DIY coolant heater install
Old 11-21-2011, 07:16 AM
TheStepChild TheStepChild is offline
Vehicles: 13 Volt, 12 Express Cargo
This install is on an 88 Ranger. Your vehicle may vary but the general ideas are the same.
1st off - follow you vehicle manufacturers recommended safety instructions for safely and properly jacking/lifting your vehicle. We're not discussing safety issues here, you are responsible for following safe work practices .
2nd - dispose off used coolant in accord with all local/state/federal rules.
For this project I needed:
Flat screwdriver
Large tote for draining coolant into. I like the ones that can slide under a bed, low profile but wide and big enough to catch the coolant.
Enough new coolant and water to refill.
A lower radiator hose coolant heater.
Sharp cutting instrument.
Start by draining the coolant. Make sure coolant and engine are cool. This truck has a drain plug on the radiator, but not all do.
Take off radiator cap to help drain.
After all that is going to drain drains, I pulled the lower radiator hose off. Here's a couple pics.
After the hose is out you need to cut a small section out for the heater. I'm starting with about this much:
You want to cut it out on a good, straight section of hose. Pretty easy to find on this ranger.
More after work...
And I have to buy the heater too, Haha. Hopefully they still have one in stock. But I had to get the hose off and measure it to know which size to get.
Old 11-21-2011, 04:22 PM
Re: DIY coolant heater install
Here is the coolant heater I used, its 600 watt, $26.49 out the door. Should be good for this 2.0L
Instructions say mount it 1-with the heater pointing towards the water pump. 2-as close to pump as you can, 3-lower than the pump, and 4 cap facing down
Here's where I put it:
route the power cord out of the way of all moving parts.
refill radiator according to your vehicle manufacturers instructions.
Old 12-28-2011, 02:04 AM
bassplyer92517's Avatar
bassplyer92517 bassplyer92517 is offline
Alex
Vehicles: 2000 Ford Ranger XLT V6 3.0L
Wow, great idea! What kind of MPG increase you looking at with this thing? I've got my Ranger too, definitely thinking about doing this.
2000 Ford Ranger XLT Supercab V6 3.0L 2WD Auto
Old 12-28-2011, 03:47 AM
Idk.
This ranger is carb'd and I noticed it does not like to be Eugene until it decides its warmed up. A manual choke would help too I think but I'm not doing it.
It really does help, I can start driving with no warm up period now.
Haven't driven it in a couple weeks. Got a friends Tacoma and have been driving that instead. Tacoma goes bye bye today tho so I'm back in the ranger.
I did just put snow tires on the ranger too, and the correct size tires. So I may not be able to get an accurate before/after comparison
Old 12-28-2011, 10:38 AM
herm herm is offline
600w in a small package, I hope the plastic does not melt.
Old 12-28-2011, 12:03 PM
Alex
That's very cool! Definitely going to think about doing this.
Old 12-28-2011, 12:14 PM
it shouldnt. Thats what its made for. Ive had it run on a timer for 5 ish hours. no problems yet.
Old 03-09-2012, 07:02 AM
2Evil4U 2Evil4U is offline
Vehicles: '03 Dodge Stratus R/T Coupe, 3.0L, 5spd
This thread got me thinking. My Strat idles at 2500rpm until it is nearly completely warm. It is chronically annoying.
I just ordered a freeze plug block heater to fix that. $15 shipped fom Amazon.
Good thoughts.
Old 03-10-2012, 05:57 PM
Just installed the new freeze plug/block heater. Surprisingly easy to access on the Mitz 6g72 in my Stratus. Took a bit to get the old plug out, but the new one fit perfectly and the hardest part was routing the cord to not touch anything hot.
In process of testing to see how it works.
Old 03-10-2012, 06:02 PM
That was quick..
Toyota Block Heater MiHG Install Party bradlee Events and Gatherings 9 03-29-2012 06:03 AM
Chicagoland engine block heater install event FireEngineer Events and Gatherings 2 09-18-2009 12:39 PM
ChicagoPriusGroup Engine Block Heater Install Event Oct. 20. FireEngineer Events and Gatherings 2 09-14-2007 03:21 PM
MiHG Prius Block Heater Buy and Install bradlee Events and Gatherings 0 08-01-2007 06:21 PM
MiHG Prius Block Heater Install 2-10-07 bradlee Events and Gatherings 5 02-17-2007 11:16 PM
