"Brake-lock differential is a more advanced ABS which the chief platform engineer will be sending us more information on later."
Brake lock differential is explained here, its a low cost way of implementing a locking differential:
http://blog.chryslerllc.com/blog.do?p=entry&id=270
"To understand what BLD does, it is necessary to understand how and open differential works. Open differentials have many attributes that make them the best choice for most vehicles. They are simple, proven and reliable requiring only an occasional fluid change to last for many years.
For rear wheel drive vehicles, they also provide a stability advantage over locking differentials (such as a Detroit Locker) that are always engaged.
The main drawback to an open differential is that torque is always split 50/50. Each wheel receives 50% of the input torque (ignoring losses). This means that if one wheel is in the air and it takes almost no torque, say 10 ft-lb., to turn the wheel, the other wheel will only receive 10 ft-lb. of torque. If 10 ft-lb. is not enough to move the vehicle in the desired direction, it will not move.
Using the vehicle’s wheel speed sensors, BLD knows when one wheel on a driven axle is turning and the other is not. BLD will apply brake pressure to the wheel that is turning.
The applied brake pressure increases the torque required to turn the wheel in the air and this allows more torque to go to the wheel on the ground. The one drawback is that the input torque must be twice as much as required to negotiate the obstacle because of the brake application. The required extra torque is not usually a problem especially in 4wd low range."
