Re: Scanguage setup for Insight.
You have the same X-gauge that I have for lean burn. On an Insight 1 that is certainly one of your most important gauges because it allows you to learn how to trigger lean burn. As far as the speed % and the fillup % are concerned, I don't think you even need to deal with them. Just set each to 0% and forget them. Reason is that the SGII is wildly off target on MPG on a lean burn Insight. Apparently the designer didn't find a way to deal with lean burn effectively.
Congratulations on your new purchase. I'm sure you are going to love the Insight 1. The isn't a better car available to wring out FE. Take good care of the little gem, there aren't as many left as there once was.
