Pricing:
2011 Scion tC Manufacturer’s Suggested Retail Pricing
| Model | Engine | Transmission | MSRP |
| tC | 2.5L I4 | Six-Speed M/T | $18,275 |
| tC | 2.5L I4 | Six-Speed A/T | $19,275 |
Current Delivery and Handling: $720
Engineering:
Engine Type: 2.5L, 4-cylinder, 16-valve DOHC with Dual VVT-i,
Displacement (cc): 2,494
Horsepower @ rpm: 180 HP@6,000 RPM
Torque (lb.-ft. @ rpm): 173 lb-ft. @4,100 RPM
Bore and Stroke (in): 3.54” x 3.86”
Compression Ratio: 10.4:1
Valvetrain: 4-valves per cylinder with Dual VVT-i
Front-Wheel Drive
CARB Emissions Rating: ULEV-II
Transmissions:
Gear Ratios
6-Speed Manual Transmission
1st: 3.538
2nd: 2.047
3rd: 1.375
4th: 1.025
5th: 0.875
6th: 0.733
Final Drive: 4.058
Reverse: 3.545
RPM at 60 mph: 2,316 RPM
6-Speed Automatic Transmission (available)
1st: 3.300
2nd: 1.900
3rd: 1.420
4th: 1.000
5th: 0.713
6th: 0.608
Final Drive: 3.815
Reverse: 4.148
RPM at 60 mph: 1,806 RPM
Body/Suspension/Chassis:
Unit-Body Construction
Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear): 24.2 mm/22.0 mm
Electric Power Steering (EPS) steering column mounted, Rack-and-Pinion
Steering Wheel Turns, Lock-to-Lock: 2.81
Steering Ratio: 14.8:1
Turning Diameter, Curb-to-Curb (ft.): 37.4
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.65/10.98
Wheels: 18 x 7.5-in. aluminum alloy
Tires: P225/45R18 All-Season Steel Belted Radials
T145/80D16 (Compact temporary use spare tire)
Interior Measurements:
Headroom (in., front/rear): 37.7/36.4
Legroom (in., front/rear): 41.8/34.6
Shoulder Room (in., front/rear): 55.4/52.1
Hiproom (in., front/rear): 52.6/48.5
Cargo Volume (cu. ft.): 34.5 w/ seat folded down
Passenger Volume (cu. ft.): 88.4
Seating Capacity: 5
Exterior Measurements:
Wheelbase (in.): 106.3
Length (in.): 174.0
Height (in.): 55.7
Width (in.): 70.7
Track (in., front/rear): 60.6 in. / 61.4 in.
Curb Weight (lbs. MT/AT): 3,060/3,102
Weight Distribution (%, front/rear, MT): TBA
Cd: 0.325
6-Speed Manual (City/Highway/Combined mpgUS): 23/31/26
6-Speed Automatic (City/Highway/Combined mpgUS): 23/31/26
Crankcase (qt.): 5.6
MT/AT transmission fluid (qt.): TBA
Coolant System (qt.): TBA
Fuel (gal.): 14.5
