Home
CleanMPG Staff
Articles
Fuel Economy Forums
More Reviews
Gallery
Mileage Logs
CleanMPG Store
Calendar
Glossary
Garage
Files
Research
Related Sites
Archives
Arcade
Monthly Fuel Efficient •
Go Back   CleanMPG Forums » Modding and Hardware » MIMA or Manual Integrated Motor Assist
MIMA or Manual Integrated Motor Assist Open discussion on the Honda Insight's MIMA mod.
Mounting the MIMA joystick and display.
Old 11-19-2006, 03:00 PM
highwater's Avatar
highwater highwater is offline
Vehicles: 2001 Honda Insight 5sp
This will not be so much about how to do the installation of the MIMA system, as what I did with the two items left to the design of the customer; that being the design/mounting of the joystick and the display. The MIMA installation is well documented on Mike Dabrowski’s webpage http://www.99mpg.com , where you will also find all the schematics for the joystick and led display.
Here’s a picture of what I did with mine, in the early stages while I was finding the right position on the shifter.
Experimental joystick mount.
Also in the picture is a bracket that will look familiar to most. It is one of those reflector brackets off a bicycle. I threw the reflector in the picture for clarification, although I had to turn it over to take the picture. There are several sizes of these things, to fit different sizes of tube, but I had some new ones, in the desk drawer that I had taken off the mountain bike, and they were the right size, so I already had some on hand. I was initially thinking of popping the reflector off, and mounting the joystick on the flat surface that was left, but then the joystick would still be exposed, and there were some other things that I wanted to incorporate into whatever I wound up attaching to the shifter.
INSTALLING A ZIPPER IN THE SHIFTER BOOT
Another thing that I wanted to accomplish with the joystick and led display install, was to make the wiring, as inconspicuous as possible. I decided to put a zipper in the shifter boot. This would allow the somewhat larger items that might be hard wired, to drop through, when removing the console. I had a button hole made crossways, at the top of the zipper opening for any wires to pass through, which was particularly suited to the flat ribbon cable coming from the joystick. The ribbon cable lays very nicely in the button hole opening.
To get the shifter boot off, remove the console, and turn it over, so as to get to the 4 screws holding the plastic frame onto the console. Remove the 4 screws and the shifter boot which is stapled into the plastic frame. Looks like this:
Shifter boot removed and turned inside out.
The small rubber band is removed by rolling it off, and then the plastic ring will fall out. Remove the staples and the boot itself is free. You might want to mark the dash (forward) side of the inside of the boot so that whomever does the sewing will get the zipper in the right quadrant of the boot. All sides are not equal. The forward side is longer, as can be seen in some of these pictures. I had the person doing the sewing for me, roll the edges of the cut, to the inside while sewing in the zipper, and also sew the zipper to the inside of the boot. It will look pretty good that way, and give an overall finished look.
Boot remounted in the console with zipper in place.
Notice the button hole at the top of the zipper.
Once you get the zipper sewn in, just re-staple very carefully. Remember, the boot is not equal on all sides. You may have to think upside down and backwards here.
Now anything attached to the shifter, can be taken loose and slipped through the zippered opening in the boot, to allow easy removal of the console.
Passing the hardwired MIMA joystick mount through the zippered shifter boot.
BACK TO THE SWITCH BOX:
From one of my electronics supply sources, I ordered a few examples, of different sizes of project boxes. Once I had the options reduced to the one I wanted to use, I modeled the chosen one, for the purpose of dimensioning, and; since I was going to have the cut-outs done on a bench top laser, the digital files could be downloaded to the laser.
Here’s the results of the modeling:
Back from the laser shop, to the desk top:
My friend Murphy, always seems to need one of what I’m working on, and as you can see from the right hand pic, he dropped by and got his share. That is why I ordered more than two. I milled a flat on the bottom of the boxes for the mounts to set in, while the epoxy sets up.
The switch operator that will be on the left side of the joystick, is the top half of a momentary rocker switch. I cut the top of the switch off, (the part that would panel mount), and glued some extensions to the top of the tactile switches on the joystick board. These (purple in the photos) extensions, reach up inside the rocker part, so that, once the cover is mounted on the box, the rocker will activated the two tactile switches, for MIMA mode 1 (forward rocker motion), and MIMA mode 2 (aft rocker motion). I finally had to just run Murphy off, on this part of the project, ……..pesky fellow, that Murphy.
The switch to the right side of the joystick, is the same switch that I cut the top off of, for the left side, except I left it in its original configuration. The forward motion on it, will be the garage door opener (Aft motion undecided at this time.). This switch is visible in the right hand photo. The small, four lobed knob, that I used on the joystick itself, is very intuitive for operating MIMA. Your finger will just fall into place. The cross-cuts in the center of the cover, also help guide the joystick to the four cardinal points of use.
The completed joystick mount.
AND NOW THE MIMA DISPLAY:
I found a nifty little project box, with some nice curves to match the Insight, or so I thought anyway, and it was available in blue (my Insight is blue). The front panel was removable, so I had my buddy with the laser, cut some clear replacements out of a cd case. (So happens the case was the right thickness.) Got several of them cut, since once you are there, 3 or 4 costs the same as a quantity of one. The masking tape is used to keep the smoke from the laser cutting, off of the clear plastic. In the case of the black plastic switch box, the smoke is not that big a deal, and can be washed off with some liquid dish soap. With the clear, we didn’t want any residue left on the surface.
I wanted to mount my garage door opener board inside this enclosure, so I had to cut it down from it’s original size. About half of the circuit board was not used anyway, and I didn’t need the switch that is on the board, since I will activate it from the MIMA shifter mount. My particular door opener is 12v powered, so that eliminates some bulk and some wiring. There are also a few extra wires on the ribbon cable from the joystick and from the led display, so wiring in the garage door opener was pretty simple.
Original door opener board (left), and chopped down version (right).
This is what it looks like, with the MIMA leds mounted.
Assembled in the left picture, mounted in the vehicle (rear view) in the right picture.
The rear view of it mounted in the vehicle, is taken with the rear hatch opened. I removed the push rivet that holds up the headliner, placed a small circle of Velcro behind the push rivet, and put the mating Velcro on the display, as seen in the left photo above. A small straight razor cut in the headliner allows the cable to exit and be plugged into the display housing. Let me get the wiring in place and then a couple more pics should clear up any question about where this thing is mounted.
Fishing the wires through the headliner….
…and through the interior rocker panel, to the front.
And now, those other pics to help clear up where the MIMA display is mounted.
Left pic shows the display with most of the leds lit up. The right pic is what I am seeing when I look in the rear view mirror.
Those detail oriented folks that might be reviewing this, would call attention to the fact that the leds are not the same in many of the above photos. The one on the left just above, with everything lit up, was taken at a later time. I had installed a larger 5mm green led, as an FAS indicator, in the center of the MIMA leds. It is much larger than the tiny amp indicators, so it’s easy to tell the difference (I have the smaller leds from the discrete display kit). All leds, are never lit up at the same time, in real time use. I lit everything up just to take the picture.
For the MIMA users:
This display gives the same information, in the same order, as Mike’s factory board. I basically just flipped it over and placed it behind my head. The only real difference is I stacked the green and amber leds, instead of having them all in a row. The regen still indicates from the right to the left, and the assist from the left to the right, with the red status indicators being somewhat separated from each other.
SECONDARY JOYSTICK LOCATION:
The MIMA design allows a secondary joystick to be in parallel with the original. This requires a piggy back plug on the primary cable and a second joystick and cable. Here is my choice for the location of my secondary joystick location:
Putting the second joystick in this location, lets my arm rest comfortably while controlling MIMA, and the cup holder in the Husco armrest is a useless item (in the Insight), as far as I’m concerned. I had to look for a long time, before I found just what I needed for the cup part. It had to be the right diameter and have some taper to it, so as to go down inside the slide out tray part of the cup holder. Here is a picture (on the left) of the two possibilities that I bagged during the hunt.
On the right are the cup-holder shapes that I cut out of the beverage tray, from the left picture. One is the raw cut-out, and the other is trimmed to fit the slide-out tray in the arm rest. That is a bare joystick board in the right hand pic.
As these photos show, the square relief area, in the trimmed cup-holder provides a means of access to run the ribbon cable from the secondary joystick, to a place where it can be routed under the carpet and up to the MIMA board. In the right hand picture you can also see that it would be necessary to have some relief, as the cable could get pinched when the cup-holder tray is returned to the “fully upright and stowed position”.
Almost done:
THE RATTLE IN THE HUSCO ARMREST:
While working with this joystick location, I wanted to see if I could get the rattle out of the slide-out part of the armrest. The following pics show what I came up with. If you have a Husco arm-rest and it rattles, this might help.
In the left hand pic, you can see a small detent in the exterior of the Husco armrest slide, in line with the slide out part. I stuck a black ziptie, zip side out, in between the frame of the armrest and the slide. I cut it to the proper length and super-glued it to the slide. This tightened up the slide (no more rattle) and makes it stay where you put it, thanks to the detent riding in the zip. If you do this, make sure you get the back end of the ziptie far enough back so it won’t ever come out from behind the detent, on the occasions when you pull the slide all the way out. Clear as mud….huh.
Well, if you stayed with me this long, I hope at the least, you enjoyed looking at the pics.
Randall
Honda Insight---Chariot of FirE
Old 11-19-2006, 03:20 PM
xcel's Avatar
xcel xcel is offline
Re: Mounting the MIMA joystick and display.
Hi Randall:
___I saw these pics go up the past few weeks and I was wondering what all this stuff was? Now I know I sure wish you worked for Ford or GM inside one of their interior groups as you can beautifully package anything …
___Do you see any vibration of the display through the rear view when traveling down the road?
___Lastly, when it comes to a MIMA review, I think you are definitely the right person to write that one up!
Old 11-19-2006, 03:28 PM
highwater's Avatar
Thanks Wayne..........
Just another of my tinker tantrums.
No vibration that is visibly noticable. The area of the Velcro is pretty small so that kepps it sucked up tight.
Randall
Old 11-19-2006, 06:51 PM
Mike Dabrowski 2000's Avatar
Mike Dabrowski 2000 Mike Dabrowski 2000 is offline
Great job Randall,
I saw your display and joysticks at the Hybridfest, and your workmanship and attention to detail makes me wish I had the patience to clean up my MIMA setup a bit.I like the mad scientist look
As MIMA # 5, and over a year of MIMA driving, how do you like the system?
Mike
2000 modified Insight MT
MIMA #007
PHEV/Boost battery system Eboost
Solar recharge
Ewheel 5th wheel
Old 11-23-2006, 05:58 AM
highwater's Avatar
Hi Mike, and sorry for the delayed response.
I continue to enjoy the MIMA mod on my Insight. I hope you can come up with those AMP connectors, so the MIMA kit will be "plug and play", well, almost anyway. If you could ever get ahold of a Civic IMA long enough to produce a MIMA for that system, I think the hybrid world would be quite a different place.
Thanks for building MIMA.
Randall
Old 11-23-2006, 10:05 AM
Thanks Randall,
Thanks for your MIMA report.
Some new happenings in my Hybrid car training work may give me access to a Civic hybrid as well as a Prius. I got to drive a Prius for about 900 miles over the last several weeks, I like the car. I made the mistake of letting my wife drive it, now She would like to get one. She hates driving the Insight with the 5 speed, and has only driven my Insight one time.
I have determined that the Prius MG2 (~40HP) could be salvaged from a junked Prius Synergy drive, and with a small modification to provide an output adapter, it could be used as a stand alone motor. I would love to see if I can use the power inverter from a Prius to drive the motor, as a potential power plant for a pure electric Insight. I would pull the ICE, and the whole IMA system, and connect the MG2 motor directly to the 5 speed, and put some batteries up front where the ICE was located, and in back where the IMA components were. It also could be the power plant for a BIG 5th wheel for pickup trucks and vans.
So many possibilities and so little time.
I finall have the part numbers for all the Amp/Tyco connectors thanks to your photos.
2 ea 179686-6 104P header Ass'y Horizontal
2 ea 179678-6 16P Plug connector
2 ea 179680-6 31P Plug connector
2 ea 179679-6 25P Plug connector
2 ea 179681-6 32P Plug connector
26 ea 175268-1 070II Receptacles
182 ea 175265-1 040II Receptacle
1 ea 1438291-6 48P header Ass'y, Horizontal
1 ea 917989-6 22P Plug connector
1 ea 917992-6 26P Plug connector
16 ea 175268-1 070II Receptacles
32 ea 175265-1 040II Receptacles
It was interesting to find that the ECM and MCM use exactly the same connectors, that makes the inventory that much smaller.
The down side of all this is that :
1. The connectors will cost between $40-$60 for a complete set in the small quantities.
2. Instead of the 20 MIMA connections, I need to fully populate the connectors so I will need to make 256 crimps for the 256 pins, then solder the 256 wires to the headers, and finally connect the MIMA wires to the assembly and use the epoxy putty to form a complete assembly.
A lot of work, but it will make it a plug in system.
Unfortunately some of the connectors are not in distributer stock. I need to wait till Fri to start looking for sources. The hollidays are not a good time to get much help with this type of parts sourcing.
Progress is never easy.
Happy Thanksgiving to all.
Mike
MIMA #007
Solar recharge
Ewheel 5th wheel
MIMA: Tips, Tricks, and Techniques highwater MIMA or Manual Integrated Motor Assist 35 08-09-2007 08:23 AM
