CleanMPG Plays Its Hand in Las Vegas with a Pair of (MPG) Kings
Old 04-12-2012, 09:30 AM
xcel's Avatar
xcel xcel is offline
The 40mpg Gamble - Can Two Family-Size Compacts Meet or Beat Their EPA Highway MPG_Estimates?
Chris Bernius and Wayne Gerdes - CleanMPG - April 12, 2012
At right, a goofy vid of the 40 mpg Gamble on a Vegas or Bust adventure.
A Pair of MPG Kings - The 2012 Chevrolet Cruze ECO (EPA 39 mpgUS highway) and the 2012 Hyundai Elantra GLS (EPA 40 mpgUS highway), both roomy enough for a Full House, are ready to try their luck in Las Vegas.
Not shown - A pair of Jokers, who brought the MPG Kings to Las Vegas and back, on an 823 mile loop, with traffic and terrain that was anything but mpg-friendly.
The Handicap - Both equipped with automatic transmission. Tire pressures set to the recommended (door jamb) pressures of 32psi for Elantra, 35psi for Cruze.
Both cars to be driven at the posted speed limit with the cruise control engaged on open roads when safe to do so, except for during steep mountain grades (up or down), where neither manufacturer recommends the use of cruise control.
Temperatures starting and ending in the mid-50F range, with warmer temperatures during mid-day.
Terrain varied from almost a mile above sea level to over 200 feet below, with dozens of miles of 6 plus % mountain grades logged in between. Sporadic traffic tie-ups on the freeways and traffic congestion along the famous Las Vegas strip.
The Odds - Starting with the 2008 Model Year, the EPA introduced new offsets or the choice to incorporate the new "5 cycle" testing, including starting from sub-freezing temperatures, air conditioner usage, and a short drive at higher speeds with the promise that the resulting numbers on the Monroney (new car window) sticker would be "more realistic" for the majority of new car buyers.
These new EPA estimates are an easy target, making the 40mpg Gamble a "safe bet". To add some suspense, and stack the odds against our MPG Kings, we will want to introduce some wildcards - those elements that are unknown to the sterile hypothetical alternate-reality found only in the EPA's test parameters.
  • The tests do not include hills or mountains although some heavy acceleration and deceleration is involved during one of the five test cycles. Our challenge will take us almost a mile above sea level - not once but several times, and down to a depth of almost 230 feet below sea level. For comparison, the Andrea Doria wreck lies 240 feet below the ocean surface.
  • The tests are run in a straight line - the steering wheel is never turned. Our challenge includes some hair-raising mountain curves and plenty of on/off ramps, surface streets, and other deviations from straight ahead. Turning the steering wheel involves a loss of inertia, as momentum is converted to body lean as the car tracks through a corner.
  • The tests are run with straight gasoline and the lower energy content of E10 reduces fuel economy.
  • The tests do not take into account wind from any direction. Our challenge includes flag-snappin' tent-topplin' winds from the southwest between 20 and 40mph.
  • Other than the single higher speed test, the rest incorporate a series of gentle stops. Our challenge takes us to traffic lights whose timing is unknown; with cross traffic able to change a green to red with little warning. Many of these lights were found along high speed secondary roads, where much more energy can be lost when braking from those higher speeds.
In simplest terms, the EPA test procedure is a sort of "Sim City" game where cars are driven only in climate-controlled laboratories in perfectly straight lines on perfectly flat glass-smooth surfaces, using theoretical fuel that the vast majority of us can't actually buy, thanks to... the EPA.
With the rules of the game established, and the players vetted, prepped for the tournament, and ready as they'll ever be, we will play the hand we were dealt and let the chips fall where they may.
Ante Up!
The 2012 Chevrolet Cruze ECO brings a nice stack of high-dollar chips to the table, and it's ready to play.
  • Safety - Ten standard air bags, ABS and traction control, StabiliTrak, and OnStar with Automatic Crash Response.
  • Fuel Economy - The small 1.4 liter four cylinder engine is turbocharged, offering 138 horsepower and a torque curve so flat it can double as a bowling alley. The strategy of tall gearing and force-feeding a small displacement engine works well in the Cruze, where acceleration is class competitive while offering excellent highway fuel economy.
  • Space - 94.6 cubic feet for passengers, 15.4 cubic feet of cargo volume, total 110.0 cubic feet.
  • Value - The Cruze Eco has an MSRP of $22,895 as tested, including navigation, and driver convenience package.
The 2012 Hyundai Elantra brings an even more impressive stack of blue chips to toss onto the table.
  • Safety - Six standard air bags, ABS and traction control, and stability control.
  • Fuel Economy - The 1.8 liter four cylinder engine provides 148 horsepower without the need for turbocharging or direct gas injection. Hyundai uses CVVT (continuously variable valve timing) on both cams, diamond-like coating on friction surfaces, a variable intake system with short and long intake runners, and an offset crankshaft to improve the efficiency of the engine. Rather than "bolting on" more horsepower or higher mpg, Hyundai pursues the approach of engineering the powerplant to deliver the best of both along with simplicity and durability.
  • Space - 95.6 cubic feet for passengers, 14.8 cubic feet of cargo volume, total 110.4 cubic feet.
  • Value - The Elantra GLS with Preferred package has an MSRP of $19,065 as tested.
Ladies and Gentleman, Place Your Bets.
Placard all around on both vehicles. 35 psi for the Cruze ECO and 32 psi for the Elantra GLS.
2012 Chevrolet Cruze Eco
Tire Pressures: RF -- RR top and LF -- LR bottom.
Initial top off fill at a Valero in National City, just southeast of San Diego, California
Reset displays. The Cruze ECO had 4,612 miles and the Elantra GLS had 1,331 miles on their respective odometer(s).
Cajon Pass Sees Your Bet and Raises It 4,200 Feet
This is the first of many climbs to well beyond 4,000’ with plenty of traffic to slow us down along the way. Cruise Control speeds are 60 to 70 mph when traffic allows, and the average is 54 mph for the trip as the two Kings head skyward over the Cajon Pass. Wind conditions stacked the deck against our two Kings, but they kept up their poker face and didn't let anyone see them sweat.
2012 Hyundai Elantra and Chevrolet Cruze
Heavy traffic on the I-215.
Cresting Cajon Pass on I-15.
59 mph average just a few miles into the US-395 slow down.
Climbing to the West Entrance of Death Valley National Park.
The 40mpg Gamble Involved climbing to 4956 feet and then descending to -246 feet in less than an hour.
Cruze ahead in the sand storm. 30 to 40 mph cross winds. The EPA test procedures only include 25mph cross winds. ... NOT!
A Pair of MPG Kings Cruisin' The Strip
The Chevrolet Cruze ECO, with an EPA 26mpgUS city rating, waits patiently at a red light on the Vegas strip.
Lay Your Cards On The Table
Round Trip Route Map
823 miles per Google Maps
After stopping for the night, the first fill in Barstow, California
15.137 gallons consumed after 642.0 miles per Google maps = 42.413 mpgUS.
13.557 gallons consumed after 642.0 miles per Google maps = 47.356 mpgUS.
The pumps at this Shell station were fast flowing so the Elantra was possibly short by .25 plus gallons without spilling after another 10 or more top offs with violent shaking between. The slow fill pumps at the Velero in Nations City where we initially filled would give us an accurate final fill and totals once we got there.
The Cruze ECO with the AT’s odometer/Trip A/B were almost dead on whereas the Elantra was showing the usual -2.2% under report which is good for customers since they earn another 2.2% on their warranties.
30+ mph headwinds from Barstow to Cajon Pass while heading back to San Diego on the I-15.
Final fill in National City, California
OEM aFCD: 180.3 miles - 47.4 mpg - 57.1 mph avg. speed.
181 actual miles on 4.116 gallons = 43.975 mpgUS.
OEM aFCD/Trip A: 176.7 miles - 42.8 mpg.
181 actual miles on 4.486 gallons = 40.348 mpg and making up for the .25 to 0.35 gallon short fill in Barstow, CA.
The Final Fill at the same Velero in National City, CA some 32 hours and 823 miles later.
2012 Chevrolet Cruze ECO vs. 2012 Hyundai Elantra - Final Results
VehicleVehicle Avg SpeedOdometer (miles)Actual milesFuel (gal)Actual MPGaFCD (mpg)aFCD offset (%)Over/Under EPA Highway
Elantra GLS54.9804.882318.04345.61344.0-3.54%+14.0%
Cruze ECO54.9821.582319.25342.74745.8+7.14%+9.6%
http://www.cleanmpg.com/photos/data/501/APairOfKings.jpg
You Got To Know When To Hold Em, Know When To Fold Em
Both players were evenly matched with one taking home the lion's share.
Elantra - 40mpg highway rating, 45.613mpg actual, 114.0% of EPA
Cruze Eco - 39mpg highway rating, 42.747mpg actual, 109.6% of EPA
The Elantra GLS proved to be the stronger contender by breaking the EPA bank by an almost 15% margin with the Cruze Eco taking home more chips than it started. Anytime you leave Vegas with more than you started, you’ve beat the odds and this pair of Kings did just that.
This challenge was anything but an easy highway drive.
These are two MPG Kings that fall under the "Hold Em" category. As the cost of a gallon of regular passes $4/gal and may be heading for $5/gal, either one of these two MPG Kings will definitely be an "ace up your sleeve".
Old 04-12-2012, 10:14 AM
msirach's Avatar
msirach msirach is offline
Re: CleanMPG Plays Its Hand in Las Vegas with a Pair of (MPG) Kings
It was good to see that both turned out so close to each other and at only a small margin above EPA estimates but in REAL WORLD driving conditions. Driving with turns, wind, and mountains certainly leave room for a far lower number than EPA. Congrats!
Read The CleanMPG Primer!
Old 04-12-2012, 10:28 AM
bestmapman's Avatar
bestmapman bestmapman is online now
Vehicles: 2010 Toyota Prius, 2009 Kawasaki C-14
Great comparison.
Drivin slow in the FAS lane.
Old 04-12-2012, 10:42 AM
rfruth's Avatar
rfruth rfruth is offline
Vehicles: 2010 Ford Fusion hybrid
Thumbs up Re: CleanMPG Plays Its Hand in Las Vegas with a Pair of (MPG) Kings
Makes me want to Cruze !
Old 04-12-2012, 11:20 AM
herm herm is offline
Congratulations guys!
Next time you drive around Death Valley try a higher octane gasoline.
Old 04-12-2012, 12:25 PM
thunderstruck's Avatar
thunderstruck thunderstruck is offline
Moderator
Vehicles: 2013 Passat SE 6 Manual
Any way you'd be able to get a Cruze diesel to repeat the test? Would love to see now what we have to look forward to in 2013.
Old 04-12-2012, 12:40 PM
bullwinkle428 bullwinkle428 is offline
Vehicles: 2002 Honda Accord EX Sedan (5-speed manual)
Is there a significant difference in the RPMs at that constant 60 mph if one were to make the same run with the manual transmission versions of Cruze and Elantra, to the point where the final numbers would be affected either negatively or positively?
Old 04-12-2012, 01:25 PM
MaxxMPG's Avatar
MaxxMPG MaxxMPG is offline
Anyone who doubts we were maintaining the posted speed limit of 65mph should know that I picked up a "food-borne illness" at some point over the prior 36 hours, and by early Sunday morning, it was at category-three. From Barstow to National City, I ate nothing and drank no water, because I didn't want the two players in the game to have to pause for a Royal Flush. It was definitely not an appropriate time for a hundred miles of P&G'ing close to the posted minimum limits.
The lesson learned from The 40mpg Gamble is that both cars offered more than their EPA highway ratings, even with traffic, terrain, and trying headwinds that do not exist within the HWFET or any other EPA test.
Old 04-12-2012, 02:04 PM
philmcneal's Avatar
nice hand wayne! love the test do more with different cars in the future!
Old 04-12-2012, 08:31 PM
ALS's Avatar
ALS ALS is offline
Moderator
This proves if your looking for gas mileage the Cruze and the Elantra are both equally qualified to handle the job.
Mileage Kings ALS In the News 5 10-21-2010 04:19 PM
Kenworth T370 Hybrid plays its part in NY City xcel Commerical Transportation 0 08-24-2009 07:37 PM
Friends wanted for Cedar Point / Green Drive Expo 2009 / Kings Island trip TheForce General 9 07-02-2009 12:21 PM
My Trip --Las Vegas - Washington DC - Michigan - Vegas = 5400 miles highflyer_i469 The Daily Grind 5 07-23-2007 02:36 PM
Research plays down ethanol's potential. xcel In the News 3 07-12-2006 07:05 PM
