How well do your tires stay inflated?
Old 11-14-2009, 09:11 AM
jhu's Avatar
jhu jhu is offline
I just checked my tires yesterday and according to my cheap $20 air compressor, they're still at 50 psi (max sidewall=51psi). This is after 6 months of not checking. Is this normal? My bicycle's tires, before the bike was stolen, wouldn't be able to hold any sort of pressure for more than 2 weeks!
Interestingly, when I got the car new last year the tires were at about 42 psi straight from the dealer where the doorjam says to put it at 32. Is my air compressor gauge just wrong?
Old 11-14-2009, 09:24 AM
JusBringIt's Avatar
Be Inspired
Re: How well do your tires stay inflated?
My summer tires/rims stayed at 60psi forever...they never go down...
The winter tires I have on now, I'm not so sure, I'll check em today, but they were at 20-35 when I got them.
Ricardo
Best Segment: 25.3mi@76.9mpg
Old 11-14-2009, 11:42 AM
St. Mushroom St. Mushroom is offline
doesn't wash his car.
Usually have to pump up my bike tires before each ride, even twice a weekend.
Old 11-14-2009, 12:34 PM
brick's Avatar
brick brick is offline
Retrograde Orbiter
Vehicles: 2009 Volvo V70
The tires on my bike need to be inflated every time I break it out. (Every couple of days for a little workout on the rollers.) On the car they don't lose pressure at all except for the usual variations with temperature.
Tim
Old 11-14-2009, 02:37 PM
Chalupa102's Avatar
Chalupa102 Chalupa102 is offline
Cycling more to drive less
Vehicles: '05 Corolla LE A/T, Catrike Trail trike
Same thing here. If the outside temp changes a lot during the week, my tires lose a tiny bit of psi, but besides that, they stay the same.
-Dan
Old 11-15-2009, 02:16 AM
bomber991's Avatar
Just a few psi per month it seems like. I'll pump them to 60, then a month or two later they're down to 55.
-Justin
Old 11-16-2009, 11:04 AM
PaleMelanesian's Avatar
Beat The System
This. They're now about 5 low from where I put them back in May, due to temperature changes.
Andrew
Old 11-16-2009, 06:42 PM
vmax186's Avatar
vmax186 vmax186 is offline
I try to check the tire pressures on most of my sleds every two weeks- the only tires that seem to lose air are the ones on the Speed Triple and the turf tires on my two ZTR mowers.
2007 Mazdaspeed 3(soon to be replaced by E39 M5 or E46 M3)
2004 X3 2.5
1995 318ti Club Sport
1975 2002A
1999 Wrangler Sahara
1996 Speed Triple
Old 11-16-2009, 10:02 PM
fuzzy fuzzy is offline
Mild hypermiler
Vehicles: '97 Legacy GT, '10 Prius
I put my winter set on yesterday. They were all in the 38-40 range, down from 42-44 when put away about 7 months ago, in warmer weather.
This is a much better bead sealing job than the previous set on the same rims.
Old 11-17-2009, 07:36 AM
Shiba3420 Shiba3420 is offline
Vehicles: HyHi 2007 2WD
I'd say I don't loose more than 1psi per several months....excluding temp changes. I feel sorry for the people that have to repressurise almost weekly.
Jonathan
Eagles may fly, but weasels don't get sucked into jet engines (with 1 known exception)
When round and black becomes lean and green xcel Articles 29 06-01-2012 05:22 PM
Proper tire pressure turns into a community outreach project xcel In the News 7 06-08-2009 01:45 PM
Finally inflated the FSP's tires because of the Metro's transmission! drimportracing The Daily Grind 5 03-02-2009 10:13 PM
The spin on tires and fuel economy atlaw4u In the News 9 05-07-2008 09:51 AM
What is the "up to maximum vehicle weight" field for tbaleno General 6 10-06-2006 10:43 PM
