Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
Ford’s 13 Fusion with Auto Stop-Start – An Affordable and Better Starting Solution
Old 07-06-2012, 02:06 PM
xcel's Avatar
xcel xcel is offline
Company touts an actual 3% savings at the pump in real world use.
http://www.cleanmpg.com/photos/data/501/2013_Ford_Fusion1.jpg
Wayne Gerdes - CleanMPG - July 6, 2012
The really sharp looking 2013 Ford Fusion – With the 1.6L EcoBoost, expect a 37 mpgUS highway number. With Auto Start-Stop, maybe a 26 to 27 mpgUS city rating might be in the cards? We’ll know soon enough.
From a release yesterday, Ford is saying it has at least 25 patents pending for the very affordable “$295 Auto Start-Stop option on the upcoming 2013 Ford Fusion.
According to Ford, the ability to shut down the engine when the car isn’t moving has always been one of the most popular features of hybrid vehicles. In reality, the ability to shut down the engine while moving is far more important as we all know but Ford has to start somewhere. I digress… The new Start-Stop system will be available on the new 2013 Fusion with the 1.6L EcoBoost engine.
Auto Start-Stop switches off the engine when the car stops and instantly restarts it when the driver releases the brake.
The new Fusion is the first Ford vehicle to offer Auto Start-Stop with an Automatic. Since an automatic transmission needs to maintain internal hydraulic pressure even with the engine off, Ford added an electrically driven pump to the transmission along with the upgraded starter motor and the higher capacity absorbed glass mat (AGM) battery.
In order to minimize launch delays after a restart, the engineers wanted to keep the transmission in gear even with the engine off as opposed to shifting it into neutral.
The Auto Start-Stop control system is always considering the next engine restart and by monitoring the 12V’s current capacity and driver’s accessory load (radio, headlights, climate control…). It will then decide whether or not to allow a shut down with subsequent spin up and restart moments later. If the electrical load is too high, Auto Start-Stop may be disabled to prevent a rough restart or being stuck with a discharged battery and inability to spin up the engine for a restart.
Voltage blending - While the engine is running, the alternator produces about 14 to 15 volts, but the battery only produces 12 volts with a full charge. When the Fusion is slowing down with Auto Start-Stop enabled, the load model tracks the vehicle speed and deceleration and then calculates when to ramp down the voltage from the alternator to the battery-only level before the Fusion stops. This blending helps to ensure the driver doesn’t experience any light dimming or sudden fluctuations in ventilation fan speed.
The Auto Start-Stop team has filed several patent applications related to the signal monitoring and controls for the climate control system. On hot summer days, the sun’s energy can heat up a car interior within minutes, quickly making things uncomfortable for the driver and passengers. The Auto Start-Stop monitors the temperature of the evaporator core that starts to rise before the occupants even feel a change inside the car. When this happens, the engine will restart sooner allowing A/C to kick in prior to a driver/passenger getting uncomfortable.
The 2013 Fusion with Auto Start-Stop helps drivers save on gas without getting in the way.
While Ford is poising Auto Start-Stop as a way to save upwards of $220 per year, the average owner will more than likely receive a benefit 1/5th of that amount. This still provides an excellent payback at the pump over the life of the car but when it comes time to change the battery 5 to 7-years down the road, lager CAP AGM’s are more expensive reducing the incentive somewhat. In addition, speaking with colleagues that have driven the very seamless BMW Start-Stop system, most turn it off soon after the newness wears off due to the continuous noise of a subdued start motor continuously spinning the motor up after each stop.
When Auto Start-Stop systems are standard equipment from all manufacturers, we will enjoy the fuel savings without having to delve into the cost factors most including myself struggle with when evaluating or setting out to purchase a new car… After all, even $295 to turn the key a few times a day seems like a lot compared to a CleanMPG’ers daily routine.
Old 07-06-2012, 04:20 PM
chilimac02's Avatar
chilimac02 chilimac02 is offline
Bible Scholar, Environmentalist
Vehicles: 2001 Honda Accord; 2009 Honda Pilot
Re: Ford’s 13 Fusion with Auto Stop-Start – An Affordable and Better Starting Solutio
Really wish this feature would be standard on all vehicles.
-Justin
My Bible and Technology Blog: www.bible-tech.com
Old 07-06-2012, 06:52 PM
rfruth's Avatar
rfruth rfruth is offline
Vehicles: 2010 Ford Fusion hybrid
Question Re: Ford’s 13 Fusion with Auto Stop-Start – An Affordable and Better Starting Solutio
I think auto start-stop is great so I built one at ford.com, it was as close to the hybrid as I could get (Fusion SE 1.6 auto start-stop + technology package + moon roof = $ 27.4) the hybrid is better equipped, gets much better EPA numbers for only $ 500.00 more than the SE so why bother with the SE (or is that the idea ?)
Old 07-06-2012, 08:45 PM
Bruce Bruce is offline
cheapskate
Vehicles: 1999 Chevrolet Prizm
Hmph. Finally, an automatic with potential for bump-starting, and the car doesn't need it. Makes you wonder how well a FAS at speed would work.
Old 07-07-2012, 02:25 AM
herm herm is offline
Is it available with a stick shift?
Old 07-07-2012, 02:47 PM
Indigo's Avatar
Indigo Indigo is offline
Witch with wry sense of humor
Vehicles: 2008 Scion xD
I thought that a car had to have a 32-volt system for stop-start. The original Silverado Hybrid, Malibu Hybrid, and a few others all had 32-volt systems.
Indigo's Moral Compass
Love God | Love Each Other | An it Harm None, Do as Ye Will | Blessed Be
http://www.indigohalo.com
Old 07-07-2012, 08:15 PM
rfruth's Avatar
One article says uses software to monitor and maintain battery voltage to ensure that the car can start cleanly and quickly when required, as well as a smart climate-control system that can start the engine early if the cabin gets too hot or too cold. - Thats marketing speak for its a 12 volt system with beefed up starter motor & battery IMO http://www.greencarreports.com/news/...-its-different
Old 07-07-2012, 08:44 PM
RedylC94 RedylC94 is offline
Originally Posted by Indigo View Post
I thought that a car had to have a 32-volt system for stop-start. ...
Why would it?
What about the stop-start Kia Rio? As I understand, it also uses heavy-duty conventional 12-V hardware, plus software to control the stopping and starting.
Generally, I think dual and high-voltage systems are justifiable mainly for components that consume a lot of electrical energy.
Old 07-07-2012, 11:12 PM
xcel's Avatar
Hi Rfruth:
Why did you think it was anything but a 12V system? All basic Stop/Starts use this.
When it comes to assisting or full EV however, than the big packs come in. Not sure why GM's eAssist went that route as they spent a lot of $'s for really no gain vs. their non-hybrid competitors.
Old 07-07-2012, 11:17 PM
Moderator
BAS was a(n overpriced) mild hybrid system rather than just a stop-start system. It had some regeneration and acceleration from a stop to improve fuel economy a little more than a "mini-hybrid" would.
2013 Ford Fusion Adds Start/Stop for Just $295! xcel In the News 32 04-02-2012 07:51 PM
BMW's New Auto Start Stop System Unleaded BMW 1 03-20-2012 10:39 PM
Auto Start/Stop Coming to Non-hybrid Ford’s In The Future xcel In the News 2 01-08-2011 07:24 PM
Some Ford models get start-stop in 2012 atlaw4u In the News 8 12-29-2010 10:41 AM
FAS with an Auto Start/Stop (non-hybrid) diesel? GainfulShrimp Fuel Economy 6 05-30-2010 01:34 PM
