Gasoline heater
Old 08-05-2009, 08:15 PM
rossbro rossbro is offline
Question Gasoline heater
Has anyone heard of using an insert into the heater hose line to heat gas before injection into the engine? A friend has bought one and will have it installed shortly. It looks like a tube for the hot water to flow through with a line wrapping tightly around it ( maybe 8 coils ), everything made of copper. The main tube looks to be about 5/8 or 3/4 inck diameter with nipples on both ends( for the heater hose ), wrapped with 1/4 or 3/8 tube for the gas.
Would preheating gasoline do anything ? ??? Thanks for any thoughts.
Old 08-05-2009, 09:36 PM
abcdpeterson's Avatar
abcdpeterson abcdpeterson is offline
Re: Gasoline heater
the EPA says No good.
http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut10.shtm
Devices Tested by EPA
The following list categorizes various types of "gas-saving" products, explains how they're used and gives product names. Those with asterisks may save measurable, but small, amounts of gas. All others have been found not to increase fuel economy
there is NOT an asterisks for fuel line heater.
Fuel Line Devices (heaters or coolers). These devices heat the fuel before it enters the carburetor. Usually, the fuel is heated by the engine coolant or by the exhaust or electrical system.
The EPA has evaluated: FuelXpander; Gas Meiser I; Greer Fuel Preheater; Jacona Fuel System; Optimizer; Russell Fuelmiser
but then if your friend Things it will help he may drive different and how you drive will change your mileage.
-Allen
Old 08-06-2009, 11:32 PM
Ford Man Ford Man is offline
Vehicles: 1988 Ford Escort, 1997 Ford Escort, 1996 Ford Contour
Re: Gasoline heater
I will soon be able to give you any answer on this one. I had a fuel heater on my '88 Escort Pony and just took it off about a month ago. My fuel mileage did drop, but I just put it back on yesterday to see if the mileage increases again or not. I haven't made any other changes to driving routes, driving habits, aero mods, or engine. I'll try to to remember to report back after a few weeks. It does seem that gas would be more vaporous at warmer temperatures. I think maybe this is also partially why a warm air intake helps mileage. Of course these are just my opinions, and opinions are like a-holes everybody has one and they all stink.
Old 08-07-2009, 07:43 AM
Shiba3420 Shiba3420 is offline
Vehicles: HyHi 2007 2WD
Re: Gasoline heater
I suppose that heated gas would atomize and burn more agressively. I suspect the greater gain would be in carborated vehicles with less or no beniefit in modern direct fuel injected vehicles. I do wonder if there is any safety concerns. Is there any possibility of one of these devices overheating the fuel and causing a fire?
Jonathan
Eagles may fly, but weasels don't get sucked into jet engines (with 1 known exception)
Old 08-07-2009, 07:47 AM
diamondlarry's Avatar
Super MPG Man/god :D
Re: Gasoline heater
If you used an engine coolant based version, there shouldn't be any overheating issues. You also need to find a way to keep the temperature to around 150F or so.
Old 08-07-2009, 08:40 PM
Re: Gasoline heater
I just made a small copper pipe device that I spiced into the fuel line, then used zip ties to fasten it to one of the heater hoses and wrapped it good with 1/4" foil covered foam insulation and taped it up with foil tape. With it being tied off to the heater hose the copper absorbs the heat and holds it. I don't know what the temperature of gas gets to, my water temperature usually runs about 205* and in town sometimes it will reach 230* so I would imagine the fuel is getting near 200* and maybe even warmer at times. I have thought about trying to rig up something using the heat from the exhaust, but I was a bit worried about getting the gas too hot and maybe causing a fire. The ignition temperature of gasoline for it to burn or explode without a spark or flame is about 495* F.
Gasoline sales down 7% from last year. ALS General 2 05-26-2008 01:20 AM
Heater Core Bypass GaryG Ford Hybrids 16 07-21-2007 08:54 PM
Driving on gas - but not gasoline. xcel In the News 0 02-01-2007 12:28 PM
Gasoline Price Manipulation Before the Elections? xcel In the News 17 12-05-2006 08:22 AM
How low can gasoline prices go? xcel In the News 0 09-10-2006 10:52 PM
