Go Back   CleanMPG Forums » Our Community » Off-Topic
Off-Topic If it doesn't belong anywhere else you will find it here.
Storm Shelters - Above Ground
Tags: , ,
Old 02-02-2012, 02:17 PM
Die2self Die2self is offline
Saving more by using less!
Vehicles: 2011 Honda Fit 5MT (Silver), 2003 Honda Accord LX 5MT (Graphite)
Hey, with storm season right around the corner here in SW MO, I was wonder who in out communite has an above ground storm shelter?
We are looking at purchasing one of the steel structures and I wanted to know if anyone knows of a good place to buy from? We are looking for a local manufacture (like twistersafe), but I just wanted to see if any one knew of federal grants that we could get. I can't find anything from the state of MO and the City of Joplin doesn't have anything set yet to help with the cost.
We were extremely fortunate to have survived the EF5 tornodo that passed only 2 blocks from our house last May and let me tell you riding it out in the hall way is not what I want to do again with my family.
Any thoughts or assistance that anyone may know of out there for defraying the cost or if you know of a good company to work with.
Maybe I can hire Larry to come down and weld up a safe room for us
-Jason
Fit
Best: 61.35 MPG / Longest: 711.1 miles (8/8/14)
Best Seg: 91.5 / 1.2 miles (urban)
Truck - Best tank:516@25.06MPG (traded)
Old 02-02-2012, 08:12 PM
basjoos's Avatar
basjoos basjoos is offline
Re: Storm Shelters - Above Ground
I'm getting ready to build an underground earthbag dome as a tornado shelter. Earthbag is an inexpensive method of building a tornado shelter and can be built above ground as well. It will eventually be the underground portion (along with a root cellar) of a cob house that I plan to build. I want to have a house (unlike the typical crackerbox house made from 2X4's and drywall) that won't be scattered across a dozen counties when a tornado comes visiting. With heavy earth walls over 2 feet thick, the worst damage that a tornado could do to a round cob house is maybe break a window and possibly cause some roof damage. Cob is also soundproof, fireproof, termite proof, and earthquake resistant.
aerocivic.com
Old 02-04-2012, 10:16 AM
EdwinTheMagnificent EdwinTheMagnificent is offline
Legend In His Mind
Vehicles: 2008 Honda Civic LX auto
Basjoos , what is a cob house ? Is it made of, or insulated by corn cobs ? It sounds interesting.
Edwin
Old 02-06-2012, 08:18 AM
basjoos's Avatar
The term "cob" comes from a Welsh word for "lump", referring to the lumps of cob mix plopped unto the top of the wall when constructing it. The walls of a cob structure are made of a mix of sand, clay, straw. The walls are built up of the wet mix and allowed to dry and, for outer walls, are typically at least 2 feet thick. Unlike adobe, to which it is related, cob dries into a monolithic structure where the straw act as a continuous rebar mesh to make it earth quake resistant and its massive weight means that no tornado will be able to shift it. The roof is built into and imbedded into the top of the cab wall and if screws rather than nails are used in its construction, should withstand tornadic winds with little damage. You can make cob walls into all sorts of free-form shapes (almost like sculpting the house) so you can build a tornado proof house using rounded walls with no corners, which are more wind resistant than the typical "straight walls with corners" house. In Britain, there are cob houses in current use that are several 100 years old. Google "cob house" for more info.
aerocivic.com
Last edited by ItsNotAboutTheMoney : 02-07-2012 at 06:50 PM. Reason: Generous people, they are.
Old 02-06-2012, 07:31 PM
Legend In His Mind
Thank you !
Edwin
Old 05-22-2012, 03:23 PM
sorry I ment to get these posted before. We got a shelter built by a friend and installed on 4/12/2012
It is 4.5 feet wide, 4.5 feet high and 8 feet long
it is being held down to the concrete with 12 HILTI 3/4 inch concrete bolts (each rated to 30,000 lbs load and 15,000 lbs shear.)
it is all constucted of 1/4 inch steel plate, including the floor and with all 1/4 angle iron around the frame. The door has three 1 inch pins that lock into the door frame when the latch is closed and held in place by a pin)
There is an electrical inlet built in but I don't have electricy running to it right now. All Battery lights, fan and a few fold up charis. We feel much more ready now. I have placed the kids in it once since it was installed.
Door closed.
Installed with Door open
Inside with built in bench
VREY BEEFY
-Jason
Fit
Old 05-22-2012, 03:47 PM
FSUspectra's Avatar
FSUspectra FSUspectra is offline
Practicing true conservatism!
Vehicles: 2005 Kia Spectra EX 5spd, 2006 Honda Accord LX-SE VTEC 5spd, 2007 Kymco People S 250
Very good looking little shelter there. Here's to hoping you'll never have to use it!
- Brandon
Best Segment - 76.5 MPG / 2.8 mi
Best Tank - 748.6mi @ 45.1 MPG 11/11/12
New to the site? Start here! Welcome to CleanMPG Primer
Old 05-22-2012, 05:43 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
What's on the other end of your vent ducting?
- Sean
New? Start here!
Old 05-22-2012, 05:53 PM
TheStepChild TheStepChild is offline
Vehicles: 13 Volt, 12 Express Cargo
does the fan pump air in, and is it filtered?
Old 05-22-2012, 06:07 PM
Moderator
Vehicles: 2010 Toyota Prius II, 2013 Chevrolet Volt
Whatever they did, I bet they didn't do it again.
Ground Straps lxmike 2000 - 2006 Honda Insight I 1 08-12-2011 05:47 PM
Ice Storm psyshack Weather 10 02-09-2010 10:14 AM
Ct's Perfect Storm(aaa/csp/cbs) 97PROTEGE Website news & discussions 12 07-04-2008 11:42 PM
Gaining ground fitmpg The Daily Grind 5 01-10-2008 01:44 PM
Breaking Old Ground ascribe2thelord The Daily Grind 18 01-04-2008 10:43 PM
