Something Everyone Should Read
Old 05-01-2012, 02:29 PM
Ford Man Ford Man is offline
Vehicles: 1988 Ford Escort, 1997 Ford Escort, 1996 Ford Contour
This is something I think everyone should read, especially if they take their car to a garage for repairs. Could save you hundreds or even thousands of dollars on repairs, plus it gives you information on how and who to contact if you think you been scammed in an auto repair.
http://www.youfixcars.com/support-fi...epairguide.pdf
Old 05-01-2012, 02:52 PM
rfruth's Avatar
rfruth rfruth is offline
Vehicles: 2010 Ford Fusion hybrid
Question Re: Something Everyone Should Read
Thanks, it says The best way to protect your fuel system is never run your vehicle below a
quarter of a tank. My question / comment is the fuel pickup is in the bottom of the tank so what difference does it make ?
Old 05-01-2012, 03:06 PM
This would have nothing to do with picking up trash, but the gas in the tank does help cool the fuel pump and will often contribute to premature failure if it's not submerged in fuel and sometimes if you run out of gas running the fuel pump dry will destroy them. I used to run mine down to near empty before filling back up, but have started filling them at 1/4-1/2 a tank in the past several years and haven't had a fuel pump failure since. I've also read that younger drivers usually have higher rates of fuel pump failures and they suspect it's because most of them drive with the tank near empty most of the time.
Old 05-01-2012, 03:49 PM
aca2983 aca2983 is offline
Vehicles: 2000 Protege ES
I've been driving for 25 years, fill my tank when it is on E, and have never had a fuel pump failure on any vehicle, regardless of miles put on it. Just sayin'...
I still miss my 83 Civic.
Old 05-01-2012, 06:09 PM
herm herm is offline
Moderator
the scary part is that the submerged fuel pump uses a brushed DC motor, and those generate lots of sparks.. how come cars dont explode all over the place?.. and yes they do wear out, get an OEM replacement unless you want to drop the tank again 6 months later..
Old 05-01-2012, 06:57 PM
worthywads worthywads is offline
Vehicles: 2005 Toyota Tacoma
+1
Old 05-01-2012, 07:30 PM
ILAveo ILAveo is offline
Vehicles: 03 Ranger(mostly), 07 Aveo(sometimes), 96 Taurus(occasionally), 01 saturn SL1 (rarely)
Pretty much any gasoline tank that is at least partially full is outside of the flammable range because its vapors are too rich. It is the tanks that look empty but still have residual fumes that are the explosion hazard.
Old 05-01-2012, 08:44 PM
all_about_the_glide all_about_the_glide is offline
Vehicles: 2007 Honda Civic Hybrid
Anecdotal, but only fuel pump I've ever had go wrong was on my wife's saab and she fills at close to a quarter tank just about every time, where I've been known to drive on vapors.
Much to her disbelief, I replaced the electric motor inside the pump myself...access under the rear passenger seat, went to google U to learn how to make the removal tool out of PVC.
Old 05-02-2012, 03:20 PM
Aftermarket fuel pumps are often as good as OEM. I've had a replacement fuel pump in my '88 Escort that came from Auto Zone it's probably been in for 10+ years and over 200K miles.
Old 05-22-2012, 03:07 PM
xcel's Avatar
xcel xcel is online now
Probably 2,000 tanks in my lifetime and most to below E. Never had a fuel pump failure... Yet
Scangauge on FFH - Can't read SOC? turbotaguy Ford Fusion/Lincoln MKz Hybrid 23 02-13-2013 11:23 AM
Read my lips!!! micman Hero and Jerk of the Day 10 09-03-2011 10:19 AM
OMG read this from AAA Aether glider Fuel Economy 19 06-27-2008 07:22 AM
Read this in car and driver.....what do you all think? shovelhead91701 Other Manufacturers 9 03-24-2008 08:46 PM
