Prius puzzler
Old 04-12-2009, 07:58 PM
hobbit hobbit is offline
Vehicles: 04 prius
Prius puzzler
I've got a Prius MPG problem that I'd like to relate to the community
for some feedback and ideas, because the evidence is sort of bizarre
and inexplicable.
This is also being posted to the prius_technical_stuff yahoogroup.
I've been doing fairly well over the winter in my '04, turning in tank
averages across the high fifties to low sixties MPG, but a friend with
an '05 has only been managing 45-ish MPG averages despite trying to be
a little more mellow on the road. [It's Jesse aka "300kmile prius", who
some of you know.] Now, he does have a somewhat more aggressive driving
style than me, but he's been trying to think about MPG a little more
lately and both of us agreed that the difference in results shouldn't
be *that* far apart in what's essentially the same car. I've got 102K
miles on mine, he's up around 150K.
Well, yesterday we got to explore that further. As a test, I drove
us down to an event and back, a couple of hours each way, in Jesse's
car, and my results were in the crapper too, making us think that
something's amiss with his Prius. It was raining for much of the way
down on the first leg of the trip but the roads were close to dry on
the way back, but even with *my* right foot in play I could only pull
49 or so MPG. Heck, on my run down to meet up with everyone else
earlier that same morning on a fresh tank, I was showing 64.0 on
arrival [which with my known +1.2% tire revs error should still
equate to about 62 real-life].
There are no obvious differences between the vehicles. Their setups
are the same as far as drivetrain -- stock system, a little extra
instrumentation added. '04 and '05 have the same minor ECU bugs
with regard to how they report certain parameters via OBD-II, but we
know how to ignore some of that. He's running 0W-20 oil where I'm
still running 5W-30. Similar tire pressures, all mid to high 50s,
but he's running the stock Integrities where I'm on my 50,000+ mile
old Hydroedges [which anecdotally deliver lower MPG but I think that's
basically bunkum once they've worn in and are run at decent pressure].
No hints from the helm of any misalignment, and tire wear looks
normal and even. With three of us and a bit of luggage in the car
we might have been running a little heavy, but not that bad.
I set up an Xgauge on his Scangauge to monitor fuel injector open
time, as detailed in my writeup on rudimentary CANbus analysis,
and the Xgauge programming I'm using now has actually evolved a little
past that to be more selective:
_ 07E0 21F3 / 0306 8461 05F3 / 3808 / 000A 0008 0001 : inj
and to add the +1 offset that seems to make it more accurately match
the professional scantool. I've been using this as one of my main
guidelines for several months now, and it really helps to determine
the boundaries of efficient running.
The parameters that I've come to consider "normal" are thus: injection
time reaches about 5.0 or 5.1 milliseconds as the engine becomes fully
torque-loaded and I see the manifold vacuum drop, and stays on
something of a plateau between 5.1 and 6.2 - 6.4 ms over a wide RPM
range from there on. On pushing harder with RPM climbing toward
3000, I see peaks of 7.0 ms. We have a fair amount of evidence at
this point that this is the most efficient running range for the
Prius engine, and on the highway where the battery and electrical
system is largely out of the picture, it's all about how the engine
is run that dictates efficiency. My own driving has been lately
influenced by monitoring RPM, injection time, and kilowatts, and
the fact that I've been turning high fifties and low sixties with
significant highway travel through a fairly cold winter [and only
sporadic block-heater use] bears that out. I'm eagerly waiting
for warm days and summer gas blend to get here, and start my
fifth-year graduate-level curriculum on Prius driving.
When I lock my foot at 2000 engine RPM on the highway, letting the
terrain determine my actual travel speed within reason, in my car I
see 6.2 - 6.3 ms injection time, maybe as high as 6.4, and speed
tends to stay generally between 55 and 65 MPH over gentle terrain.
This is what I refer to as the "60@60 point" where MPH meets MPG.
In Jesse's car, at the same 2000 RPM and observing about the same
range of travel speeds and performance, injection time was more like
6.8 - 6.9, with occasional excursions to 7.0 or more. And the highest
I could push the average on the MFD was 49.5 -- I never broke 50 MPG
the entire day, in fact, even on the backroads near our destination.
I was pretty much driving the way I always do, and the car felt
like it was doing about what I'd expect at any given RPM in terms
of power output and speed of travel. But there was this notable
disparity in fuel usage -- 10% more squirt-time in his, basically,
leading to something approaching a 20% fuel-economy difference.
I think that's more than the passengers or the weather would have
donked it; something has to be wrong.
We stopped carefully [regen-only as well as I could determine] a
couple of times so I could get out and feel all the brakes, seeing
if I could detect any heat from one dragging. All stone-cold, and
if that was a factor the speeds I observed from holding at 2000 RPM
would likely have been lower anyway. RPM vs. ballpark speed and
the miscellaneous seat-of-the pants determinations in his car
matches what mine does; it's just injector time that doesn't.
He's got a relatively new air filter, and we changed his plugs
and transaxle fluid at about 120K a little while back. I didn't
check the oil *level*, in hindsight.
I didn't have all my Scangauge notes with me or I would have set
up to monitor his short-term and long-term fuel trims, to see if
any of that was off but not off enough to throw a MIL. Maybe next
time we get together. What I'm looking for here, from those who
have bothered to read this far, is some additional ideas on what
to check for. Compare TPS deltas between idle and steady-state
running? Inspect for vacuum leaks? Dump all the crap out of the
car and try a solo loop on a nicer day? That sort of thing, geared
toward whatever might affect MPG in a relatively serious way.
_H*
Old 04-12-2009, 08:25 PM
ILAveo ILAveo is offline
Vehicles: 03 Ranger(mostly), 07 Aveo(sometimes), 96 Taurus(occasionally), 01 saturn SL1 (rarely)
Re: Prius puzzler
The next test I would try would be a coast down test of his car vs. yours to verify whether to chase a drivetrain explanation or not.
I don't know specifics about the Prius power plant but the mystery effect you're chasing could be consistent with a dirty/worn sensor feeding the ECU mildly inaccurate readings. Maybe your car could be a donor car for swap tests?
Old 04-12-2009, 08:36 PM
JusBringIt's Avatar
Be Inspired
Vehicles: 1999 Dodge Avenger, 2009 GMC Denali
Re: Prius puzzler
If you have the horsepower x-gauge, you could gauge the hp used at 50mph vs what is used in your car at 50mph. Since they have the same engines and practically the same ecu, the power reading should be identical. The one pushing out more hp obviously has more resistance and more than likely a mechanical problem. This is probably the easiest way to determine any excessive powertrain consumption.
Now I'm no expert on the prius, but if the maintenance listed above are the only ones, within the last 100k miles, that might be the issue. The spark plugs maybe?
Ricardo
Best Round Trip: 55.6mpg 147mi
Best Tank:44.2mpg 730.6mi
Old 04-12-2009, 10:52 PM
Vehicles: 04 prius
Re: Prius puzzler
Plugs are recent, as mentioned.
I *should* have also banged in my preferred equivalent to the
horsepower xgauge, which is kilowatts. [see the xgauge-database
thread for details.] But we needed to get rolling so I didn't
want to be wading through the xgauge UI for another several minutes.
Good idea on the coast-down test. Now we need to find a suitable
hill with no traffic...
_H*
Old 04-13-2009, 01:19 AM
MaxxMPG's Avatar
MaxxMPG MaxxMPG is offline
Vehicles: 2006 Chev Malibu Maxx, 1994 Chry LeBaron GTC conv
Re: Prius puzzler
The longer injection "squirt" would have to correspond with more air in order to keep the O2 sensor happy, so that introduces two possibilities.
1- The O2 sensor is getting old and sluggish, although this could be a longshot because OBDii keeps the sensor under close observation.
2 - There could be a brake or wheel bearing or other drag on his car (which the lonely hill coastdown could prove) that would lead to higher road horsepower requirements. And more HP is the result of the longer injection pulse and the equivalent boost of air.
If it turns out to be some sort of drag, coast down in N vs D would likely help to determine if it's a problem with brakes or bearings or if it's in the powertrain.
Old 04-13-2009, 02:22 AM
drimportracing's Avatar
drimportracing drimportracing is offline
Pizza driver: 61,000+ deliveries
Vehicles: 92 Geo Metro convertible 1.L, 3 cyl, 5 speed and a FSP
Re: Prius puzzler
I'm thinking along the lines of what MaxxMPG said with regards to the injector pulse. O2 sensors are cheap and easy to replace and at 150K not a bad investment, I would check the EGR valve too for excessive carbon buildup. (I'm assuming a Prius has an EGR valve). Vacuum lines could be leaking from the intake manifold. How does it idle compared to yours? If they are both cold do they close loop at the same time?
I would also check the battery (bench test under load and electrolyte level), if it's not in optimal condition then the alternator has to work harder, it wouldn't make the pulse longer but it would waste fuel.
Also disconnect the battery for 10-15 minutes to clear the computer and reconnect and drive it slow with hypermiling techniques for at least 75 miles then see what it gets for it's next tank or what whatever you guys can do immediately with a scanguage (I'm envious and nearly clueless) That faster pulse could be an ECU response to his more aggressive driving style. The ECU will establish a pattern of driving after approximately 75 miles and adjust to that style, ie economy over performance response.
You could tell him it's his heavy shoes. - Dale
50.28mpg/457.8miles/9.104g Jan 25-29, 2010 Best mpg.
514.6miles/10.392g/49.52mpg Jan 20-24, 2010 Best over 500 tank.
Old 04-13-2009, 05:35 AM
Kacey Green's Avatar
Kacey Green Kacey Green is offline
Vehicles: 2009 HCHII
Re: Prius puzzler
O2 sensors are said to be cheap but I've seen the price range wildly on different vehicles, from $300 to $1500, when did they stop being cheap? or are we comparing them to more major repairs?
The Midlands Hybrid Club, the home of the hypermiling and hybrid club of the Carolinas, based in Columbia, SC.
Old 04-13-2009, 06:37 AM
99LeCouch 99LeCouch is offline
Vehicles: 1999 Buick LeSabre
Re: Prius puzzler
$1500 for an O2 sensor?!? I thought $90 was bad...
Could be a near-dead sensor, or could be it needs a PCV valve and a tuneup.
1999 Buick LeSabre
"Look at the rolling couch!"
Old 04-13-2009, 06:42 AM
Re: Prius puzzler
most of these were "off brands" non-Honda/Acura used cars
The $1500 was a luxury brand
Old 04-13-2009, 07:50 AM
JusBringIt's Avatar
Be Inspired
Re: Prius puzzler
I paid $35 for mine
Ricardo
CleanMPG Previews the 2010 Toyota Prius-III xcel Reviews 38 01-01-2010 11:19 AM
2010 Toyota Prius-III Revealed... new details xcel Articles 31 03-06-2009 10:35 AM
Chicago to NY in a Prius on one tank of fuel? xcel Articles 9 08-09-2008 12:29 AM
