2012 VW Passat TDI Specifications
MSRP: $25,995
Destination: $770
The TDI base trim, the SE, arrives with standard features including the following:
- 17-inch alloy wheels
- Exterior chrome window trim
- Keyless entry
- V-Tex leatherette seating
- Multi-Function leather-wrapped steering wheel w/ CC, audio and Bluetooth controls
- 8-way power driver seat
- Heated front seats
- A/C
- Dual zone automatic climate control
- Trip computer
- Radio-CD system (MP3-capable, plus external audio input)
- Touchscreen premium VIII radio
- Bluetooth connectivity
- One touch up/down power windows all around
- Elegant and distinctive analog clock at the center of the instrument panel
- Outside temperature display with frost warning
- Aluminum trim dash and middle console
- Sliding front center armrest
- Automatic headlights with automatic coming and leaving home feature
- Insulating glass
- Two 12V power outlets
- Rear center armrest with integrated cup holders
- 60/40 folding rear seat
Options Pricing:
$1,900 – TDI SE with Sunroof: Adds in addition to the SE, a six-speed DSG automatic transmission and sunroof.
$3,500 – TDI SE with Sunroof and NAVI: Adds in addition to the SE with Sunroof, 18” alloy wheels, RNS 315 Navigation, Mobile Device Interface (MDI), fog lights and exterior chrome accents.
$6,200 – TDI SEL Premium: Adds in addition to the SE with Sunroof and NAVI, leather seating surfaces, comfort sport seats, keyless access and remote start, RNS 510 Navigation, Fender Premium Audio System, driver seat memory, wood grain interior dιcor, 8-way power passenger seat and interior chrome accents.
Engineering:
Engine Block/Cylinder Head: Cast Iron/Aluminum-Alloy
Displacement (cc): 1,968
Horsepower @ rpm: 140@4,000
Torque (lb.-ft. @ rpm): 236 @ 1,500 to 2,500
Redline (rpm): 5,000
Bore and Stroke (mm): 81.0 x 95.5
Compression Ratio: 16.5:1
Valvetrain:
Belt driven DOHC w/ 4-valves per cylinder, hydraulic lifters and single valve springs
Intake: Electronically controlled Direct Fuel Injection w/ Turbo charger
Drive-by-Wire Throttle
Front-Wheel Drive
CARB Emissions Rating: ULEV-2
Required Diesel Emissions Fluid (DEF)
Transmissions:
Gear Ratios - 6-speed Manual/Automatic Transmission(s)
1st: 3.77/3.46
2nd: 1.96/2.05
3rd: 1.26/1.3
4th: 0.87/0.9
5th: 0.86/0.91
6th: 0.72/0.76
Final Drive I: 3.68/4.12
Final Drive II: 2.92/3.04
Reverse: 4.56/3.99
Calculated RPM@ 60 mph:
1,624 RPM!!!/1,785 RPM
Body/Suspension/Chassis:
Unit-Body Construction
Four-link independent Rear Suspension
Stabilizer Bar (mm., front/rear): TBA/TBA
Electro-Mechanical Power-Assisted Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: 3.0
Steering Ratio: 16.4:1
Turning Diameter, Curb-to-Curb (ft.): 36.4 ft.
Power-Assisted Ventilated Front Disc/Rear Disc Brakes (in.): 12.3x1/10.7x0.4
Wheels: 215/55 R17 All-Season Tires – Optional 235/45 R18
Full-sized aluminum alloy spare wheel and tire
Interior Measurements:
Headroom (in., front/rear): 38.3/37.8
Legroom (in., front/rear): 42.4/39.1
Shoulder Room (in., front/rear): 56.9/57.0
Hiproom (in., front/rear): TBA/TBA
Cargo Volume (cu. ft.): 15.9
Passenger Volume (cu. ft.): 102.0
Seating Capacity: 5
Exterior Measurements:
Wheelbase (in.): 110.4
Length (in.): 191.6
Height (in.): 58.5
Width (in.): 72.2
Track (in., front/rear): 62.1/61.0
Curb Weight (lbs. MT/AT): 3,360/3,397
Cd: 0.31
6-Speed MT/AT (City/Highway): 31/43 mpgUS
Crankcase (qt.): 5.3
Coolant System (gal.): 9.2
Fuel (gal.): 18.5
Required Fuel: Diesel
Warranty
The new Passat offers VW’s No charge Care Free Maintenance program (3 years/36,000 miles) and the safety of Volkswagen’s Intelligent Crash Response System.
