MSRP: $15,895
Destination: $775
Options Pricing:
6-speed AT - $1,000
Carpeted Floor Mats - $95
Engineering:
Displacement (cc): 1,591 cc
Horsepower @ rpm: 138@6,300
Torque (lb.-ft. @ rpm): 123@4,850
Redline (rpm): 6,700
Bore and Stroke (mm): 77x85.44
Compression Ratio: 11.0:1
Valvetrain: DOHC 16-valve with Dual Continuously Variable Valve Timing (D-CVVT)
Gasoline Direct Injection (GDI)
Drive-by-Wire Throttle System
Front-Wheel Drive
CARB Emissions Rating: LEV-2
105,000-Miles-or-More Tune-Up Interval
Transmissions:
Gear Ratios
6-Speed Manual Transmission
1st: 3.769:1
2nd: 2.045:1
3rd: 1.286:1
4th: 1.036:1
5th: 0.893:1
6th: 0.774:1
Final Drive: 3.64:1
Reverse: 3.545:1
6-Speed Automatic Transmission (available)
1st: 4.400:1
2nd: 2.726:1
3rd: 1.834:1
4th: 1.392:1
5th: 1.000:1
6th: 0.774:1
Final Drive: 2.93:1
Reverse: 3.440:1
RPM@60 mph (MT/AT): 2,397/1,930
Body/Suspension/Chassis:
Unit-Body Construction
Torsion Beam Rear Suspension
Stabilizer Bar (mm., front/rear): None
Electrically Power-Assisted Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: 14.9:1
Steering Ratio: 2.9:1
Turning Diameter, Curb-to-Curb (ft.): 34.12 ft.
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 10.1/10.3
Wheels: 16c6.0 Alloys
All-Season Tires: P195/50HR16
Compact Spare Tire
Interior Measurements:
Headroom (in., front/rear): 39.9/37.2
Legroom (in., front/rear): 41.8/33.3
Shoulder Room (in., front/rear): 53.7/53.4
Hiproom (in., front/rear): 51.3/47.2
Cargo Volume Rear Seats Up/Down (cu. ft.): 21.2/47.5
Passenger Volume (cu. ft.): 90.1
Seating Capacity: 5
Exterior Measurements:
Wheelbase (in.): 101.2
Length (in.): 162.0
Height (in.): 57.1
Width (in.): 66.9
Track (in., front/rear): 59.3/59.5
Curb Weight (lbs. MT/AT): 2,430 2,588/2,496 2,654
6-Speed Manual (City/Highway/Combined): 30/40/34
6-Speed Automatic (City/Highway/Combined): 30/40/33
Crankcase (qt.): 3.49
Coolant System (qt. MT/AT): 4.7
Fuel (gal.): 11.4
