Tire size and FE
Tags: , , ,
Old 04-20-2012, 08:40 AM
Apabob Apabob is offline
Vehicles: 1980 Volkswagen Dasher (1.5L N/A Diesel)
Lightbulb Tire size and FE
I dont know how often this has been referenced here but i just thought id mention an example of tire size and how it affects my FE.
I have a small, slow car with a 4 speed manual tranny. Needless to say, highway speeds really tend to wind the piss outa my engine.
Ive recently switched my small diameter snow tires (155/80 R13)out for some substantially larger diameter all-seasons (185/80 R13).
The advantages are tremendous for my particular situation. The greater diameter of the tires effectively stretches my gear ratio, making traveling at 70 mph feel a little less like im whipping a horse to death.
The other side of that particular coin, is less mechanical advantage on takeoff (dead stop). Thats not at all an issue for my little diesel but could be something to consider in another vehicle.
And finally, the larger wheels just plain roll better. They are not slowed nearly so much by bumps in the road and my car will roll so much further every glide its amazing.
Ive seen psi and low resistance rollers mentioned here alot, and with very good reason, but i thought tire size deserved a bit of attention too.
Something to consider...?
Old 04-20-2012, 08:43 AM
PaleMelanesian's Avatar
PaleMelanesian PaleMelanesian is online now
Beat The System
Re: Tire size and FE
Someone did controlled testing on this and found it to be a benefit. Sentra se-r I think it was? The larger tires will hurt you if you do a lot of stop-n-go and braking. There's a lot more momentum in the larger diameter spinning tire that's wasted if you brake. If you coast instead, you get that momentum back in extra distance traveled so it's a wash. Then the lower rpm can help you.
Andrew
Old 04-20-2012, 08:55 AM
I didnt consider the greater energy present due to the Centrifugal force of the larger dia tire. Thats an interesting consideration.
I reealy notice how much less small bumps affect speed. The mechanical advantage (leverage) of the larger diameter tire allows for smoother rolling. They just climb the bumps better!
Old 04-20-2012, 09:24 AM
ALS's Avatar
ALS ALS is online now
Moderator
You can play with a Gear/Tire calculator to see the highway benefits of going to a larger diameter tire. On my old Volvo by switching to a 205/55/16 tire (optional) over the stock
195/60/15 it was about a 100 rpm drop over all at 65 mph. Hey every bit helps. I wish when I got new tires for my 960 I had gone to a 205/60/16 over the stock 205/55/16's.
Be carefull when doing this so that you don't get rubbing issues.
Old 04-20-2012, 09:37 AM
Dream'R Dream'R is offline
Vehicles: '08 HCH II, '05 Accord I4 5AT
By my calculations you have increased your tire diameter by 6.8% which is a significant difference. As I'm sure you realize, your speedometer and odometer will be altered by the same difference. I'd be curious to hear if your fuel economy has improved by even more than compensating for this factor. It would seem very likely if for no other reason than the change from snow tires to all seasons usually reduces rolling resistance. My Civic hybrid's mpg improves at least 5% when I switch my tires over in the Spring.
I have no evidence to back this up but my instincts tell me that taller, narrower, high pressured tires roll easier -- think road bicycles versus mountain bikes!!
Cheers,
Roger
Old 04-20-2012, 09:41 AM
Right Lane Cruiser's Avatar
Penguin of Notagascar
A small nitpick here -- it isn't "Centrifugal force" (which doesn't actually exist -- Wikipedia reference-linkcentripetal force does) but rather Wikipedia reference-linkangular momentum.
- Sean
New? Start here!
Old 04-20-2012, 09:43 AM
Beat The System
http://xkcd.com/123/
Andrew
Old 04-20-2012, 09:51 AM
herm herm is offline
are there any LRR tires in 13" or 14" sizes?.. its discrimination!
Old 04-20-2012, 09:57 AM
Beat The System
I know!
but really, there are some. Especially the one Sean's about to mention.
Andrew
Old 04-20-2012, 09:58 AM
Sure there are, Herm -- the first gen Insight uses P165/65R14. Only that size of the OEM spec'd tire is ultra LRR construction but it does exist.
Great cartoon, Andrew! And nice premonition, too.
- Sean
New? Start here!
95 Civic EX Tire Size KrazyDawg Honda 11 04-17-2013 11:20 AM
What size tire should I get for 08 Fit Sport? CptanPanic Honda 1 07-19-2010 07:25 AM
Tire Size Calculator drimportracing General 1 06-21-2010 06:40 AM
tire size the rookie Toyota 7 01-04-2009 10:26 AM
Tire size change for better mpgs? auto-xr Technical 6 05-31-2008 02:42 AM
