Researchers: Heat From Exhaust Could Be Harnessed For Improved MPG
Tags: ,
Old 01-05-2011, 09:34 AM
msirach's Avatar
msirach msirach is offline
Potential for incremental improvements in fuel economy
http://www.cleanmpg.com/photos/data/501/exhaust_pipes.jpg
Bengt Halvorson - THECARCONNECTION - December 29, 2010
More research funding is finding different venues for increased efficiency. Can you put a dollar value on these incremental increases? --Ed.
If you've ever crept along in gridlock and noticed the floor of your car getting a little warm, or 'seen' all the heat energy escaping from a hot exhaust pipe on a cold day, you know that exhaust systems send a lot of heat right out the tailpipe—heat that could potentially be put to use.
What if you could recapture that energy and turn it back into electricity that could be used by vehicle accessories?
As automakers look for incremental improvements in fuel economy, that's one of the potential uses of an advanced thermoelectric material that's being researched by physicists and engineers at the University of Michigan. They've studied the material that could potentially be wrapped around a vehicle's exhaust system and would produce energy that could supplement the vehicle's electrical system—therefore allowing higher mpg.
Such a system could make the most difference in low-speed stop-and-go driving, where exhaust pipes typically heat up and the mechanical load from vehicle alternators has a greater impact on fuel economy; supplemental power from these materials in the exhaust system, along with the newer smart-alternator systems already used in some vehicles, could together significantly ease that load.... [Read More] Thanks for the article, JohnM!
Old 01-05-2011, 10:51 AM
herm herm is offline
Re: Researchers: Heat From Exhaust Could Be Harnessed For Improved MPG
A turbocharger with a motor attached to the shaft is another way to extract heat from the exhaust, can be used to remove turbo lag or generate electricity or even act like a supercharger.. and can be controlled electrically and reliably. Feed that to a good size lithium battery for hybrid propulsion duties.
Higher compression ratios also increase efficiency.
Old 01-05-2011, 11:05 AM
http://www.greencarcongress.com/2005..._exhaust_.html
http://www.greencarcongress.com/2009...-for-enha.html
Old 01-13-2011, 07:54 AM
scottd scottd is offline
Vehicles: 2005 VW Jetta TDI
That's why I drive a Diesel
DOE awards GM $2.7 Million to create prototype exhaust heat recovery system xcel In the News 0 10-27-2009 11:48 AM
Possible diy mod: Exploit exhaust heat to heat engine faster? Shrek Fuel Economy 6 08-15-2008 07:52 PM
Researchers: Car exhaust may be used for power dsharp Fuel Economy 28 08-14-2008 01:42 PM
Researchers work to turn car's exhaust into power atlaw4u In the News 3 08-14-2008 03:35 AM
New Source for Biofuels Discovered by Researchers atlaw4u In the News 0 04-25-2008 08:21 AM
