How many miles before you change your tires?
Old 01-30-2010, 12:39 PM
jhu's Avatar
jhu jhu is offline
Just wondering how long your vehicle's tires last and what the tread depth was before replacement.
Old 01-30-2010, 01:22 PM
Damionk's Avatar
Damionk Damionk is offline
DWL Lover
Vehicles: Honda Accord
Re: How many miles before you change your tires?
At the time I could only afford cheap tires, so I got 40k mile tires. I am at about 37k miles with about half the tread left. I do plan to buy a new set in the next few months, store them, then when the tires I have on now are too low put on the new ones.
(It is a little complicated, I know, but it makes good financial sense to my situation.)
Forget driving like a normal person, I would much rather drive like a sane person.
Old 02-01-2010, 08:04 AM
Taliesin's Avatar
Taliesin Taliesin is offline
Vehicles: 2002 Ford Ranger (2.3, M5), 2007 Dodge Ram 1500 (4.7 FFV, 5A)
I completely depends on the tires and the vehicle, but...
The original tires on my Ranger were 40K mile tires, and I swapped them out at 80K miles.
They were still just above the wear markers.
The CleanMPG Fuel Economy Challenge
The competition: fierce
The ones scared: gas merchants.
Old 02-01-2010, 08:30 AM
PaleMelanesian's Avatar
Beat the System
60k on the Ody, but they were poorly treated by the previous owners for half of that.
Andrew
88.3 mpg commute 72.8 mpg / 946 mi tank
100 mpg commute 90.2 mpg / 1191 mi tank
Old 02-01-2010, 09:20 AM
rdprice64 rdprice64 is offline
Still Learning
Vehicles: 12 Leaf SL, 07 FEH, 94 Trek 720
45k currently on the OEMs and no real slippage so far this winter, so no plans to replace them.
So does anyone actually do the tread measurement to decide when it is time to get news ones and how do you go about doing that? Do you need any special tools?
-Rob
FEH: 65.0 MPG - 14.0 mile commute   45.598 MPG - best tank   615 miles - longest tank
Old 02-01-2010, 09:32 AM
Beat the System
Mine were nearly down to the wear bars in the front. I decided to go ahead and change them since winter was coming on. In summer I would have gone a bit longer.
Andrew
Old 02-01-2010, 09:39 AM
Still Learning
OK Andrew, get a little simpler for the simpleton. What are wear bars?
-Rob
Old 02-01-2010, 09:46 AM
Beat the System
The orange highlighted part. They're in there to show when the tread depth reaches the legal limit. If the bars are starting to wear, and are no longer deeper than the main tread, you really need to replace the tires. Some will say you are overdue by this point, and they may be right - traction degrades as tread wears, starting from day 1.
Andrew
Old 02-01-2010, 03:43 PM
MaxxMPG's Avatar
MaxxMPG MaxxMPG is offline
Using pocket change, you can measure basic tread depth. I have a tread depth gauge (about $2 from the auto store), but coins work well enough for rough guesstimates.
2/32" - legal minimum - Insert a penny upside down into one of the wide treads in the tire. If you can see the top of Lincoln's head, you're below the minimum.
4/32" - minimum if driven in heavy rain - Insert a quarter upside down into one of the wide treads in the tire. If you can see the top of Washington's head, the car will be very susceptible to hydroplaning.
6/32" - minumum if driven in snow - Insert a penny upside down into one of the wide treads in the tire. If you can see the top of the Lincoln Memorial, you're below the minimum for good snow traction.
I have replaced tires in as little as 20k miles, and the average is usually about 60k miles. The winner, though, is a car I traded in at almost 170k miles that still had the original rear tires installed, and they had plenty of tread life left on them. The fronts wore out at about 60k mile intervals, with the swap-out done at 4/32 tread depth.
Old 02-01-2010, 05:25 PM
St. Mushroom St. Mushroom is offline
doesn't wash his car.
Lincoln method:
http://www.youtube.com/watch?v=KkLJf-6zS4E
Are you really supposed to change oil every 3000 miles? JusBringIt In the News 21 09-08-2009 06:46 PM
how many miles on your potenza tires JimT General 11 08-14-2009 08:00 AM
One Thousand Miles And Counting: Fusion Hybrid Breaks 1,000 Miles On Single Tank msirach Ford Fusion/Lincoln MKz Hybrid 31 04-29-2009 01:55 PM
Bright Idea: Change a Light, Change the World. xcel In the News 14 10-08-2007 12:37 AM
Reminder: Change oil every ... 12,000 miles? xcel In the News 9 03-25-2007 08:32 AM
