Go Back   CleanMPG Forums » Our Community » Off-Topic
Off-Topic If it doesn't belong anywhere else you will find it here.
Solar power conversion
Old 01-09-2007, 01:51 PM
Hot Georgia's Avatar
Hot Georgia Hot Georgia is offline
Vehicles: 2004 Honda Civic Hybrid,2001 Grand Caravan
Hi all.
I've begun researching different ways to convert a typical family home to solar power.
Namely solar water heating and electricity.
Most every where I've read is the startup cost is high, but in a few years the "Premium" is recoverd in fuel savings.
Does anybody here have one of these systems, or know anybody 1st hand who does?
I was wondering how long the system *actually* lasts, maintenance cost etc.
I was considering having a company come out and assess our location for solar output and I suspect we have a good one.
Efficient drivers do it better.
Old 01-09-2007, 04:38 PM
brick's Avatar
brick brick is offline
Retrograde Orbiter
Vehicles: 2009 Volvo V70
Re: Solar power conversion
The most effective use of solar power is passive heating and cooling. (Yup, cooling.) A properly designed home can capture tremendous amounts of solar energy in cold weather, reducing active heating loads by quite a bit. A properly designed home can also use solar energy to reflect and reject heat, reducing cooling loads. Unfortunately this is not an easy retrofit, as passive solar applications generally require the home's design to be built with the sun in mind from the ground up.
The next best application of solar energy in the home is hot water. Active thermal energy capture is currently a much more efficient and cost-effective process than photovoltaics. Water heating is also one of the home's most energy-hungry processes which makes it a cost-effective project.
I do not recommend photovoltaics at the moment, as you are looking at an extremely long payback period and minimal impact to your home's energy profile. Electrical power under optimal conditions would be on the order of 100W per square meter of PVs, at a cost in the thousands of dollars. You could install a system that would take care of most of your home lighting if you are running CFL, but the thing is that it would provide light when you need it least. Attempting to store energy for later use is possible, but the losses incurred would significantly decrease effective energy yield.
Here's how I would procede:
-First I would create an energy profile for my home. I would want to break down energy consumption into space heating, water heating, and misc. electrical loads. In GA you also want to assess cooling loads.
-Then I would look for ways to improve the home's passive properties. Would more insulation reduce heating and cooling loads? How about awnings to reduce heat absorbtion through the windows when it's warm? A step further might include ceiling fans to improve interior ventillation with minimal energy loads.
-Finally, I would look for ways to supplement active loads. For hot water, any number of thermal collection systems are available. Should work extremely well in your climate, too. For electrical loads, have you considered a windmill? The cost/benefit is much better than photovoltaics, though it would take a fairly involved study to determine if your location is suitable. It's easier to assess the potential of solar using existing data that's fairly easy to get.
Tim
Old 01-09-2007, 06:00 PM
Thank you for the reply.
Come to think of it I have alot of existing things to update in my home.
It's a spilit-foyer style built in 2000. I'll need to look at things like your window awnings and possibly replace our windows. (Despite being new-ish they aren't very efficient) Electric plug plate wheather stripping etc can help as well as a better seal for the doors.
Wow you put allot of things on my plate. Thanks for the advice.
Efficiency measures, solar panels 'green' homes. xcel In the News 2 01-13-2010 11:47 AM
How Close to Catastrophe? xcel In the News 0 10-28-2006 03:46 AM
Pioneering Technology Lab Now Puts Energy Into Solar. xcel In the News 0 07-03-2006 11:31 PM
Major increase in US solar power manufacture. xcel In the News 1 06-21-2006 06:58 PM
Diversify: Solar power for the Gulf mds2 Environmental 0 06-15-2006 10:25 AM
