My 9th grade science project. better fuel economy and performance
04-09-2011, 09:46 AM
Hypothesis; IF YOU ALTER THE TEMPERATURE OF THE AIR GOING INTO A GASOLINE COMBUSTION ENGINE THEN THE ENGINE'S EFFICIENCY WILL BE AFFECTED
RESULTS; RPMs At Different Celsius Temperatures:
10 Degree Air Temperature- full throttle 11032; idle 1764
-25 Degree Air Temperature- full throttle 12395; idle 1982
40 Degree Air Temperature- full throttle 10074; idle 1611
125 Degree Air Temperature- full throttle 8946; idle 1430
By changing the temperature of the air going into the engine I was able to prove that colder air leads to better fuel economy while maintaining or improving performance.
Abstract:
How Air Temperature Affects the Efficiency of a Gasoline Engine
By: Jake Levine
In light of the events in the Middle East over the past month the US needs to lessen its demand on foreign oil. When Middle East countries are in turmoil or fighting wars and rebellions such as with Mubarak in Egypt or Kaddafi in Libya the price of oil goes up. When the countries who own the oil need the oil to fight wars, to prove a point, or to threaten other countries by limiting the amount of oil released the price of the oil goes up. When the price of oil goes up the price of gas goes up. If we limit the amount of oil we get from the Middle East when the countries in the Middle East decide to limit the amount of oil released the price of our fuel would not be as affected.
By improving fuel economy of cars and trucks and even motorcycles we reduce the demand on oil. Most car companies try to improve fuel economy in new cars by reducing weight, changing gear ratios, slowing down throttle response, and even shutting down the engine at red lights. These actions might even be overdoing it, when something as simple as changing where cars intake there air from might-based on my results- be able to improve fuel economy.
I found that the temperature of the air did in fact have an effect on an engine. But instead of hot air making it go faster like I expected it did the opposite, the colder the air the faster the flywheel span. I suspect this is due to more oxygen per square inch in cold air than in hot air.
To test this theory I decided to do one more experiment. I measured specific amounts of super 93 gasoline into containers and dropped a match into the gas. I then recorded the explosion and measured how high the explosion was.
In all three sets of the second experiment the fuel burnt in the cold was more than noticeably bigger than the warmer explosions. This would leave me to believe that at sea level colder air is more combustible than warm air.
By moving the air intake of a car from the engine bay that can be over a few hundred degrees to an outside place such as the front bumper or fenders can greatly improve efficiency and or performance.
04-09-2011, 10:45 AM
Vehicles: 99 Escort zx2
Re: My 9th grade science project. better fuel economy and performance
[quote=jlI found that the temperature of the air did in fact have an effect on an engine. But instead of hot air making it go faster like I expected it did the opposite, the colder the air the faster the flywheel span. I suspect this is due to more oxygen per square inch in cold air than in hot air.
To test this theory I decided to do one more experiment. I measured specific amounts of super 93 gasoline into containers and dropped a match into the gas. I then recorded the explosion and measured how high the explosion was.[/QUOTE]
More oxygen in the air means more fuel will have to be burned to keep the A/F ratio to the set point
As for dropping a match into gas:
Mike
04-09-2011, 06:24 PM
Vehicles: 2012 MINI Cooper
JL, your experiment showed that cold air does make more power. It did not show anything about economy. If you were able to set up a very sensitive flow-meter on the feed to a carbureted engine, or two of them on the feed and return fuel lines of an injected engine, you might have been able to detect something about the fuel used. For an injected engine, monitoring the pulse widths of the injector signal would also give you some idea of the amount of fuel going in. But measuring no-load RPM doesn't tell you about the fuel.
WOT (Wide-Open Throttle) is also a condition that doesn't have much to do with everyday driving and fuel economy. What you really need to do is figure out how much power is used to propel a car at freeway speeds (which is on the order of 10 HP), then see how efficiently an engine with a throttle can make 10 HP. It turns out that, due to "pumping losses" at the throttle plate, most gasoline engines tend to make that ~10 HP more efficiently with high intake air temps.
The experiment is a good one, but it does not actually ask the question that you thought it was asking.
-soD
04-09-2011, 08:11 PM
Vehicles: 2005 Chevy Cobalt
JL, most of us here find that we get better fuel economy at higher ambient air temperatures, as you originally expected. Just look at most people's mileage logs and you will see better mpg numbers in the summer.
Note my observations in the chart below - higher mpg at higher temperatures and lower speeds. Can you image the mpg this car would get in Texas going the new speed limit of 85 mph (off the chart  ):
You can see how the data shown above was collected at:
http://www.cleanmpg.com/forums/showthread.php?t=24278
John
04-10-2011, 01:21 PM
Vehicles: Ford Focus 2009 A/T SGII
Cooler air will not help improve efficiency on todays gasoline engines.
It will improve efficiency on diesel engines though.
04-10-2011, 08:38 PM
I checked out some charts from diesel trucks and cars in our Clean MPG Mileage Logs. Look for people who have logged for over a year. Not sure where these vehicles reside and if temperatures are very cold in the winter:
Here is a chart from a Jetta TDI:
Here is a Ford 350 truck:
They seem to get better mileage in the warmer months.
John
04-10-2011, 10:55 PM
DWL Lover
Vehicles: Honda Accord
Gas get better mileage in summer because of summer gas too. To the best of my knowledge nobody here has found out how much summer gas affects mileage.
04-11-2011, 09:58 AM
Vehicles: 2006 Pathfinder
I agree that the summer blend produces better MPG overall, but I also notice that on the warm days this past month that mileage improves quite a bit despite the winter fuel. So as previous ones have said, warm air is conducive to better MPG.
2006 Pathfinder
04-11-2011, 10:08 AM
Super MPG Man/god :D
Agreed. My Prius seems to make a jump in FE at around 40F then another jump around 60-70F. I think it has a lot to do with increased combustion efficiency along with the fact that warmer air isn't as dense and takes less effort for the car to physically move through the air. My glide times are significantly longer in warmer temps even with the same psi in the tires ie, I can glide farther in 70F at sidewall-max  than I can at 25F.
04-11-2011, 12:36 PM
My personal feeling (just a guess though!) is that the tire temps, engine temps, and extra air resistance of the denser air play more of a role than induction temps do.
I believe there are people on ecomodder.com who have A/B tested warm air intakes. Some have seen benefits, others have not.
-soD
