MSRP: $49,800
Federal Tax Credit (for those that qualify): $7,500
CA State Rebate (for as long as CA funding continues): $2,500 or more
Destination: TBA
Options Pricing
None Available
Engineering
Motor
Motor Type: AC induction motor
Horsepower: 154 HP (115 kW) Maximum
Torque (lb.-ft.): 218 lb-ft. (Normal Mode)/273 lb-ft. (Sport Mode)
Redline (rpm): 14,500
Drive-by-Wire Throttle System
Front-Wheel Drive
CARB Emissions Rating: ZEV
Battery
Battery Type: Li-Ion
Power Output: 129 kW Maximum
Number of Cells: 4,500
Voltage: 386 V
Maximum Usable Capacity (Extended Mode): 41.8 kWh
Weight (lbs.): 845.5
Onboard Charger: 10 kW with maximum 9.6 kW from outlet.
Charger Type: 240V – 40A
Charge Time at 77 degrees F:
Standard Mode (35 kWh)
40A/240V: 5 hours
30A/240V: 6.5 hours
16A/240V: 12 hours
12A/120V: 44 hours
Extended Mode (41.9 kWh)
40A/240V: 6 hours
30A/240V: 8 hours
16A/240V: 15 hours
12A/120V: 52 hours
Display(s): Preview Results - 5 miles/kWh w/ SoC falling from 3/4 to 1/2 SoC over 59 miles.
Transmission
Fixed-gear open-differential trans-axle
Gear ratio 9.73
Body/Suspension/Chassis
Unit-Body Construction
Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear): TBA mm/TBA mm
Motor Driven Power-Assisted Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: TBA
Steering Ratio: TBA
Turning Diameter, Curb-to-Curb (ft.): TBA ft.
Power-Assisted Ventilated Front Disc/Rear Solid Disc Brakes (in.): TBA/TBA
Co-Op Regenerative Braking
Wheels: 17 in. Alloy
Low Rolling Resistance Tires: Yokohama Geolandar G91 P225/65R17
Spare: Inflator Kit
Power and Performance
0 – 60 mph (Normal Mode): 8.6 sec.
0 – 60 mph (Sport Mode): 7.0 sec.
Max Speed (Normal Mode): 85 mph
Max Speed (Sport Mode): 100 mph
Interior Measurements
Headroom (in., front/rear): 40.8/39.7
Legroom (in., front/rear): 41.8/38.3
Shoulder Room (in., front/rear): 57.1/55.3
Hiproom (in., front/rear): 53.8/52.4
Passenger Volume (cu. ft.): 108.2
Cargo Volume (cu. ft.): Rear seats up - 37.2 // Rear seats down - 73.0
Seating Capacity: 5
Exterior Measurements
Wheelbase (in.): 104.7
Length (in.): 180.1
Height (in.): 66.3
Width (in.): 71.5
Track (in., front/rear): 61.4/61.4
Ground Clearance (in.): 5.9
Curb Weight (lbs.): 4,032
GVWR (lbs.): 5,005
Cd: 0.30
EPA Mileage Estimates/Capacities
EPA MPGe: 76 MPGe (EPA early estimate)
LA4 (miles): 173
EPA Range (miles): 92 miles (Standard Mode (35 kWh))/113 miles (Extended Mode (41.8 kWh))/103 miles (EPA homologation early estimate)
Warranty
5-year/60,000-mile Powertrain
8-year/100,000-mile Battery
Colors
Super White (Fleet only)
Blizzard Pearl
Classic Silver Metallic
Shoreline Blue Pearl
