2007 Toyota Yaris 3 Dr. Hatchback/Sedan
Pricing:
Yaris 3-Door Liftback 5-Speed Manual $11,050
Yaris 3-Door Liftback 4-Speed Automatic $11,950
Yaris 4-Door S Sedan 5-Speed Manual $13,425
Yaris 4-Door Sedan 5-Speed Manual $11,925
Yaris 4-Door Sedan 4-Speed Automatic $12,650
Yaris 4-Door S Sedan 4-Speed Automatic $14,150
Destination $620
Base - Option packages - higher trims have far fewer options to add due to inclusion.
Option Combination #A $740
All-Weather Guard Package - Larger Washer Tank w/ Level Warning, Heavy-Duty Heater, Heavy-Duty Starter, Rear Heater Duct & Daytime Running Lights (DRL) (CP)
Convenience Package - AM/FM CD Player w/MP3/WMA Playback Capability & Auxiliary Audio Jack, 15-in. Steel Wheels w/Full Wheel Covers, Rear Window Wiper & Rear Defroster (CQ)
Option Combination #B $1,400
Power Package - Power Door Locks, Power Windows, Power Outside Mirrors, 60/40 Split, Reclining, Sliding, Fold-flat Rear Seat, AM/FM CD player with MP3/WMA Playback Capability and Auxiliary Audio Jack, Rear Window Wiper, Rear Defroster and 15-in. Steel Wheels (PQ)
Option Combination #C $2,350
4-wheel Anti-Lock Brake System (ABS) w/Electronic Brake-Force Distribution (EBD) (AB)
Driver & Front Passenger Front Seat-Mounted Side Airbags & Front & Rear Side Curtain Airbags (GY)
Option Combination #D $2,890
Fog Lamps (LF)
Rear Spoiler (RF)
Remote Keyless Entry System (KE)
Option Combination #E $3,280
Fog Lamps (LF)
Power Package - Power Door Locks, Power Windows, Power Outside Mirrors, 60/40 Split, Reclining, Sliding, Fold-Flat Rear Seat, AM/FM CD Player w/MP3/WMA Playback Capability & Auxiliary Audio Jack, Rear Window Wiper, Rear Defroster & 15-in. Aluminum Alloy Wheels (PP)
Rear Spoiler (RF)
Cargo Logic Tote (9G) $40
Cargo Net (GN) $49
Door Sill Enhancements (G0) $159
Emergency Assistance Kit (7R) $70
First Aid Kit (3Z) $29
Interior Light Kit - Blue (44) $275
Rear Bumper Protector (EF) $65
Sport Shifter Knob (22) $65
VIP Security (V3) $499
Wheel Locks (WL) $59
TRD 18" Wheel (Single Wheel/Tire not included) $330
TRD Oil Filler Cap $57
TRD Radiator Cap $38
TRD Shift Knob $76
Engineering:
Displacement (cc): 1496
Horsepower @ rpm (SAE net, Rev 8/04): 106 HP @ 6000 RPM
Torque (lb.-ft. @ rpm): 103 lb.-ft. @ 4200 RPM
Redline (rpm):
Bore and Stroke (mm): 74.9 x 84.6
Compression Ratio: 10.5:1
Valvetrain: 16-Valve DOHC VVTi
Sequential Electronic Fuel Injection
Front-Wheel Drive
CARB Emissions Rating: ULEV-2
100,000-Miles-or-More Tune-Up Interval*
Transmissions:
Gear Ratios
5-Speed Manual Transmission
1st: 3.545 2nd: 1.904 3rd: 1.310 4th: 0.969 5th: 0.815 Final Drive: 3.722
Reverse: 3.250
5-Speed Automatic Transmission (available)
1st: 2.847 2nd: 1.552 3rd: 1.000 4th: 0.700 Final Drive: 4.237 Reverse: 2.343
Body/Suspension/Chassis:
Unit-Body Construction
Torsion Beam Rear Suspension
Stabilizer Bar (mm., front/rear): 23 mm/NA
Electrical Power Assist Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: 3.02
Steering Ratio: 19.7:1
Turning Diameter, Curb-to-Curb (ft.): 32.6 ft.
Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.03/7.87
Wheels: 14" with Full Covers//15" Steel or Alloy
All-Season Tires: P175/65 R14//P185/60 R15
Compact Spare Tire
Interior Measurements:
Headroom (in., front/rear): 39.4/37.5//38.8/36.7
Legroom (in., front/rear): 40.3/33.8//42.2/35.6
Shoulder Room (in., front/rear): 51.4/48.3//51.6/50.2
Hiproom (in., front/rear): 50.0/48.3//49.8/50.1
Cargo Volume (cu. ft.): 12.8/12.9
Passenger Volume (cu. ft.): 84.1/87.1
Seating Capacity: 5
Exterior Measurements:
Wheelbase (in.): 96.9//100.4
Length (in.): 150.0//169.3
Height (in.): 60//56.7
Width (in.): 66.7//66.5
Track (in., front/rear): 57.59/57.5//58.3/57.9
Curb Weight (lbs. MT/AT): 2293/2326
Cd: .29
5-Speed Manual (City/Highway): 34/40
5-Speed Automatic (City/Highway): 34/39
Crankcase (qt.): 4.3
Coolant System (qt. MT/AT): 5.4
Fuel (gal.): 11.1
