes the 2014-2015 "vehicle in my garage" short list along with the Prius C and multiple plug ins.
2013 Altima Preview – 38 MPG Highway from a Non-hybrid or Diesel Midsize? Whooaa! xcel In the News 30 05-18-2013 06:51 PM
VWs 2013 Jetta Hybrid does it Again! xcel In the News 1 11-07-2012 08:57 PM
Toyota October 2012 Sales up 15.8% xcel In the News 3 11-04-2012 11:40 PM
GM October 2012 Sales up 4.7% + 2013 Spark Preview xcel In the News 9 11-04-2012 10:47 PM
2013 Jetta Hybrid Pricing Plus a Whole Lot More xcel In the News 6 11-01-2012 02:07 PM
