Major Changes in BMW's new R1200GS
Old 10-11-2012, 06:23 PM
Earthling's Avatar
Earthling Earthling is offline
Trying to be kind to Mother Earth
Vehicles: '07 Prius, '10 Focus, '03 BMW R1150RT
BMW's first water-cooled boxer!
http://www.cleanmpg.com/photos/data/500/new_R1200GS_s.jpg
Harry Clark - CleanMPG - Oct. 11, 2012
The best gets even better.
Major changes arrive with the latest BMW R 1200 GS.
The challenge: how to improve even more following nine years at the top.
Even in its ninth year of production, the current BMW R 1200 GS is still setting the benchmark in its segment in comparative tests with its outstanding overall concept and innovative technology. With over 170,000 units sold, it is the most successful and top-selling travel enduro in the world.
The challenge facing the BMW Motorrad was considerable: To further improve the GS - in all areas and equip it with the latest technical innovations.
Development goals
  • Further increase performance overall - without neglecting its
    well-established virtues.
  • Perfect its touring suitability.
  • Increase off-road suitability.
  • Achieve superior figures within the travel enduro segment and beyond in terms of engine and riding performance.
  • Ensure preparation for the future in terms of noise and exhaust emissions.
  • Suspension with top handling, optimum traction and increased off-road performance.
  • Increase active and passive safety.
  • Unmistakable BMW Motorrad design in typical GS style.
  • Top quality as is characteristic of BMW Motorrad.
To begin, BMW Motorrad instilled a new air/water-cooled boxer engine design with vertical through-flow, integrated gearbox and left-hand cardan shaft drive.
The boxer engine in the new R 1200 GS continues to use air/liquid cooling, however, the coolant oil has been replaced by a glycol-water mixture. This ensures a high level of heat absorption capacity of the cooling liquid for more efficient heat dissipation.
The engine continues to use air cooling with two small radiators inconspicuously integrated up front.
The through-flow is now vertical instead of horizontal for improved filling, and the engine housing integrates the 6-speed gearbox as well as a wet clutch with anti-hopping function instead of the dry clutch as was used previously.
The secondary drive now runs via the cardan shaft on the left-hand side. With an output 125 HP@7700 rpm and 92 lb-ft@6500 rpm, the new engine continues to offer excellent power and performance in the enduro segment.
The empty weight is 523.6 pounds including standard BMW Motorrad Integral ABS.
E-gas and cruise control
An electronic throttle actuator is now used for the first time in a GS. Here, rider commands are passed on directly by the sensor in the accelerator twist grip to the engine control system; this then regulates the throttle valve electronically. The use of the E-gas system provides a significant improvement in terms of controllability and response. What is more, the rider can adapt engine characteristics to the situation on the road by means of five modes.
ASC and riding modes
For the first time the new R 1200 GS now offers five freely selectable riding modes including an ex works option and feature three different E-gas settings with varying engine characteristics.
Semiactive suspension: BMW Motorrad Dynamic ESA for optimum riding dynamics in every situation as an ex works option.
The new semiactive suspension BMW Motorrad Dynamic ESA (Electronic Suspension Adjustment) taps into a whole new range of possibilities as well as providing maximum riding safety and performance. Dynamic ESA monitors the vertical movement of front and rear wheel control as well as other parameters by means of a spring travel sensor in each position, and adapts the damping automatically to the situation depending on riding conditions and the maneuvers being carried out. Damping adjustment at front and rear is effected by means of electrically controlled regulation valves.
The chassis of the R 1200 GS uses a completely new tubular all-steel bridge frame with a bolt-on rear frame. Along with the newly designed Telelever at the front and the EVO Paralever at the rear, a significant increase in rigidity enhances ride stability and steering precision. Optimized handling qualities are the result of a refined geometry and longer swingarm providing improved traction when riding over smooth or rough terrain.
A unique feature of the new R 1200 GS are the tires in the sizes 120/70 R19 at the front and 170/60 R17 at the rear, specially adapted to improve performance.
The brake system of the R 1200 GS has been extensively revised as well. There are now radially mounted Brembo Monobloc brake calipers at the front and a larger brake disc at the rear.
In line with the BMW Motorrad principle “Safety 360°” the new GS is equipped with ABS as standard equipment.
For the first time ever, the new R 1200 GS incorporates an LED main headlight with integrated daytime running light providing excellent road illumination both day and night.
On the navigation front, a new Multi-Controller allows fast and convenient operation of the BMW Motorrad Navigator IV. It is located on the inside of the handlebar grip which allows function selection in a much less distracting manner without having to remove your hands from the bars.
The newly developed windshield of the R 1200 GS offers improved wind and weather protection while also reducing wind noise. Adjustment by a simple wheel can be completed with one hand.
The new R 1200 GS has extended adjustment options for optimum seating comfort. The rider’s seat can now be adjusted in height and tilt angle and the passenger seat can be shifted longitudinally to obtain the ideal distance between rider and passenger. The new handlebars can easily be turned upwards and, together with the optimized knee grip in the fuel tank area, they provide an even better standing position for off-road riding. A high and a low seat, as well as an adjustable footrest system and adjustable foot controls, round off the new R 1200 GS accessories to fit an individuals needs.
Old 10-11-2012, 06:35 PM
Earthling's Avatar
Re: Major Changes in BMW's new R1200GS
The R1200GS has been the biggest selling motorcycle in Germany, and one of it's best selling bikes. It's a go-anywhere, tour-across-continents, excellent ergonomics motorcycle with excellent durability and good fuel economy.
It has been characterized by it's air-cooled opposed-twin "boxer" motor. This motor has been an iconic symbol of BMW Motorrad. It has always been air-cooled, with a single-plate dry clutch. Until now.
This new version of the R1200GS represents a major change. It now has water-cooled cylinder heads with small radiators tucked away, and even more dramatically, a multi-plate "wet clutch." For the go-fast crowd, horsepower has been increased from 110 hp to 125 hp, while maintaining decent fuel economy for such a capable touring machine. Water cooling was apparently used to comply with increasing emissions standards. A big benefit of the wet-clutch will be reduced maintenance - no more spline lubes which required a major service to accomplish.
I expect these changes in the R1200GS to appear in the rest of BMW Motorrad's R-bike (opposed twin) lineup in the near future.
Harry
Old 10-12-2012, 11:41 AM
Jay's Avatar
Jay Jay is offline
Vehicles: Acura RSX Honda VFR750F
Did they manage somehow to make this bike even heavier...again? I remember when BMWs were light, but I was a teenager then.
I also remember when BMW dropped the boxers entirely. They said, "That's it. Our new inline 3 and 4 cylinder bikes are sooooo much better than our crappy boxers that we aren't going to make boxers any more." "Get the very last ones at a huge premium because when they're gone, they're gone." lol Then, ahem..." We've brought back the boxers due to popular demand".
And that's the rub. No matter the technical merits of the new engine, will BMW's tradition-loving customers go for a water-cooled boxer?
Old 10-12-2012, 11:49 AM
southerncannuck's Avatar
southerncannuck southerncannuck is offline
Vehicles: 2007 Honda Fit Sport Auto 2010 Honda SH150I scooter
I prefer the boxer because to my eyes at least, it makes sense. Valves are easy to service, plugs are right there, and both jugs get equal cooling. While I'm sharing I'll tell you that I would rather have less power and no liquid cooling. Air cooling has never failed me nor has it caused any service work.
Old 10-13-2012, 07:18 AM
EdwinTheMagnificent EdwinTheMagnificent is offline
Legend In His Mind
Vehicles: 2008 Honda Civic LX auto
"Why would anyone want an air-cooled motorcycle engine?" , Edwin asks with a puzzled expression. But then he looks around him and sees many Harley Davidsons and gets the answer. Tradition and nostalgia.
I prefer the quietness (and power) of my Honda VFR750F and the sweet whine of its gear-driven cams. You don't get that sweet music with the racket and clatter associated with air-cooled engines. But I admit I have no experience with BMW air or oil-cooled boxers , so maybe they have their own sweet music.
Edwin
Old 10-13-2012, 11:25 AM
Jay's Avatar
Jay Jay is offline
Edwin, I have a '94 VFR750F and I had always been of the opinion that water-cooling has so many advantages that "tradition and nostalgia" was the only thing going for air-cooled. A couple years ago I was blasting down the 15 freeway in July (on a 1000mi trip) and my water pump developed a leak. My engine overheated in earnest in St. George, UT where I spent the night. I topped up the radiator and left at 3 am to try to beat the NV and southern CA heat. I ended up stopping for good in Baker, CA where it was just stupid hot. I was stuck there for two days trying to figure a way to uhaul my bike and me back home. The expense of getting the bike back home and replacing the water pump was almost more than the bike was worth.
Suddenly, I saw the beauty of air cooled. There's more to it than "tradition and nostalgia".
Old 10-14-2012, 07:32 AM
Legend In His Mind
I get your point , Jay. That has never happened to me on the motorcycle but it could. In my old Si , when the water pump failed I was only 7-8 miles from my mechanic and I could just add water ( a few times) to get there. Also, my 93 VFR750F is past tense ; I had to sell it in 98 to pay some bills (divorce). My financial sitch is a bit better now and I am eagerly planning to buy another motorcycle.
Did you ever do 1000 miles in a day on your bike ?
Edwin
Old 10-14-2012, 09:16 AM
Earthling's Avatar
BMW bikes aren't perfect, but I haven't heard of any water pump failures. I've heard of some minor leaks. You can check here: http://www.bmwmoa.org/forum/ They have other components that go bad, but I just haven't heard of many issues with the K bikes, which are all water cooled. I had a K75 that started to overheat. I was stuck in traffic on an Interstate. I used the median shoulder to bypass the traffic jam. The cause was a stuck radiator fan. That fan had been inoperative for years and it only showed up in a traffic jam, which are non-existent where I live. I got home fine, pulled the radiator, and replaced the fan unit.
Honda recommends changing out the water pumps in their cars as preventive maintenance. It wouldn't be a bad idea in a water cooled bike. Honda says something like 90K miles if I recall. It would take quite a while for a hardcore biker to log 90K miles on a bike.
Harry
Old 10-14-2012, 09:23 PM
Legend In His Mind
I don't recall Honda saying that when I had my 89 Civic Si , but maybe I did not pay attention. I do remember my mechanic telling me that they "usually replace the water pump" when a timing belt is changed , and I can see several reasons why , but I chose not to do so. The water pump lasted for nine years and 155K miles.
I would not hesitate to buy another water-cooled motorcycle. And of course now it will have fuel injection , which is great. I don't miss carburetors.
Wonder if Alvaro ever replaced the water pump in his 100K km on his 650 ?
Edwin
Old 10-15-2012, 06:43 AM
Earthling's Avatar
Water pumps in cars last about 150K miles. It makes a lot of sense to replace them before they go bad. I had two Civics, a '99 and a '98 and I remember the salesperson going over the maintenance schedule with me at time of purchase, with one of the items being replacement of the water pump before it went bad, well before that 150K interval.
Harry
GM Like Most Every Other Major OEM in Germany Is Going Solar in a Big Way xcel In the News 13 10-16-2012 05:42 PM
Major CC skeptic changes sides GreenBlues Off-Topic 2 09-01-2010 07:59 PM
Pharma as a major polluter Chuck In the News 9 04-28-2010 02:41 PM
Major Green Tax Deductions Right Lane Cruiser In the News 11 02-15-2010 08:43 PM
Another major life change laurieaw Off-Topic 16 04-06-2009 11:42 AM
