2007 Honda Fit/Fit Sport
Pricing:
Honda Fit MT/Auto
$13,850/$14,650
Honda Fit Sport MT/Auto
$15,170/$15,970
Dest. $595
16" Alloy Wheel $836
Car Cover $209
Chrome Exhaust Finisher $30
Full Nose Mask $145
Rear Bumper Appliqu้ $58
Sport Grille $220
All-Season Floor Mats $109
Carpet Floor Mats $99
Cargo Cover $165
Cargo Net $55
Cargo Organizer $59
Cargo Tray $99
Leather Shift Knob $79
Honda MusicLink (for iPodฎ) $199
Engineering:
Displacement (cc): 1497
Horsepower @ rpm (SAE net, Rev 8/04): 109 @ 5800
Torque (lb.-ft. @ rpm): 105 @ 4800
Redline (rpm): 6300
Bore and Stroke (mm): 73.0 x 89.4
Compression Ratio: 10.4:1
Valvetrain: 16-Valve SOHC VTEC (R)
Multi-Point Fuel Injection
Drive-by-Wire Throttle System (TM)
Front-Wheel Drive
CARB Emissions Rating: LEV-2
100,000-Miles-or-More Tune-Up Interval*
Transmissions:
Gear Ratios
5-Speed Manual Transmission
1st: 3.462 2nd:1.870 3rd: 1.321 4th: 0.970 5th: 0.757 Final Drive: 4.294
Reverse: 3.231
5-Speed Automatic Transmission (available)
1st: 2.995 2nd: 1.678 3rd: 1.066 4th: 0.756 5th: 0.550 Final Drive: 4.562
Reverse: 1.956
Body/Suspension/Chassis:
Unit-Body Construction
Torsion-Beam Rear Suspension
Stabilizer Bar (mm., front): 21.0
Electric Power-Assisted Rack-and-Pinion Steering (EPS)
Steering Wheel Turns, Lock-to-Lock: 2.41
Steering Ratio: 12.8
Turning Diameter, Curb-to-Curb (ft.): 35.6
Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.3/7.9
Wheels: 14" with Full Covers//15" Alloy
All-Season Tires: P175/65 R14 81S//P195/55 R15 84H
Compact Spare Tire
Interior Measurements:
Headroom (in., front/rear): 40.6/38.6
Legroom (in., front/rear): 41.9/33.7
Shoulder Room (in., front/rear): 52.8/50.6
Hiproom (in., front/rear): 51.2/51.0
Cargo Volume (cu. ft., seat up/down): 21.3/TBD
Passenger Volume (cu. ft.): 90.1
Seating Capacity: 5
Exterior Measurements:
Wheelbase (in.): 96.5
Length (in.): 157.4
Height (in.): 60
Width (in.): 66.2
Track (in., front/rear): 57.3/57.1
Curb Weight (lbs. MT/AT): 2432/2514//2471/2551
Weight Distribution (%, front/rear, MT): 61.8/38.2//61.6/38.4
Weight Distribution (%, front/rear, AT): 63.3/36.7//63.2/36.8
EPA Mileage Estimates*/Capacities:
5-Speed Manual (City/Highway): 33 / 38
5-Speed Automatic (City/Highway): 31 / 38
Crankcase (qt.): 4.4
Coolant System (gal.): 1.4
Fuel (gal.): 10.83
* Preliminary EPA mileage estimates determined by Honda. Final EPA mileage estimates were not available at the time of printing. Use for comparison purposes only. Your mileage may vary.
