Acceleration - how hard?
Old 03-02-2009, 11:26 PM
SentraSE-R's Avatar
SentraSE-R SentraSE-R is offline
Pishtaco
Vehicles: 2012 Hyundai Elantra A6, 2006 Scion xB M5
Re: Acceleration - how hard?
You should get a ScanGauge to monitor your engine load while you're accelerating. To achieve best BSFC, you want to keep LOD between about 75 and 85, and RPM between about 1500-2200 rpm (for most 2.0 liter class engines). Full throttle wastes too much gas. You need much less throttle climbing a hill, and much more descending a hill, to achieve the same load. We're talking about aggressive accelerating during pulses, not maintaining speed - which should be done with light throttle.
Darrell
Boycotting Exxon since 1989, BP since 2010
49.6 mpg avg over 38,000 miles. 177% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Best tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 03-03-2009, 07:50 AM
PaleMelanesian's Avatar
Beat The System
For steady-speed driving, yes, you want the minimum throttle possible, like a granny.
But we want more. So we pulse and glide. This article hits on the technique for the pulse part.
Andrew
Old 03-03-2009, 11:12 AM
run500mph's Avatar
run500mph run500mph is offline
Vehicles: Daewoo Nubira 2001
I have a question. I have done 75-80% throttle and had great results. I have now been pulsing from around 40 mph at full throttle and achieved the highest numbers in a year. Someone said that it is my scanguage reading incorrectly because it is wot. Can't thr SG read wot correctly? The mpgs have gone up significantly by doing this. I accelerate from a stop at about 40% throttle at 1st gear then about 100% from 2nd through 5th gear to a max speed of 60 then FAS on the glide. The tires have been at 75-85 psi so the glides are very very long. The change seems logical to me, but what say you all?
Old 03-03-2009, 11:18 AM
ksstathead's Avatar
If it goes open loop at WOT, then SG may not be accurate. Need to confirm with tank averages.
Old 03-03-2009, 12:38 PM
run500mph's Avatar
Can you seen on the sg if it goes open loop?
Old 03-03-2009, 12:57 PM
Right Lane Cruiser's Avatar
Penguin of Notagascar
You should be able to see it on the LP gauge. I'd pull it up and see what happens while you are accelerating with your foot planted. If it opens, the air/fuel ratio the SG uses to compute consumption won't be valid anymore.
- Sean
New? Start here!
Old 03-03-2009, 02:53 PM
JusBringIt's Avatar
Be Inspired
at wot, loop is open, sg wiill most likely read 9999mpg.
Ricardo
Best Segment: 25.3mi@76.9mpg
Old 03-03-2009, 03:10 PM
SentraSE-R's Avatar
Pishtaco
SG won't read 9999 mpg unless you've got open loop and fuel cutoff. My SG is set to monitor fuel cutoff at idle thottle position sensor (1) plua 4 (5). At WOT, the TPS would be 35 or so, and I'd have <5 mpg fuel economy.
Darrell
  #19   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 03-03-2009, 03:13 PM
JusBringIt's Avatar
Be Inspired
If there is a significant change in throttle position, wot to no throttle, or vice versa, the sg has a tendency to read 9999 for a brief period.
Ricardo
  #20   Submit to Clesto Submit to Digg Submit to Reddit Submit to Furl Submit to Del.icio.us Submit to Spurl
Old 03-03-2009, 05:56 PM
All that can be said for certain is that in WOT circumstances most vehicles depart from the stoich air/fuel ratio and dump enough fuel in to make sure that the cylinders don't burn (ie, they run very rich).
The SG measures air flow and uses that to calculate the fuel consumption using the stoich ratio and will continue to do so during WOT. This means that it will report less fuel used than what is actually burned -- a higher mpg readout than reality would dictate.
- Sean
New? Start here!
Adapting Basic Hypermiling Techniques to the HCH-II tarabell Articles 90 11-19-2010 09:29 PM
Acceleration Rates 87LX Fuel Economy 8 11-01-2008 11:20 AM
I Need help with Acceleration, or new improved Scangauge? abcdpeterson Fuel Economy 6 08-14-2008 09:01 PM
Optimal Acceleration AT&MT - Gas only Tweakfreak Fuel Economy 11 08-01-2008 07:05 PM
