Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
GM’s PU Truck Cylinder Deactivation Leaves Much to be desired…
Old 08-15-2012, 08:42 AM
xcel's Avatar
xcel xcel is offline
In a desperate attempt to showcase the aging Silverado lineup over its rivals, GM touts cylinder deactivation with pushrods over multivalve per cylinder and downsizing with direct injection and turbocharging?
http://www.cleanmpg.com/photos/data/501/2013_Chevrolet_Silverado.jpg
Wayne Gerdes - CleanMPG - Aug 15, 2012
2013 Chevrolet Silverado – Pricing TBA and an at best 15/21 mpgUS city/highway using an aged design based on an original from almost 6 decades ago
GM’s fuel efficiency of its bread and butter 5.3L V8 engine in the latest 2013 Silverado continues to be enhanced with cylinder deactivation in low load operation.
Managers (not Engineers) developing the current Silverado sought the least expensive solution for improving the fuel economy while preserving its durability and lackluster performance.
Jordan Lee, Global Chief Engineer for GM small block engines must have cringed when he was quoted by the PR group with the following:
“Rather than adding turbochargers or multi-valve cylinder heads to increase the power of smaller engines, we chose to keep the proven capability of our larger V8 truck engines, and save fuel by switching off half of the cylinders when they aren’t needed.”
A combination of simple hydraulic valves (read cheap) and software switch off the cylinders when the driver doesn’t need full power. When more power is needed, the system, called Active Fuel Management or AFM reengages the additional cylinders.
With the above, should Cruze ECO and Sonic owners with their modern designed 1.4L turbo’s including 4-valve per cylinder heads be concerned?
Additional diatribe that must be making Ford’s EcoBoost designers shake their heads included GM saying its 5.3L provides “V8 power and capability while offering up the best EPA fuel economy estimates of any V8 pickup.”
“Our 5.3-liter V-8 delivers EPA fuel economy estimates comparable to some competitors’ V6 engines.”
What they failed to provide was the performance AND fuel economy are both lacking by comparison to the latest modern V6 engine designs from Ford as shown in the following snap shot and spec description.
Ford’s 365 HP/420 lb-ft of torque 3.5L EcoBoost (16/22) vs. GM’s aging 315 HP/335 lb-ft. of torque 5.3L V8 (15/21 mpg) in a 620 ft. drag race.
The Silverado with the 4.3L V6 and 4.8L V8 using 4-speed ATs and the 5.3L V8 using a 6-speed AT was a group of old dogs competing with Ford’s pack of young wolves with their modern engine designs and 6-speed ATs. Not only was the older 5.3L V8 performance aspect proven subpar vs. the much more modern EcoBoost and Hemi onslaught hundreds of times, its EPA rated fuel economy is also significantly behind the times.
GM is stretching their entire PU truck engine lineup redesign at the expense of future owners Even Ford’s naturally aspirated 302 HP/278 lb. ft. of torque 3.7L V6 mated to the modern 6-speed AT they provide provided sprint times just a fraction of a second off the Chevrolet 5.3L V8 for a lower cost, less HW thanks to its 4-valve per cylinder modern engine design vs. AFM all the while providing a respectable for a PU truck, EPA of 17/23 mpgUS city/highway compared to the 15/21 5.3L.
Later on in the PR, Lee added:
“As GM develops future vehicles, we will continue to draw on our company’s unsurpassed global powertrain portfolio, which includes direct injection, clean diesels, vehicle electrification, turbocharging, supercharging, and other technologies. But as with our current V-8 engines with Active Fuel Management, the starting point is always what’s the right solution for the customer and the way they use the vehicle.”
Can the following emoticon describe this release any better?
GM, you can do much much better than this! Outdated 2-valve per cylinder pushrod engines were good 57 years ago when they were first designed but today with $4.00/gallon gasoline? Maybe that is why Ford sold 49,314 F-Series by comparison to the Silverado’s 28,972 and Sierra’s 11,105 vehicles purchased last month? This is the kind of thinking and product sinks corporations and you must do better!
There was one highlight in this misguided release. According to Vincentric, the Silverado has the lowest total cost of ownership of any full-size pickup. I wonder what KBB says about that?
Old 08-15-2012, 08:54 AM
xcel's Avatar
Re: GM’s PU Truck Cylinder Deactivation Leaves Much To Be Desired…
All the while RAM is set to unleash their new 3.6L Pentastar V-6 engine (Ward’s 10 Best Engines Award two years in a row) with variable-valve timing (VVT) with 305 HP and 269 lb.-ft. of torque as standard equipment.
In addition, this new RAM PU truck engine will provide a “best of the best-in-class fuel economy” of possibly 18/24 mpgUS (my guesstimate?) for V6 equipped PU trucks.
Old 08-15-2012, 09:10 AM
rhwinger's Avatar
rhwinger rhwinger is offline
Vehicles: 2006 HCH II w/NAVI; 2012 Ford C Mac SE
Hi Wayne:
A coworker looked at the F-150 Ecoboost after our adventure drive. He said the Ecoboost was more expensive and he couldn't get incentives to help lower the cost difference. I don't know how hard he tried with the dealer. He ended up getting the Chevy PU FSP. I don't know all the particulars, but he drives close to 25 miles each way if he doesn't ride his motorcycle.
I don't know how GM computes 'cost of ownership'. Does it include fuel for, say, 17K miles a year or something?
Bob
"Bomber" Bob
Cessna and HCH-II Pilot
Best tank 774 miles/10.4 gal
Old 08-15-2012, 09:26 AM
bullwinkle428 bullwinkle428 is offline
Vehicles: 2002 Honda Accord EX Sedan (5-speed manual)
Is this just a recycling of the old technology that GM used with the Cadillac 8-6-4 engine (if I recall correctly) some 20-25 years ago? I know that was a complete flop, in terms of both performance and sales, and they were fortunate that gas became relatively cheap for a number of years after that, which allowed them to get by with ancient designs.
Old 08-15-2012, 09:35 AM
TheStepChild TheStepChild is offline
Custom User Title
Vehicles: 07 Silverado, 12 Express Cargo
Was wondering the same about the caddi. My grandfather had one of those turds.
James -
Old 08-15-2012, 09:40 AM
PaleMelanesian's Avatar
Beat The System
I hear the current GM deactivation scheme works pretty well, no like the old 8-6-4. The trouble is it's still churning all 8 pistons and carrying their weight and the bigger engine block. Why not build it smaller and boost when needed, instead of building bigger and then idling part when not needed? I'll pose the same question to Honda with their 6-4-3 VCM V6 engines... Why start with the big engine?
Andrew
Old 08-15-2012, 12:06 PM
herm herm is offline
Re: GM’s PU Truck Cylinder Deactivation Leaves Much to be desired…
What mpg do the Ford and GM owners get in everyday commuting?.. while towing 3000, 5000 and 10000lbs?.. I still dont trust turbos.
We know what the EPA gets.
Beat The System
Try pickuptrucks.com for towing tests. Pretty sure they did one with F150 V8 vs ecoboost.
Andrew
Old 08-15-2012, 12:26 PM
rhwinger's Avatar
I know one group that got 32 mpg on a cross country trip, fully loaded. ;-)
Oh yeah, and 22 mpg while towing a Fiesta from Atlanta to Williamsburg.
"Bomber" Bob
Old 08-15-2012, 12:36 PM
xcel's Avatar
Hi Herm:
When it comes to towing, there is so much energy in a gallon of gasoline and diesel and it is all used when the throttle plate is opened up. It is when the vehicle is not towing which is 98% or more % of the time when all of these technologies can provide better FE under low or lower LOD operation.
Unfortunately GM is boasting about 30 and 60 year old technology while the real work was done by its competitors with the results continuing to show up in the real world and the EPA. The numerous 5.3’s I drove dated felt dated by comparison to both the 3.5L EcoBoost and the 5.7L HEMI in the RAM.
What GM needs to do is bring in its DI and boosted new V6 in a new truck including a much needed interior update. Driving newer GM PUs remind me of driving decade old GM PU trucks. They just have not kept pace with what the rest of the industry has gone to. Toyota’s Tundra and RAM’s 1500 have the best interiors by far. Ford has its amazing EcoBoost and its Power Stroke. Even its more fuel efficient 3.7L kicks @$$ on the fuel economy side of the equation. All GM currently has it their Duramax with the 6-speed Allison and that is absolutely it when it comes to consumer trucks from my perspective.
Bob, that was almost 26 mpg when towing the Fiesta
VWs 1.4L I4 with Cylinder Deactivation xcel In the News 3 08-06-2012 09:19 PM
Ford’s Focus Diesel Honored Yet Again in Europe… Nowhere To Be Found Here However :( xcel In the News 23 05-16-2012 04:42 PM
CR’s 2011 Annual Reliability Report is out and… xcel In the News 10 10-26-2011 08:43 AM
Cylinder Deactivation Improves FE Chuck In the News 32 10-19-2007 10:12 PM
