Sport FWD/AWD MSRP: $20,695*/$23,345
Touring FWD/AWD MSRP: $23,895/$25,145
Grand Touring FWD/AWD MSRP: $27,045/$28,295
* Sport FWD is available with 6-speed MT only. Sport AWD, Touring and Grand Touring FWD and AWD are equipped with the 6-speed AT.
Destination: $795
Option Package Pricing
Bluetooth Audio Package (Sport with 6-speed AT only) - $400
Includes Bluetooth, color monitor and HD Radio.
Moonroof/Bose Audio Package (Touring only) - $1,130
Includes – Moonroof, Bose Audio and 9 speakers.
Technology Package (Touring) - $1,185
Includes Navigation, Alarm system, Bi-xenon headlights with auto leveling, Pivoting Adaptive Front-lighting System (AFS), Auto On/Off Headlights, Rain sensing windshield wipers and Auto dimming mirror w/ Homelink.
Technology Package (Grand Touring) - $1,325
Includes Navigation, Mazda Advanced Keyless Entry, Alarm system, Bi-xenon headlights with auto leveling, Pivoting Adaptive Front-lighting System (AFS) and Auto dimming mirror w/ Homelink.
Fog Lights (Sport Only) - $350
Remote Start (Touring and Grand Touring Only) - $525
Sirius Satellite Radio (Touring Only) - $525
Auto dimming rearview mirror with Compass and Homelink - $295
Crystal White Paint (Touring and Grand Touring Only) - $200
Retractable Cargo Cover - $190
All-Weather Floor Mats - $100 (Carpeted Floor Mats are Standard)
Wheel Locks - $55
Engineering
Displacement (cc): 1,997
Horsepower @ rpm: 155@6000 RPM
Torque (lb.-ft. @ rpm): 150@4,000
Redline (rpm): 6,500
Bore and Stroke (mm): 83.5x91.2
Compression Ratio: 13.0:1
Valvetrain: 16-valve VVT
Direct Injection
Drive-by-Wire Throttle System
Front-Wheel Drive
Advanced Direct Ignition System
Transmissions
Gear Ratios
6-Speed Manual Transmission (Sport Only)
1st: 3.700 2nd: 1.947 3rd: 1.300 4th: 1.029 5th: 0.837 6th: 0.680
Final Drive: 4.705
Reverse: 3.724
6-Speed Automatic Transmission
1st: 3.552 2nd: 2.022 3rd: 1.452 4th: 1.000 5th: 0.708 6th: 0.599
Final Drive: 4.624
Reverse: 3.893
Calculated RPM@ 60 mph (MT/AT): 2,264/1,960
Body/Suspension/Chassis
Unit-Body Construction
Independent Multi-link Rear Suspension
Stabilizer Bar (mm., front/rear):
2WD both Automatic and Manual 21/18 and 4WD Automatic 21/19
Electric Power-Assisted Steering (EPAS)
Steering Wheel Turns, Lock-to-Lock: 2.7
Steering Ratio: 15.5:1
Turning Diameter, Curb-to-Curb (ft.): 36.7 ft.
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.7/11.9
Wheels: 17x7.0 (19x7.0 on Grand Touring)
All-Season Tires: Yokohama P225/65 R17
Temporary Mini Spare Tire
Safety
Six airbags (front, side and side-curtain) with rollover protection
Power-assisted ventilated front and solid rear disc brakes
Anti-lock brakes (ABS)
Electronic Brake Force Distribution (EBD)
Brake Assist (BA)
Dynamic Stability Control (DSC)
Traction Control System (TCS)
Hill Launch Assist (HLA)
Daytime running lights (DRL)
Collapsible steering column and fold-away brake pedal assembly
Tire pressure monitoring system (TPMS)
Three-point safety belts for all seating positions
Front seatbelt pretensioners with force limiters as well as Lower Anchors and Tethers for Children (LATCH)
Blind Spot Monitoring (BSM) system standard on Touring and Grand Touring models only.
Interior Measurements
Headroom without moonroof (in., front/rear): 40.1/39.0
Headroom with moonroof (in., front/rear): 39.0/39.0
Legroom (in., front/rear): 41.0/39.3
Shoulder Room (in., front/rear): 57.5/55.5
Hiproom (in., front/rear): 55.2/53.7
Passenger Volume without moonroof (cu. ft.): 103.8
Passenger Volume with moonroof (cu. ft.): 102.3
Cargo Volume (cu. ft.): 34.1 (65.4 with rear seats down)
Seating Capacity: 5
Exterior Measurements
Wheelbase (in.): 106.3
Length (in.): 178.7
Height (in.): 65.7
Width (in.): 72.4
Track (in., front/rear): 62.4/62.5
Curb Weight FWD (lbs. MT/AT): 3,208/3,272
Curb Weight AWD (lbs.): 3,426
Weight Distribution (%, front/rear)
2WD MT - 57:43
2WD AT - 58:42
4WD AT - 56:44
Cd: 0.33
EPA Mileage Estimates/Capacities
6-Speed Manual (City/Highway): 26/35
6-Speed Automatic (City/Highway): 26/32
Crankcase (qt.): 5.2 without filter change and 4.9 with
Coolant System (gal. MT/AT): 7.8/8.0
Fuel (gal.) FWD: 14.8
Fuel (gal.) AWD: 15.3
